According to John J. Flynn in Ship Modeler's Shop Notes, page 109.
"The lower planking should be laid at a 45 degree angle to the center of the ship".
My question is WHY? What purpose did that serve? This is the first time I have heard of this.
Stay Safe
Bill
This was from vol. 3?   There is an "IF" phrase in your quoted phrase.   I was not able to find the original article on the CD.  Thus, I am not able to discover the context.
He is describing a way to build a strong deck on some model by laying it in two layers.  The under layer being laid at 45 degrees.  I am guessing that the beams are spaced too far apart to provide 90 degree strength.
There are some examples that I have seen in Paris? or similar with diagonal planking that was an attempt to resist hogging or sagging.   I read that one of the innovations with the original version of Constitution was a series of substantial riders that were diagonal and chevron in pattern.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
Some wooden minesweeper hulls were planked in two layers. The inner layer was at 45 degrees to the horizontal/vertical and the outer layer was a more normal parallel to the horizontal. The frames were typical wooden ship design. I don't know if the deck planking was in two layers (I don't recall spending much time looking at the overhead), but the top layer was normal longitudinal planking.
Phil
Current build: USS Cape MSI-2
Good Morning Everyone;
I can understand the reason for making the lower planking diagonal in a model for strength, if this layer is then covered by a more normally-oriented set of planking.
Re full size practice, when Robert Seppings became Surveyor of the Navy in the early 1800s, one of the reforms which he introduced was diagonal deck planking, and diagonal riders. The riders were successful, but the deck planking was dropped after a few years, if I remember correctly.
See below part of a plate from John Fincham's works, showing some ways in which this was done.
Diagonal ledges seems to run counter to one of his guiding principles though, which were to reduce timber consumption, as well as to add strength.
All the best,
Mark P
Edited by Mark P
Previously built models (long ago, aged 18-25ish) POB construction. 32 gun frigate, scratch-built sailing model, Underhill plans.
2 masted topsail schooner, Underhill plans.
Started at around that time, but unfinished: 74 gun ship 'Bellona' NMM plans. POB
On the drawing board: POF model of Royal Caroline 1749, part-planked with interior details. My own plans, based on Admiralty draughts and archival research.
Always on the go: Research into Royal Navy sailing warship design, construction and use, from Tudor times to 1790.
Member of NRG, SNR, NRS, SMS
Thank you guys for your comments. I believe I should have mentioned that the galleon in question is San Marcos from 1580.  John Flynn did not identify what ship he was talking about in his article. My quote is exactly as printed.
Stay Safe everyone
Bill
i try to learn something new everyday, shame i missed the idea for 60 years of my life
i have never heard of the diagonal  under decking
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Below is the entire bit in the original Shop Notes that was initially referenced.  Below that is the original published in the Secretaries Newsletter Vol 3 - pg 25.  It is an exact copy of the referenced text that I found in the #3 SNL file on the CD.  It was a shop note in the SNL - no other related info.
Kurt
PLANKED DECKS by John J. Flynn (3-2)
If one is at all apprehensive about an individually laid planked
deck opening up, make allowances for a double deck. The lower planking
should be laid at a 45 degree angle to the center of the ship.
In the past I used blackened glue to indicate seams between
deck planks, but no longer do so. I feel the seams and butts are prominent
enough with just a glue line.
I put in enough nails to hold each plank until the glue underneath
it has dried. The nails are left slightly above the deck surface so
they can be easily drawn. Sanding fills these nail holes and is just suggestive
enough of actual wooden plugs put over the counter sunk nail
holes in a full sized vessel.
Kurt Van Dahm
Director
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
Midwest Model Shipwrights
North Shore Deadeyes
Butch O'Hare - IPMS
