thank you Sjors
i havent been able to skype yet with him but talk daily to him on the phone
he is slowly recovering and in good spirits
Current builds : HMS Bounty, Constructo Pilar
Next build : undecided
On the Shelf : AL San Juan, Mamoli HMS Victory
Builds on hold : Ochre Gorch Fock, Hachette/Amati Black Pearl
Previous Builds Gallery : Virginia; King of Mississippi
Previous Builds logs : AL King of Mississippi 1/80
Adrieke,
I'm finally catching your lovely build.   Sorry to hear about your father, but happy to hear he's doing better.  I do hope you and your wife get to visit him. From experience in our families, it will be a trip you won't regret.
after a few days of playing with the endeavour i finaly got round to bying some extra clamps to glue the second deck on
afterwards using a torch i checked for gaps and used some filler so that there is no leakage
you may notice the hole in the deck thats where the led lights will go for the first deck. this way no wires wil be visible through the windows on the second deck. i will also make it that i can easily take out the assembly if i ever need to replace a led.
i still need to figure how i wil hold the 3rd deck in place without glueing it on.
the last picture i tried out to see if the smoke stacks fitted
next i need to create a mold for the windows i need to scratch build
the idea is to assemble all the windows in this mold so that they will all be the same size and shape
Hi Adrieke,
Admire your courage to complicate this build with lights, for which you have to do a lot of modifications. Maybe the next time I built the King :P will follow your model.
Keep the good work going.
John
<span style='font-family: courier new'>In progress: <a class='bbc_url' href='http://modelshipworld.com/index.php?/topic/177-king-of-the-mississippi-artesania-latina-scale-180/'>King of the Mississippi</a></span><br />
<br />
<span style='font-family: courier new'>Completed : <a class='bbc_url' href='http://modelshipworld.com/index.php?/topic/176-mare-nostrum-4331-artesania-latina-scale-135/'>Mare Nostrum 4331</a></span><br />
<span style='font-family: courier new'><a class='bbc_url' href='http://modelshipworld.com/index.php?/gallery/album/51-16th-century-galeass-imai-scale-1160/'>16th century Galeass</a></span><br />
<span style='font-family: courier new'><a class='bbc_url' href='http://members.upc.nl/carla.en.john/Modelbouw/Rocket.htm'>George Stephenson Rocket Locomotive</a></span><br />
<br />
<span style='font-family: courier new'>Next build : sl Louise</span>
Hi Adrieke,
Nice job :).
I don't know what's your next step, but wait for fixing the chimney stacks until next deck is on its place.
It fits not so well (in my kit it didn't).
Edited by wim500
Cheers,
Wim
Current build:
Creole Queen scratchbuild and Korean Turtle War Ship
Finished: King of the Mississippi, Bon Retour, Chinese Pirate Junk, Nave Egizia
Next builds:  Gundeck Vasa; Bounty (bashed)
hello Wim
yes i know i have already adjusted the holes in the deck and was just testing to see if they are straight and it looks good :)
my next step is finishing the lights for the first deck then glue the second deck stateroom on and scratch build the windows :)
i finished working on the little box wiht the lighting for the first deck
it fits nicely in the deck and can be opened to pull it out
now i need to find some small connectors. to hook it up
wiht that out of the way i could now glue the stateroom onto the deck
i did not plank the outside yet as i will fill any gaps up first and then plank over it
i wil now also be able to fit the piece of breadboard with the resistors in teh compartment at the front between the 2 smokestacks (will put 2 walls in painted black so it wil be invisible from the outside
Hi Adrieke,
It looks ingenious, will follow your lighting project with interest.
Regards
John
<br />
<br />
thanks John and Sjors
i am just hoping it turns out the way i want it because i have never done this before
Carlosys was the one that inspired me to try it
i think this build is perfect to put lighting in :)
since the inside of the front and back half circle staterooms wil be visible i had already decided to take out the pieces of plywood that hold the construction together
i painted the walls white and planked the floor
the 4 bits of wood strip will be used to hold the ceiling up until the other walls are bended and glued
they are also painted white so that they wil not be noticeble
Adrieke, you now reached the level of scratch building. I anxiously awaiting the outcome.
