Eight Sided Drainage Mill by flying_dutchman2 - FINISHED - scale 1:15 - Achtkante Poldermolen
Wood used on the vanes.
Long piece that holds it together (Roede) is poplar.
Piece on top of the roede and the windbord is cherry.
Horizontal (heklatten) and vertical (zoomlatten) slats are purpleheart.
Someone at the woodclub gave me a big tube full of it. So I thought that it would be a perfect fit as it is strong and dark in color.
Marcus
Current Built: Zeehaen 1639, Dutch Fluit from Dutch explorer Abel J. Tasman
Unofficial motto of the VOC:
"God is good, but trade is better"
Bought some more supplies to finish the mill.
Menards: 1 quart of Cliff gray Max Bond exterior paint. This is to imitate the thatch.
Hobby Lobby: More acrylic paints. Orange, Grass green, Black, Titanium white and Crimson
For the bricks that will be glued to the foundation wall.
AMACO 10 lbs Air Dry clay ($11.00), terra cotta color.
Made a template of poplar with 56 rectangular holes 3/4" by 1/4" by 1/4".
1745440368_Achtkantigepldrmlnbrickmaking.thumb.jpg.21622d19aea5f944dafec1ca70d2a2a0.jpg
Took pieces of clay and press in the molds, making sure that the corners are filled in.
535418142_Achtkantigepldrmlnpressclayintemplate.thumb.jpg.28585a831b3cbcf938547235e4d9a8c4.jpg
Once all clay is in the molds, scrape off excess clay on both sides.
780788727_Achtkantigepldrmlnscrapingoffexcess.thumb.jpg.649d26e896f13cffcabf89d5680f8fbf.jpg
The mold is filled with clay.
230218318_Achtkantigepldrmlnbricksmade.thumb.jpg.b029796472fe9861b4c88abacba4f7ce.jpg
Use a scrap piece of wood that is the same size as the mold and gently push out the clay bricks (looks like little loafs of bread) .
531479554_Achtkantigepldrmlnbricksdrying.thumb.jpg.a90a84d5beaa6ceed83fcfdf51ed5e29.jpg
SO far it seems to work. Once dry I can always sand the edges. Not all of them are the same size.
This process can be applied to any size bricks. I opted out of the method that uses tile grout and fortified as I had previously mentioned in this build. This method is cheaper, no mixing of material and works just the same.
I don't know how long it takes to air dry but I assume it has to do with the temp. and humidity of the location.
Marcus
You are right, there. Take into account that for the inside to dry completely it takes a bit longer (at your size certainly an hour ;) ). However, since, I presume, you won't bake your bricks, you can buildwithout the need to wait for them to dry throughout. Bricks used to be molded, and dried in the mold, when outwardly dry, demolded and stacked to dry further for baking. The process has changed considerably since the industrial revolution
Carl
17 minutes ago, cog said:
You are right, there. Take into account that for the inside to dry completely it takes a bit longer (at your size certainly an hour ;) ). However, since, I presume, you won't bake your bricks.
I am letting them dry overnight. Baking? At what temp. and how long, is it better than air drying?
I went to the website of this product and can't find anything on baking this type of clay
I will paint it a darker red and use lacquer on it to protect it from the weather
Marcus
bricks are baked to make them durable - weather resistant - however, your regular oven won't do. don't fret, your solution works too. you might want to use a satin or matt water resistant varnish. glossy lacquer ... not so mill like ...
Carl
My plan was matt lacquer. The varnish idea sounds like a good idea as well.
Any of the shiny paints that are on the mill get a coat of Dull coat.
Marcus
Bricks were completely dry and several had there edges sanded off. Most of them are similar in shape. I stacked them to make a wall and a few are off, so those I won't use.
Took about 2-1/2 hours to make around 200 bricks, this is excluding drying.
677652905_Achtkantigepldrmlnready-to-usebricks.thumb.jpg.7e453c0677813d33a46efdaf242a120c.jpg
After looking at many mill pictures on the Net and in a mill booklet I have decided how to paint the vanes. I am using the colors from the instructions and may improvise a bit.
