I have decided to build the Batavia by Kolderstok.
I just jumped over here from another vine I started about being not completely satisfied with my build quality.
One area I would like to improve is the precision and consistency in which to cut the gun port openings in a 17th century
Dutch ship. I have done the Prins Willem already but not to my satisfaction.
I am looking for any tips or tricks to get a precise cutout of the hull with sharp corners and clean lines.
Maybe I just don't have the talent to get what I want but any tips would be helpful.
Thank you
JMS
Are your difficulties related to laying out  or marking the ports, or from cutting them out?  (or both?).
I have found over the years that accurate marking is the key to good results and the best way to mark is with a knife, not a pencil.   With a line scribed by a knife, you can carve, file, sand right to the line, and you'll end up with straight edges and sharp corners.  The smaller the scale, the more critical this becomes.
Bruce
Stay Sharp - Stay Safe
Judgement comes from experience:  experience comes from poor judgement.
  • USS Constitution: Scratch build solid hull 1:96 scale
I use a scalpel to cut the gunport. Replacing it regularly. Also make sure its square by using one of the Gun Port lids attached to a small nail to ensute its square
I had this same problem before.
What I do now is carve smaller amounts of wood, instead of taking big chunks, carving one cut vertically and one horizontally,
and always make the end of the previous cut, the limit for the next one.
By being conscious of this, I improved my carving to a more acceptable degree.
Not sure if this will help you, but surely it did for me.
Best of lucks
Ulises
There aren't but two options: do it FAST, or do it RIGHT.
Current Project Build Log: Soleil Royal in 1/72. Kit by Artesania Latina.
Last finished projectsRoyal Ship Vasa 1628; French Vessel Royal Louis 1780. 1/90 Scale by Mamoli. 120 Cannons
Future projects already in my stash: Panart: San Felipe 1/75; OcCre: Santísima Trinidad 1/90;
Wish List: 1/64 Amati Victory, HMS Enterprise in 1/48 by CAF models.
So much to build, so little time!
Hello.
This may help you. I have been watching from video one to ten. Very entertaining.
Go to episode 10
https://www.youtube.com/watch?v=51VT0eYWkxs&list=PLGC1fmQp8LDsu0EKRM9nen3HqOzD8Y3F2&index=10
This is all fine what he is doing, but gun ports which are towards the stern and, to some degree the bow, are progressively les and less square, and become rhombs (parallelograms with other than right angles) because their vertical lines remain true vertical and the horizontal lines follow the decks.
Hence, his handy plastic square template cannot be used there, I'am afraid.
Unless he has different templates for those ports, each with different shapes...
Agreed, however the question was about how to precisely cut the gunports, not finding their placement or shape. Of course you would need different templates if that is called for in your ship. :)
Best regards
We can start a nice discussion about this :) - as a parallelogram shaped gun port  where the turning axle of the hinges are not in the same line  simply cannot be opened. Two hinges beside each other need the same axle line to function properly. And if you mount the hinges under a specific angle so there turning lines are the same then the form of the port gives trouble to open.
The vertical sides of a gun port were vertical - that's correct, but regarding the horizontal lines: the lower one could follow the deck (but this was surely not always the case), but the upper one was always under a 90º angle with the vertical sides. So a square gun port is very original.
Attached a photo of the Vasa (Wasa) which is the excisting proof of how it was done (this is the original ship from 1628 - same time as the Batavia). Due to the back light the form of the gun ports is clearly visible.
Hans
Owner of Kolderstok Models - 17th century Dutch ships.
Please visit www.kolderstok.com for an overview of the model kits available
Hi Hans,
This is a topic getting quite a lot of interest in the Vasa forum: Fred Hocker states that the frames are not vertical in that area of the ship, and that the gunport-sides are not coinciding with the frames.
Besides: when looked at exactly at 90-degree, the aft gunports of Vasa are indeed not completely square, but it is the angle of the picture that suggests more than there actually s. Most of the gunports of Wasa are (almost perfectly) square and not trapezoid....
see this drawing (issued by the Wasa-museum) http://forum.game-labs.net/index.php?/topic/4220-wasa-1628-swedish-warship-with-plans/
Jan
Thanks for the information.
I think I have been doing the cutouts about how most do it. I just need to refine my technique
and the template is a good idea.
However, I just watched episode 13 of the video that Ulises suggested and that is what I will do
on my current build.
Take a look.
JMS
I drill four small holes on the four corners (about 0,6 - 0,8 mm) - in such a way that the hole is complete inside the outlines of the gun port.
Then cut out with a sharp knife and as last thing with a square file make the corners square
Hans