Regards,
John
<br />
<br />
can you tell that the curved walls are also scratch made
when taking the stateroom apart to refit for lighting they broke up in several pieces.
first i was just going to join them up again but the ones for the 3rd deck stateroom are smaller and they ended up being a total mess with one bit missing somehow
i bought some 1.5mm plywood to remake them.
the holes for doors and windows are only roughly cut
progressing with the second level stateroom
the back room is ready to have the outside wall fixed again
the square part i cut out at the ceiling is for the part with the led light in.
as mentioned before the idea is that i can repair any faults in th elighting after the model is finished.
for that i wil need to make sure the parts that fit on top of the 3rd deck (see second last picture) are bended corectly so that it wil fit together without gaps and without glue
as feared after reading Johns build log on how he solved the lining up of the holes for the smoke stacks the 3rd deck doesnt line up with the 2nd deck and it wil need to be moved 3 mm to the back
Hi Adrieke,
You are well progressing in your lighting adventure. Happily the 3rd deck misery is identified still in time. In this stage it is not so hard to correct (I assume).
Regards,
John
<br />
<br />
Good day Adrieke,
Your build is quite elaborate but you look like you doing fantastic. Beautiful vessel and I love the diagonal decking.
As to the sealing iron that I'm using on the San Francisco, here at Hobbytown USA it was only $20 and now that I have it I realize it is basically an iron. Fancied up for the hobbiest but essentially, still an iron. My point is, find the smallest clothes iron you can that has a non-stick bottom and you will have pretty much the same thing. It' just adding high heat to wet wood in a small area and bending the fibers as it generates steam. I agree... it's nice but I wouldn't spend $55 either. Just a thought.
Randy
thanks for looking in Randy :)
hmm maybe like a small travel iron if they have that as normal irons feel too bulky for the job
its the same as the other electric plankbenders which are just soldering irons with a difernt tip
unfortunately here in oz lots of things are way more expensive then they should be
Yeah, I think you're right Adrieke. The first planking iron I saw was like a soldering iron and I was surprised by what the hobby shop had - expected a lot smaller. Good luck finding one in oz... I like that, never heard it before. :D
John yes it was not too difficult fixing up the 3rd deck. i did notice that the aft 2 smaller steam stacks are slightly off compared to the plan.
soaked and fitted the first curved wall.
i also worked on preparing the other half circle room for the led :
cutting out the ceiling
make a little ledge to slide the part on
then test fitted it
the last picture shows the inner walls behind the steam stacks that will cover up the wiring inside and the ceiling bit in place
Hi Adrieke,
Looks good. You really have to be inventive by installing the lighting.
Regards,
John
<br />
<br />
hi John
i am figuring it out as i go along
i have a clear view now on how the wiring for lower 2 decks will run
only thing i am stil working on is what kind of connectors i wil use to hook all the parts up
they need to be small and easy to disconnect
i used some 1 mm copper wire to easily assemble the ventilation openings on top of the 2nd deck stateroom
Nice job Adrieke.
In fact there were small windows on top of the second deck. On the outside were the guestrooms and in the middle the bar, diningroom, etc.
Maybe a photo tells more (left upper corner).
Cheers,
Wim
Current build:
thanks dave and Wim
thanks for the picture Wim. had been wondering on how the layout would have been inside :)
Edited by Adrieke
Adrieke,
Assume you are using copperwire to construct the ventilation opening since you must be able to remove the 3rd deck (replacing lighting bulbs a.s.o.)
Regards,
John
<br />
<br />
thanks dave and Wim
Adrieke, here's a link with tons of reference: http://uwdc.library.wisc.edu/collections/LaCrosseSteamboat
Cheers,
Wim
Current build:
thanks again WIm. saved the link in my favourites :)
exciting moments as i am testing the lights for the first deck (yay still working ;) )
i am also creating all the bits that will hold the 2nd deck lighting
tonight been doing a bit of soldering work. man that is just not my thing :(
but i did make progress. just trying to figure out how to hook up the wires
one red wire needs to from right to left to hook up to the first deck lights
 a second one to hook up the single led on the right to the back 3
then a black wire to hook up to the end of the 4 circuits on the left
Edited by Adrieke
