I want to try Bluejacket’s glued up decking sheets on a project. It is 3/64” in thickness.  It is going to have the stress of the deck camber and the sheer of the deck which sort of oppose each other. What is the general view of the best adhesive to use for a situation like this?
Kurt
Hello Kurt. If it is wood to wood, nothing beats any of the dedicated wood glues: be it Titebond, Elmer's, Gorilla, to name a few.
They form a bond usually stronger than the wood itself.
Edited by Ulises Victoria
There aren't but two options: do it FAST, or do it RIGHT.
Current Project Build Log: Soleil Royal in 1/72. Kit by Artesania Latina.
Last finished projectsRoyal Ship Vasa 1628; French Vessel Royal Louis 1780. 1/90 Scale by Mamoli. 120 Cannons
Future projects already in my stash: Panart: San Felipe 1/75; OcCre: Santísima Trinidad 1/90;
Wish List: 1/64 Amati Victory, HMS Enterprise in 1/48 by CAF models.
So much to build, so little time!
You need to watch the sheet curling when you use those dedicated wood glues. I use CA when gluing sheets because you don’t get the curling, I use the PVA (Titebond 2) when gluing strips
Regards,
Jim Rogers
Damn the Torpedoes , Full speed ahead.   Adm David Farragut.
Are you gluing this to deck beams or a sub-deck?  For beams definitely go with PVA.  I use Titebond II.  For a sub-deck, consider using contact cement.  It will handle the sheer and camber but once you put it on the sub-deck, there is no moving it around.
Toni
Member IPMS
                           Utrecht-1742
Any aliphatic (yellow) glue such as those mentioned above are great.  In woodworking of any kind, IMHO, CA is good for only one thing.    If you cut yourself pretty badly,  it is a great temporary fix to hold the cut closed until you can get to the doctor to put in the sutures.
Allan
Edited by allanyed
To prevent curling due to moisture in white or yellow glue, dampen down the upper side of the sheet to equalize the moisture content both on sides of it.
Too late on that one. The sheet is stained and varnished already. That might be a slight deterrent to it curling though.
Kurt
Edited by Kurt Johnson
