Although I managed to make a limber board for my Triton cross-section, I remain unhappy with the method I used as it wasn't as precise as I wished.
The method I used was simply to angle a disc sander and sand the parallel sides without cutting the bottom flat part (I thought that at this scale the lack of a flat part would not be very noticeable).
I therefore thought it would be nice to find out from the experts how they approached doing this.
The picture of the cross-section is:
All contributions most welcome as I'm bound to be doing this on future builds!
Thanks
Tony
Thanks, druxey. I had thought about doing it with the saw (as I do have a tilting arbor) and could see how the first face might be cut. However I thought it might be hard to cut the second parallel face over the full length to the exact width as it would require careful juggling with a stick holding it down.
And after that I thought that the final flat on the lower surface would prove even more difficult.
However, I can see that this might be something to practise and perfect!
Tony
Ha! Having thought about it in relation to another sawing question (this time the waterway on the lower deck of the Triton cross-section) I realised how simple it would be.
The reason I was in a bind was that I was thinking of cutting the angles on a 2mm plank. The moment I realised that I just have to turn the diagram 90 degrees it was clear that I could use a long and wide block to slice off planks with the correct bevel. That way I could also just push the block 2.44mm to the side for each set of slices
Sorry to have wasted everyone's time, but in case anyone's interested, here's a drawing of explanation:
Now back to the waterways!
Tony
Ah.... Occam's razor strikes again.   Simple and elegant, Tony.
