Well done sailor, well done.
Current Build - Caldercraft Diana
Completed - Artesiana Latina Swift, Harvey, MGS Prince de Neufchatel, Imai USS Susquehanna, Mamoli Constitution, Rattlesnake per Hunt Practium, Caldercraft Snake, Diana, Caldercraft Victory, Kammerlander Duke William
Waiting to be Launched -  Bluejacket Constitution
Proud member of The New Jersey Ship Model Society, Model Shipwrights of Niagara, Model Shipwrights of Western New York and Offshore member of the Society of Model Shipwrights
Fantastic work Lyle. :imNotWorthy:
Andrew
Completed (Kits):-
I've been working on a lot of projects but am also getting time in on the Bounty...
Doing some touch-up and building a box for the wiring, switch and battery of my light system.
But the biggest headache has been making rope coils or hanks! What a pain in the ***!
I have attempted several methods and frankly, I don't like any of them... none of them look natural to me. It might be the fact that I make my own rope or maybe I just haven't found a good method.
I have settled on one for the moment that gives me results that I may have to live with... If any of you have ideas or suggestions, please do tell.
For the record, this method was provided by Peter Burton on YouTube
I started out by making this jig, I can do 10 hanks at a time:
I measured the length that I wanted the hanks to be and came up with the distance between nails. The holes are drilled slightly larger than the nails so that they can be removed easily. I also put down some clear tape to keep the hanks from getting glued to the board.
Next, I wound my rope around the nails:
This method seems to be the best for keeping the waste to a minimum...
Once the rope is down, I use a diluted PVA glue (Elmer's) to coat the entire hank and then left it to dry.
Once it was dry, I pulled out the bottom nail while holding the hank down firmly with tweezers and then pulled the middle nail. The top nails can stay in place. Using the tweezers, I gently removed each. Using the tweezers, by passing it through the hank, I grabbed the top loop and pulled it through the hank before placing back on the nail:
I then put another drop of diluted PVA on the top loop where it meets the hank. Letting them dry completely before installing them.
Here are the results:
Not completely happy with these but as I stated, these are the best I've made and after a pretty thorough search, I just haven't found a better solution!
Would love to hear your thoughts!
Lyle
"The only thing that stays the same is the constant state of change"
Completed Builds:
Occre HMS Terror - https://modelshipworld.com/gallery/album/2065-hms-terror-occre/
NRG Half Hull Project - https://modelshipworld.com/topic/23546-half-hull-project-by-lylek1-nrg/
1:130 1847 Harvey - https://modelshipworld.com/gallery/album/2125-1847-baltimore-clipper-harvey-1130-scale/
Scott Miller's Sea of Galilee Boat https://modelshipworld.com/topic/29007-sea-of-galilee-boat-by-se-miller-120-scale-lylek1/
In progress:
Artesania Latina HMS Bounty - https://modelshipworld.com/topic/26817-hms-bounty-by-lylek1-artesania-latina-148-scale/
Waiting for dry-dock space:
Model Shipways - USS Constitution
Master Korbel - Cannon Jolle 1801
A Scratch build -TBD
Making some progress... a little slow but getting there!
My rope hanks have improved as I continue to use the same method as I posted. Still not 100% happy with them...
Definitely an improvement over my first set.
Finished the box that hides my lighting wiring, switch and battery:
Not particularly anything special but serves its purpose.
I need to make about 40-50 more hanks and am working on the touch-up.
Still have the barrels to finish and get everything staged on the below deck portions.
Getting closer!
Lyle
Completed Builds:
In progress:
