Regarding the bitts for fixation of the foremast; I had a discussion with Frank (fmodair) some time ago. Pictures of La Reale and some of other galleys show that there is a deviation  of 5-7 degree of the foremast from the vertical axis due to the special handling of the lateen sails.
 It declines toward the bow. In the Corel plans, the foremast is shown in a vertical  position.
I decided to follow the paintings and drawings. To follow them, the deviation of the foremast of the vertical axis has also to be reflected in the tube to be drilled into the bitts. I have tested the decline with some wood pieces simulating the bitt and the foremast.
Moreover, I do not believe that the bitts were strong enough to withstand the enormous power of the big sail, i.e., the foremast had to fixed at the keel line. Such a fixation is also shown in the Mondfeld plan of the galley La Dracene. Thus, I made surroundings for the foremast fixation.
Next step is adapting the supports for the oars., which is probably the most difficult part
As suggested by the Corel manual, I started with the two middle supports #82 and #83 (Corel plans), which are at the lowest point of the deck line. To get them in a vertical position I made a holder with a 1.5 mm slot (= thickness of plywood) and 8 mm width of the vertical wood strips   (= distance between the supports). I made also some wood pieces 8 mm wide to keep and control the distances between the supports. Additional supports were added between #82 and #83 and the yokes.
Further supports were inserted between the middle ones and the yokes.
20 hours ago, fmodajr said:
Only one side left to do! Lol!
From the first photo, it looks like you got the curve of the supports perfectly.
Nice job Clark!
Frank
Thanks Frank, when I first read your blog I was astonished that only a limited number of supports can be adapted per day. Now I know what you meant.
Hope to read further inspiring news in your blog.
Clark
Lower planks are glued now and I have started to drill the holes for water outlet. I made some help lines. One line 3 mm distance to the hull to mark the middle of the holes. Rectangular ones to mark the location of the supports. Distance between the rectangular lines was 9.5 mm. Thus, I made a small metal template, outer width 9.5 mm with an inner opening of 6 mm to mark the limits of the holes. For drilling the holes, a driller 0.8 mm was used, wood between the holes was cut and sanded. 6 mm width was marked on the  sander (sanding paper glued on wood piece).
DSC06033.thumb.JPG.87f47e049654df8d1b38db9c0805eab6.JPGDSC06037.thumb.JPG.acf1c08ad7780d06329e0d36d0a05868.JPGDSC06039.thumb.JPG.1063c0ae0756181907689becc5cd974e.JPGDSC06092.thumb.JPG.5637dc80f9722da60a19540abfc71e84.JPG
To arrange supports for the lower planks, I started with the first one arranged by a metal strip clamped to the yolks. Gap between the following supports was kept by using a wood block with 7.3 mm thickness
Nice work on the slots.
Make sure the chain for the shrouds fit thru the slots!
I didn’t check mine and later found that the chain barely fit..
Frank
Thanks Frank,
the photo and my description my have  led to errors but I have just drilled the water outlets, the  slots for the shrouds are probably led through holes in the outer gangway. I will keep your hint in mind.
Clark
21 hours ago, Clark said:
Thanks Frank,
Clark
Hi Clark,
Sorry for the confusion!
I should have been more clear!
Your water outlet slots and the tool you used came out so nice, that my mind jumped to the slots for the shroud chain plates. I should have waited until you reached that point for those slots, before I made my comments!
Frank
To arrange the benches, I wanted to use the template of the outer platform (named arbalester base by corel). However, the plywood pieces were very slovenly cut by corel. Thus I had to put some effort in sanding them or extending by gluing additional wood strips. May be it would have been much easier to make them new as Frank (fmodair) did. For arranging the benches in line with the outer platform I used a wood piece to keep the angle.
DSC06210.thumb.JPG.e1e2f07d9bbfe9fffbc9ec07ac99240f.JPGDSC06213.thumb.JPG.25e2003d3150aa5eba48bfbac563b625.JPG
Regarding the gun deck, I had to regard some points. First, I want to show the ship on trip and not in battle. Thus, the carriages have to be tightly fixed and everything has to be cleaned up. Unfortunately, I could not find a plan how to fix the carriages. Frank (fmodair) shows one in his blog from the fleur de Lis but I am not sure if the fixation shown really worked when the ship was on trip. I created a solution of how I would fix them if I were the 1st officer or anybody else responsible.
DSC06236.thumb.JPG.4e9cbb773f89446cabf9a19fa58788e9.JPGDSC06237.thumb.JPG.2deb58c493abf97f68ea7dd534a19bf8.JPG
The outer platform is now glued. I had a discussion with Frank some time ago about the holes in the platform. He drew my attention to the fact that the shroud chains are led through the holes. Shroud chains contacting wood are probably not doing well on the long run. Thus, I simulated an enforcement of the holes.
DSC06249.thumb.JPG.763cdfa94a48303f13b91fff025203e0.JPGDSC06250.thumb.JPG.ba0aa5cec195d39906d61497f2a2fb79.JPG
The outmost fixation of the outer platform is covered by a small brown/white strip 1mm thick and a walnut strip on the top. I put small “pyramids” on the stern and bow ends to cover the different types of wood.
In the corel plans there is a suggestion to fix the blocks for slackening the fore lateen yard in the middle near the main cannon.   This would not work since it would hinder managing the main cannon. Thus, I fixed it behind the main cannon.
I read the build log of Gimo who built the Reale back in 2013. He showed a nice suggestion to pep up the stern (kings?) platform. I also thought about planking the stern platform and decided to put a compass symbol on it, remaining planking has to be done in a diagonal shape. Template was drawn  using Power Point.
2 hours ago, Gimo said:
hi Clark
great stuff! looking really good
Gimo
Thanks also for the inspiration.
Is the Coureur you are building, the one of CAF/Tom? I am thinking about the next project.
Clark
Clark
I'm building a POB version based on the ANCRE Monograph in scale of 1:42.
Gimo
Current Projects :
  - 74 gun ship (aft cross section) - scale of 1:54
  - Lugger "Le Coureur" - scale of 1:42
Previous Builds :
  - Reale de France
  - Triton Cross Section
Forecastle with upper platform is ready. I used mahogany planks to get a contrast to the gangway of the oarsman und the lilies ornament. Unfortunately, it also makes the sander dust more visible.
18 hours ago, fmodajr said:
Nice work with the mahogany!
Great for the contrast you are looking for.
Frank
Thanks, I will probably proceed with the mahogany planking.
Clark
For planking the decorative platforms at the stern, I used the material provided by corel. Since these platforms were the beginning of the officer’s part of the ship, I marked the “border” to the oarsmen part by a half round strip on the top and a concave one at the bow side.
Clark
16 hours ago, Strata said:
Stunning. I hope the floor will be easily visible on completed model.
The floor will be covered by arches but I know that is there.
Thanks for stopping by.
Clark
Awesome mosaic work on that platform. Everything looks perfect.
Regards,
Dan.
For adapting the arches covering the kings platform, I used and sanded the template provided by Corel before proceeding the way Corel manual suggests. This because the arches had to be put in line with the arches already glued at the stern platform. It took some time but it was the best way to fit the strips.
Railings  were fixed before putting the arch construction on. According to Corel there should be a window line between the railings: So far none of the Reale builders (fmodajr, bender, gimo) liked it. Me neither. I replaced it by some pillars.
