Hello everyone!
This is my first build log for ship-model building, The Zeehaen, a 17th century dutch merchant ship.
The primary references is 17th CENTURY DUTCH MERCHANT SHIPS(by Ab Hoving) and Shipbuilding in the Dutch Golden Age. The reason for choosing zeehaen is it seems simple but a bit special, and the carving patterns are relatively simple for me to practice. Cor Emke's plans are not suitable for a full frame ship model, but I like some challenging making, although I find I think too simple at first- my 3D building process seemed to hit a brick wall, I can't get any reliable reference of internal structure on the stem and stern. so I finally changed my mind and took Mike Y's advice- start my log while the project is not yet completed. Perhaps someone can provide more accurate internal structural drawings to correct my mistakes, in addition, I also make a presentation of my making methods- Almost all parts were designed by 2D/3D and output to CNC processing.
This is current progress
The frames from k#-35# using 2D cutting
Assembly process
Keel and some special-shaped parts using CNC double-sided milling processing
The "V slot" was  processed directly by CNC.
even so tiny parts were processed by CNC
The Building jig
This kind of jig is recommended by my friend, wangshuoliurui,as a senior shipmodel builder in china. I think this kind of jig is more suitable for those hull in 17th Century.
Some experiments of figurehead or figurine carving patterns were designed by 3d and processed by multi-axial CNC .
3Dmodel was build by rhino, This requires accurate size.
Convert the model into polygon format
output to zbrush and sculpt it by virtual technology
CNC programming and machining.
Wow, that looks like a very interesting project. I will follow with interest.
Regards Christian
Almost fully automated modelling, hjx! My only concern would be the amount of scrap wood generated. Could one move the pieces closer together to mill them out?
