Nice work and I'm happy you're getting the info you need.
I made the main boom today. Tomorrow I will try to make the gaffs.
Lextin.
Edited by qwerty2008
"I have no special talent. I am only passionately curious." - Albert Einstein.
I made the fore gaff today. I will post pics when I make the main gaff.
Lextin.
I made the topsail yard today.
Lextin.
I just realized that I interpreted the negative space in the line drawings as positive space and made the wales wrong. should I fix them or just leave them?
Lextin.
Jerry I hope you don't mind me using a picture from your build log the red aria is the wale on your Pride the blue aria is the wale on my Byzantium.
Lextin.
You're not building an accurate model of an actual boat, but a sort of fantasy boat.  I don't think this is much of an issue, especially not structurally.
The bottom line is you.  It's your model, what do you want?  If thine wale offend thee, pluck it off.
Jerry Todd
Click to go to that build log
I haven't been able to get on MSW for the past few days. Since my last post I made the t'gallant yard and the yoke and parrels for fore course yard and the topsail yard.
Lextin.
  • 5 weeks later...
I have not done much work on the model lately but yesterday I did manage to make the tubes that the bolts for the drop keel go though. I also made a block to seal between the counter and the deck so water wont get in around the rudder which will be made from aluminium tube and clear polycarbonate that will be slotted and epoxied in place.
Lextin.
Good to see an update Lextin, she is coming along,
michael
A nice bit of progress, Lextin.  Earlier, you were questioning the wales.  What did you decide?
I started on the ruder, I still need to fill the tube with resin, make the hinge and make the tiller. I also made a skylight which will be placed just aft the path of the capstan bars. I am going to go with a capstan rather then a windlass, this clears up space in the bow and fills the extra space towards the stern.
Lextin.
Looking Great Lextin, I like the skylight as well.
Michael
I made the capstan, in the images it does not sit flush with the deck because I have not decided on an exact position yet also the capstan bars in the second picture are temporary mockups so I could see how much space the capstan would need.
Lextin.
That is a big diameter for those bars, were they really that big? I am not familiar with capstans.
Michael
Capstans don't normally appear on such small vessels but I wanted one and it helped with space management. I made the bars similar in proportion to the capstans on larger ships, if you look at the capstan on dafi's victory you can see that the bars go very close to either side of the ship so I did the same.
Lextin.
I have been working on the removable keel the past couple of days. I made the fin and cut the slots for the bolts I also made a muckup weight from foam board the weight will be cast from approximately 30 pounds lead but first I will do another float test just to make sure that it will need 30 pounds if not I will adjust accordingly.
Lextin
I finished building up the thickness of the bulwarks all the way down to the deck and made the anchors. The anchors are made mostly from wood, the flukes are card and the rings will be copper.
Lextin.
Those anchors look good Lextin.
Michael
I broke out the rope walk and made a short length of hawser the took some more pictures. I also got a shot showing the inside of the bulwarks.
Lextin.
The cable looks great , what is the diameter and what threads did you use to make it?
Michael
The diameter is about. 3.5mm, (between 3 and 4 inches in full scale) I made it from four strands of some Nylon string that I got from Wal-Mart a few years back. I might change it later on in the build this one was just so I could see how the anchors would look when finished.
Lextin.
I installed the first bit of radio control gear, the rudder servo and the rudder linkage.
I was also wondering if I should ad another gun port on each side towards the stern where I have drawn the [?] I could then get rid of the planed stern chasers by making the two aft most cannons able to be unshiped and moved to the chaser ports when necessary.
Lextin.
