more accurate , for this period , mast and top mast connection made by garlands, means connection made permanent ,at least is not supposed to be fast lowering as in later period ,when top rope was implemented / and mast cap looks specific shape ... it should looks like this
Hendrik_Cornelisz._Vroom_-_The_Arrival_of_Elector_Frederick_V_of_the_Palatinate_and_Elizabeth_Stuart.jpg
Hendrik_Cornelisz._Vroom_-_The_Arrival_of_Elector_Frederick_V_of_the_Palatinate_and_Elizabeth_Stuart 01.jpg
Hendrik_Cornelisz._Vroom_-_The_Arrival_of_Elector_Frederick_V_of_the_Palatinate_and_Elizabeth_Stuart 02.jpg
Dutch_and_English_Warships_in_Battle against Portugues-Spanish_-_Aart_van_Antum.jpg
Dutch_and_English_Warships_in_Battle against Portugues-Spanish_-_Aart_van_Antum 01.jpg
2 hours ago, kirill4 said:
Good day Tomasz,
Have question , for what there is one more running end of the tie halliard , as seems on the foto there are two? but tie halliard is a single rope ...
Knight with 4 sheeves may be  correct - on Your model mast cap is continental form/type (which is not correct for this ship, but choozen by kit maker as I understood)) but not in english style as it should be/it should be like a half brick ... and such shape and method of connection mast and top mast (moveable)suppose the top mast could be lowered ... in such case , 4 sheeves in the knight quite reasonable...4th sheeve could be used for top rope...
I will fix it like this... 😅🤣 i am not good with drawing
Edited by Tomasz B
Good day Tomasz,
Did You mean this arrangements?
One,4th sheave of the knight  need to be left free - it is used 20210209_095147.thumb.jpg.fa5dee7fe5a6782cb3878455f4c0b89f.jpgfor top rope
On 1/27/2021 at 2:24 PM, Tomasz B said:
Yes you are completely right,  but i know all my mistakes and almost all parts of it that they are not right , so if i want them to be fixed then i will have to take almost  all of it including masts and boards yet even decking.
So i get to the point when asking myself can i really do this without giving up to soon on this ship ?
So i am not sure i should go for that.
 If i fix one then i will go for another and another and so on ,till bulkheads 😅🤣 and never finish it😥
If I may offer my two cents so to speak, in the end, you're the builder, the Captain, the quality control officer, and it becomes a matter of what is acceptable to you. Those viewing your model will never know what mistakes you made, what you corrected, what is historically correct. What you will take away is what you learned and what you will apply to the next one. That "Holy Grail" of perfection will always be there to seek. I know! I have followed it many years on so many things I have built!
On 2/9/2021 at 6:55 AM, kirill4 said:
Good day Tomasz,
Good morning sir. Yes first left sheave will be free(as mentioned earlier those ropes are not glued yet they are like that just for now)this halliard picture is from GH London i will follow...
Edited by Tomasz B
Good day Tomasz,
All clear, thanks :)
Your rope looks very good and it is correct shape for running rigging.
All the Best!
Kirill
So here it is. Heights of this block will be adjusted later when yards done,but i think just like now is quite good (i am satisfied with 😌) 1 more to go. Also did some work with mizzen boom?(if boom is correct still Learning ,apologies) 😃
Edited by Tomasz B
Upload pictures issues
Please consider the way, how to fitt them right way ! :)))😂
As usual - from R.C.Anderson book
Edited by kirill4
Just have read exactly the same page ha ha... is fig 309 can be applied to my case 🤔when i have only 2 rows of tracks ?
Good day,
I think Yes ,why not? :)
I did them the same way as You with two rows... :)23558790.thumb.jpg.88cea05bfe4c352baae9480abefa3353.jpg23754697.thumb.jpg.e1dd662f991e564e5a840abcd419d6ba.jpg
Edited by kirill4
Hi all.
Had to resize parrel bead, was to big imo... just did smaller.
1 picture is way too big. Last picture smaller one
But i think this block will be to big as well 🤔
8 minutes ago, kirill4 said:
Good day,
This variant looksmuch better,!:)
Thanks ,is more like proper size compare to mast diameter  i think.
Hi All 👋.
Since last post been experimenting with sails (just didn't like the kit ones -too thick and  bad looking sewing imo)
Wasn't sure i want them😕 cuz i don't have sewing machine,
hand sewing ? Hmm tried , is not for me 😅
So i took cloth double the size of a sail and mark exactly half on it then stained one of them
Next pulled stained strand through .
they looks not bad i think-not perfect but i am happy with , i will add rope on every edge later after shaping them and some more details on them but not sure yet what kind of🤔
not 100%sure how they should looks like...
Edited by Tomasz B
Hi All 👋
Because Occre rigging diagram is kind of strange i think i am trying to solve the bowsprit rigging , have searched hundreds of pictures and plans also from books and all i found it should be something like this if all sources are not wrong.
If someone can look at this and tell me i can do it like that?
20210305_183957.thumb.jpg.610de7033a579b126e4c037c95504e13.jpg 20210305_192608.thumb.jpg.9aec2cdb2a09305fef04e02c5693a31c.jpg
And spritsail - nothing glued yet
Apologies if that was explained somewhere already, spend a week on searching and sti not sure 🤔
23 hours ago, kirill4 said:
Rigging plan in Your own building , Post #9 ... no good? :)))
Good afternoon Sir.
You mean occre Rigging?
If yes then i don't understand it completely have a look at it.20210307_204220.thumb.jpg.f7d3b4bf5668f55d17aebcf68c55f72d.jpg
  once is 3 blocks 20210307_204217.thumb.jpg.cdbf862c3ddc1a9a24b89826cf706d61.jpg
another time is 4
I just don't get it
Finally did that Rigging
Is quite similar to what occre suggested but more clear for me😄😀😆....😅🤣
Of course nothing glued yet 🙃for future adjustments
Edited by Tomasz B
Good day,
Dear Tomasz,
I meant Eugen Troppmann reconstruction based on Raymond Aker GH reconstruction...
Or You could use rigging plan from book "Mayflower and other colonial vessel"
Edited by kirill4
Or we could use Hoeckel/ Mondfeld rigging as variant...there are some minor differences from Eugen T. version of rigging
Edited by kirill4
It is not clear from your pictures how You managed spritsail sling and You missed one block in the middle of the spritsail yard( seems You cancelled it by mistake), and one/ pair of it/ fitted on the bowsprit/ these two blocks will make spritsail halliard/ which is ness- ry for yard hoisting and lowering.
Pozition of the spritsail need to be moved to the aft, a little bit,
It need to be shifted behind fore stay lower deadeye-this will give ness-ry space for spritsail moving up and down using halliard...
For better understanding bowsprit rigging arrangement pls refer to relevant article in R.C.Anderson book...
Actualy this book contains almost 90% information ness-ry for galleon model rigging...
Edited by kirill4
Maybe There is sence to add some belaying points for spritsail running rigging near the bowsprit area, where it penetrates trough bulkhead? Or before gammoning?
