It was suggested to me when I joined earlier this month that I should start a build log so here goes. :) This is my first wooden model but I have some prior experience with plastic models. So far I have completed the first layer of planking of the ship which after much sanding and application of wood filler seems to be shaping up nicely. The next stage is the second layer of planking.
I have probably made many mistakes already but I am learning as I go.
Your hull looks nice and smooth so far. I used contact glue for the second layer, and it was a messy process. I agree with you that white glue is better. It probably makes a neater job because there's more time to set the planking perfectly, and it dries clear and can be sanded. Yours looks great so far.
The second layer of planking almost finished, a few more finishing touches and sanding. I have learnt a lot from this planking experience for my next model! I am thinking of the Occre Golden Hind or Beagle next.
The next stage is to install the rubbing strakes, but I have a question for those building this model. The instruction states they should be installed 15mm from the top of the bulwarks but that doesn't seem right, maybe a little bit more? Also should the rubbing strake be 15mm (or more) all along or turn upwards at the bow? Thanks
You are correct. They should be 20mm below the top of the bulwark. Also, they do not turn upward at the bow. They are parallel to the top of the bulwark all around.
Here is the measurement from the real ship: you can see it's exactly five feet, which corresponds to 20mm in 1:75 scale.
Thank you Keith that's very helpful. I see you have the original plans so I will know who to ask in future! :)
  • 4 months later...
Work has recommenced on the Terror as I have some free time again!... First step was to install the ice shocks, I had to use a little wood filler after sanding as the wood is quite brittle and broke away in parts, especially where it bends at the bow... also they did not quite line up at the bow (my own fault) but as I had used CA glue I was unable to adjust the planks, I managed to rectify this with a little more filler and careful sanding.
Second was the addition of the aluminum sheets, they are difficult to bend to shape but I'm happy with the finish overall.
It was at this point I decided to paint the hull black/white, a few coats hides a multitude of sins!
This is my first build so I have been following the instructions to the letter, I have read on other build logs that the instructions are incorrect in places, so I hope I haven't messed anything up too badly so far. It is all experience for my next model.
PXL_20201005_092533869.thumb.jpg.26d3b1d00c4937b8a7015e93b9757294.jpgPXL_20201013_131508797.thumb.jpg.5ca133fbc524686ed257bd71c600baa2.jpgPXL_20201013_131434855.thumb.jpg.ace728145f62fee6f46dde74ff3267b4.jpg
I've been doing some work on the deck pieces and I've also made a start on the masts and the bowsprit. The next stage is the fitting of the chainplates, I don't like the out of the box option so I have bought some Billing Boats chainplate straps from Cornwall Model Boats for a more elegant solution. I have  a question for those who have done or are doing this model, the instructions don't state the placement or measurements of the chainplates, as this is my first model I don't want to fit them in the incorrect place and then have problems with the shroud rigging later on. From studying the OCCRE Youtube videos it seems that the first chainplate of each of the three 'sets' of chainplates aligns with each of the masts and there are approx 5mm apart (see image below) - any help or assistance would be greatly appreciated🙂
BF010-350x350.jpg.b7079b3e78f3114a436ac8055d809317.jpgChainplates.png.335a9950ad8ee49e3a482ad67772548c.png
Hi there, good to see someone else went for the Billing Boats solution 🙂 Did the same with my Terror, lined up the first chainplate from the middle of the mast, as you show in your picture.
Took a bigger measurement though, 5mm isn't enough for spacing the deadeyes. Tip, grab some excess planking wood and draw a line every 5,5cm, then transfer that in pencil on the ice-shocks. That gave me a good idea of where the chainplates would end up. Chainplates for the mizzen mast run almost to the end of the shock, so it might be worth measuring before you install them.
"Whatever does not kill you, only makes you stranger."
Current build:
Finished builds:Calella by Occre - Greek Bireme by Amati HMS Terror by Occre - Frigate Diana by Occre
you can put a piece of dowel in the mast hole, mark the height of the top and run a bit of string down to get the right angle (i just marked and drilled with about 1mm extra on top of deadeye diameter.
Keith
