Yes.   Try diluting the white glue with water... about 50/50.  Some also use solvent-based varnish.  Once the footropes are on, coat with the solution of choice (test to see which works best for you).
On my Syren build, in the manual it was suggested to use an appropriate gauge black wire. I think I used 28. At that size it is difficult to know the difference and I could shape the hang of it until it looked right.
     Current:         Emma C. Berry Lobster Smack-Model Shipways-1:32-1866
        Back on the shelf:    USS Essex- MS- "Old Yellow Box" Solid Hull  Wall Hanger (Half Hull)
   Completed:    18th Century Armed Longboat-MS 1/24
                          USN Picket Boat-MS 1864 1/24
                          US Brig Syren by Sea Hoss- Model Shipways-1803
                          18th Century Carronade/Ship Section
                          Mayflower-Pilgrims Pride by Sea Hoss-Model Shipways-1620
                          18th Century Long Boat by Sea Hoss-Model Shipways
                          USS Constitution by Sea Hoss-Revel-Plastic
Applying shellac to the foot rope works well. The shellac soaks into the thread readily. As the alcohol solvent evaporates, the shellac begins to harden. Before it becomes completely hard, it can be shaped as one desires. When it hardens, the string will stay where you had put it. For smaller scales, however, blackened fine wire is easier to work with.
Yep, shellac or zapon are my solution. You can soften it with the solvent again, if you are not yet happy with the shape. This can be also done in sections.
Try "Matte Medium"
Maury