Started on the first coat vanes. The roede is black on all sides, the windbord is chromium oxide green on both sides, the vertical slats (zoomlatten) are Titanium white on the front and the horizontal slats (heklatten) are chromium oxide green on the front.
1343118262_Achtkantigepldrmlnvanefront.thumb.jpg.820f3de70ddf4a135737c58cfe73cdd1.jpg
Lots of mills don't have paint on the back and sides of the horizontal and vertical slats.
I think I mentioned the reason already. The Miller doesn't paint the slats so he can climb on the vanes to check for broken areas.
Marcus
3 hours ago, amateur said:
Are those 200 enough, or will there be a second batch?
jan
There will be many more. My guess is 200-250 for one side. I have 8 sides. Under 2000 should be enough. The clay cost $11.00 for 10 lbs which is 4.5 kilo. Pretty cheap.
When the mill is completed it will be heavy so a strong wind should not be a problem.
Marcus
Made another batch of bricks this AM, around 330. I dry stacked bricks on the foundation template and it is not 200 but 80-100 depending on an extra layer.
Off to painting another coat on the vanes
Marcus
Started working on the triangular piece (kruiwerk) opposite of the vanes which is the back. Measured the strips that were needed and put a coat of primer on them.
The second coat of paint has been applied and the mill is starting to look good.
While the gray paint was still wet, added a bit of yellow ochre and brown to it and with a brush, brushed downward strokes. Need to do some areas again. Then I will add a picture here.
At the woodclub yesterday someone mentioned a site that sells high quality silicone molds for bricks, pavers, blocks, etc. Should have known, I would have purchased the brick mold. Some of my bricks are a bit uneven. The molds eliminate that. My bricks will have that 'old look'.
Site is called hirstarts.com
They send international as well.
Marcus
Finished painting the vanes. All I need to do is balance them and once that is completed, drill a hole through the red part and the copper tubing and put a nail through it so the vanes stay in place.
1936458587_Achtkantigepldrmlnwiekenvanes.thumb.jpg.08d17d15699e8a2f01ae5f1f97bec59a.jpg
Close up of the axle head. The piece of paper with numbers is that when I take the vanes off I put them back where they were initially.
These are penanten. The are located on the corners at the bottom of the mill.
These are called the kruipalen. These stakes are located in the garden. That big triangular piece (kruibalk), the bottom of it corresponds with the stakes that are on the ground.
Questions for Jan.
What are the kruipalen for?
Is it to let people know that this is a danger zone?
What are the penanten for ?
Is this made of concrete and holds the mill in place?
Still need to do the bricks, put and place the triangular piece permanently put the cap and mill together with a bolt and nut and some more painting.
Marcus
kruipalen are to turn the head with he vanes. the rope is attached to them so by spinning the wheel you turn it
penanten either concrete or brick and mortar foundation
Carl
THe pennants, I dont know, the kruipalen are vital in the turning of the mill to the wind (or out of the wind)
attached to the mill is the kruiwerk: some very heavy beams that are fixed to the kap. At the bottom of the kruiwerk, is an axle wich a large wheel.
Attached to that axle is a rope (or chain, doesn't matter too much, as long as it is strong enough). To turn the mill to the wind, one end of the rope is fixed to one of the kruipalen, and then the miller starts turnong that large wheel, so the rope is wou d up on that axle. This turns the mill.
So these kruipalen are important, and they are rather heavy, relatively long poles, driven i to the ground.
Jan
# Jan and Cog, thank you both for the information and Jan for the video.
So once you have moved the kruibalk with the kruiwiel you leave the rope that is attached to the kruiwiel tied to the kruipaal so the cap and the vanes do not move
Must be a heavy rope or chain to keep it steady.
Took the vanes and the cap of the mill and turned it upside down. Installed the first layer of bricks. As glue I am using the same material that I used to make the thatch. I think it will look good. Bit uneven but that gives it character. 😀
Marcus
No. No need to have a very strong rope, as soos as the mill faces the wind, there are almost no forces that will turn it
als, when turned put of the wind, the wind is blowimg sideways or from behind, again not very strong forces.
but there is indeed a chain to prevent turning. (Some mills have the safety system
sewhere inside in the head.)
jan
Working on the brick wall. Ran out of the little bit of tile glue I had left over so now I am using flooring adhesive. Works well. More liquidity so it goes in all the empty spaces. I apply it with a syringe.
1810994530_Achtkantigepldrmlnbricksglue.thumb.jpg.28d93ed6870f46b1fde2817f2cda7466.jpg
40838865_Achtkantigepldrmlnglueonshortsideofbrick.thumb.jpg.12f13ece9aabf9efbb27741b4f01ded8.jpg
45244971_Achtkantigepldrmln2layerbricks.thumb.jpg.125d498c5cc626952ac233633b16146c.jpg
Layers of bricks.
I know I am going to run out of bricks so I'll have to make more.
Once the foundation wall is finished I will let it dry for a week.
Then I will add a combo of tight bond glue and clay dust to fill in the large crevices, then lightly sand some of the edges to give it a more even look.
Because the clay is a bit brittle, I will use a primer and paint it crimson red which looks like brick red and finalizing with several coats of lacquer.
Hopefully with all these layers of material it will hold out in the weather.
Marcus
Made another batch of bricks and installed the two bottom layers. Let it dry for a couple of days. Then I will sand the bricks somewhat even.
The red blocks on the corners are called pananten. They are usually made of concrete and are there to keep the foundation walls in place.
1246048775_Achtkantigepldrmlnpenantenbricksfinished.thumb.jpg.70cd86c83fd25aa2c06c68ab5dd06d2d.jpg
Finished painting the triangular piece (kruiwerk). At the end of the long slender sticks there are light red caps (klapmutsen). Jan or Cog might know what they are for.
Once bricks are sanded and painted I will also add a coat of Dullcoat to all the shiny paint.
Still need to make the hooks that will be placed in the window frames which are for the shutters.
Also need to add a flag, a vangstok (long stick painted in red, white and blue stripes, when the stick is down the mill is operational and up, it is not or the other way around) and a few other things.
Than put it all together and balance the vanes.
Marcus
After filling in the gaps from the bricks with a glue /sawdust paste and let it dry overnight, I put primer on them. This primer dries in 2 hours.
292032674_Achtkantigepldrmlnprimedbricks.thumb.jpg.5c6497730d00edeaccc8f5e8c1faa031.jpg
Installed the triangular piece (kruiwerk). Put the cap on two crates and screwed the big piece (kruibalk) in place. Nailed the slender pieces (korte en lange schoor) into the designated area (lange en korte spruit).
Attached the slender pieces to the big piece of wood by first gluing them together, then drill a hole through it and hammering a small metal rod into it. Couldn't use a screw or nail. Let it dry.
1856331414_Achtkantigepldrmlnkruiwerkpin.thumb.jpg.4200853653a8121223f32722db99c3fa.jpg
780181993_Achtkantigepldrmlnkruiwerkdone.thumb.jpg.ea562a4696efeab421dc20b19bd689d1.jpg
Painted the first coat of crimson on the bricks. This will dry dark red.
1238117435_Achtkantigepldrmln1stcoatcrimson.thumb.jpg.f37c8cec15910c9ac2e22d81ba437b63.jpg
Marcus
Touched up the bricks and the clinker wall.
Added a second coat of various colors on top and on the bottom of the cap.
The cobalt blue is called heaven (het hemeltje).
Cut out the front and back beards (voor en achter baard). The front will be located on cap under the vanes. There is lettering on that such as the year it was established and a name. The back one is also located on the cap behind the triangular piece (kruiwerk).
Marcus
Installed the various ropes.
The vangstok which is painted in the colors of red, white and blue their is a rope at the end.
At the downwards position means that the vanes are moving.
1989697263_Achtkantigepldrmlnvangstoklow.thumb.jpg.8d20b445cd9ea8998b5286c7bb21a4c5.jpg
In the up position means that the mill stopt turning.
984358123_Achtkantigepldrmlnvangstokup.thumb.jpg.d561ddedb4b939140bd3383a50f9a77d.jpg
Adding a flag mast with a Dutch flag. The flag is a leftover from the Utrecht. Going to see how it holds up to the outside.
Working on attaching the window shutters to the window frames and addind the steps at the bottom of the door frame.
Marcus
