I am planning a 1/2" = 1' cross section model of a boat that had White Oak planking and frames.  What would like more like White Oak at 1/2" scale Beech or Maple?  I have misplaced my reference for which woods look like others at scale.
Thanks,
Kurt
Kurt Van Dahm
Director
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
Midwest Model Shipwrights
North Shore Deadeyes
Butch O'Hare - IPMS
Kurt:
My money is on Beech. I recall Dr. Feldman had good things to say about its scale resemblance to oak.
Russ
Kurt,
The attached photo is of a Great Lakes Batteau, c1763. Scale 1:48.
The POF hull was made from American Sycamore that at your large scale might work well.  It has a distinctive but fine grain that resembles oak.  I might have a piece left over.  Tomorrow i’ll Look through my stash.
Thanks Roger.  I looked through my stash and found a piece of Sycamore.  I think the figuring may be too much.  The photo is of a 13/16 inch piece marked as "S".  The other piece "B" in the photo is Beech.  Between the two I am leaning to the Beech.
I cut a piece off a billet of Black Birch that I like.  I am going to the hardwood store tomorrow or Wednesday and check out some White Birch as I am told it has less figure than the Black Birch.
I have Red Oak galore in my full size shop but not a stick of White Oak, so I am going to compare the pieces I cut against the White Oak as well as comparing the White Birch to the White Oak.
I plan to use Chuck's Alaskan Yellow Cedar in place of the Yellow Pine that was used for ceiling planks, cabin framing and planking and a few other places.  White Pine was the primary wood used as it's the hardest and best wood for boats that is native to IL.
Kurt
Kurt Van Dahm
Director
www.thenrg.org
CLUBS
Butch O'Hare - IPMS
Giving your question some thought, I don't think any species will
scale the grain,  going down usually at a minimum of a factor of 50.
The species with no obvious grain would work best even with White Oak.
I am thinking that it is the color that you are focusing on.  I am no artist and
I do not know their rules, but I bet there is a scale effect on col;or - I just do not
know what it is.
I scored some Beech from Yukon Lumber last week, and it is a shade darker than
Hard Maple-  My Maple tends to vary a bit in color but Beech is a fudge darker.
I find American Sycamore to be generally awful.  What I have has a busy grain, is brittle, can get fuzzy, and
splits easily.  The only really satisfactory use I have had with it is using it to duplicate a 1 x 1 x 6 inch
Xacto sanding block - round at one end, wedge at the other.
If the rule on scaling is things get lighter, Hard Maple may work for you,  If you want even lighter,
Soft Maple.  I found Silver Maple to be too soft, too fuzzy for my taste.
If you want aged and weather beaten,  Poplar -
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
Went to the hardwood store and took various woods over to hold next to some White Oak planks.  After a bunch of back and forth I decided on Birch.  Looks perfect.  Steve Wheeler had suggested using Birch and he was right.  A piece of 1 x 4 and a piece of 1 x 2 each about 5' long will be a lot more than I need for this project but these were the shortest lengths w/o any streaks of darker wood.  Less than $20 and I am all set.
Have already ripped a bunch and cut all the frame pieces I need.
Thanks for the input guys.
Kurt
Kurt Van Dahm
Director
www.thenrg.org
CLUBS
Butch O'Hare - IPMS
Blimey, all this talk of different woods at your local timber store. I did the circuit of all the local stores near me in the UK for a piece of oak to use in the house. All I found was, pine, badly seasoned pine, knotty pine and a bit of teak.
Current Build(s):
Completed Builds:
