You are making big improvements to a rather ordinary kit.  Excellent work.
thank you for your appreciation of my effort
Попков Сергей Федорович
I have a question about the bolts with the square heads that you made in Post #94.  How did you form the square head?  Did you heat them and then shape using the tool you showed earlier?  Or did you heat the brass to melting and use that tool as a mold?
Wonderful work so far.  I'm enjoying watching your technique.
Also thank you for your appreciation of my effort
An apparatus for manufacturing bolts with round and square heads bought here http://forum.modelsworld.ru/topic9552.html
Brass wire of medium hardness. Do not heat the wire and tools.
Cold brass clamped into the holes of the instrument. At the end of which the cylinder iron  pyramidal deepening. With its help wire end did rivet.
A lot of time spent on training.
I apologize for the English translation.
Translated with help Google
Thank you.  And translation worked very well.
You might want to re-check the plans.  The French didn't use the ringbolt to guide the breeching rope to the rear of the cannon barrel. On their carriages, the rope went through a hole where you have the ringbolt.
Impressive work.
Thanks for the feedback about my work
Impressive work.
Became interested in the construction of gun carriages.  I is corrected on the following model
Yes, that is a precedent.  What I was thinking is more like this:  http://modelshipworld.com/index.php?/topic/454-24-pdr-bronze-gun-le-fleuron-1729-by-garward-m-124/
But I think that such an option as I have an exception to the rule
There's always an exception. :)   Keep up the fine work.  I love watching this ship being built.
Do you plan on applying any 'ageing' to the ship?I ask because I am researching different techniques and the Russian forum is a little strange with the translator.
Kind Regards Nigel
Currently working on Royal Caroline
