I bought some wood dough to help smooth the inside of the bulwarks before I paint the inside of them, then add the prepared decking, suppled with the kit. Meanwhile, I made an fitted the jaws for the mainmast boom and jib. They fit the mast snugly. I worked more on the forward companionway and one of the deck skylights. These look OK, viewed with the naked eye, fuzzy and rough in the picture.
Edited by Organ tech
addition
Since the sponsons and the deck are at the same level, I cut out the bulwarks where the  paddle wheel-water closets will go. Slightly too wide so some putty and paint  will be used here later.
Next, I traced the paper patterns for the deck, a thin basswood piece, suppled with the kit, scored with lines to be the planking. For logical reasons, this pattern will only be approximate, and need to be corrected, with paper "shims" to accurately conform to my actual bulwark outlines.  Reasons for correction---paper and wood both change size slightly with humidity, micro-deviation of my my bulwark carving from the paper pattern, to name a couple. Pics show the tracing,  paper inserted in the hull with a "shim" at the stern. My pattern was pretty close.
When satisfied with the pattern, I anchored it to the basswood deck sheet with a couple dabs of rubber cement, and cut it out with a razor knife. The deck sheet was barley large enough, but adequate. I used contact cement to glue it into the hull. My fit is good enough where the waterline "moldings" shown in the instructions, will cover any gaps between the bulwarks and deck. small pieces will need to be glued between the sponsions and deck. Coming up---gun cutouts, outside hull painting, and copper sheeting, as well as keel and rudder.
I'm starting out on my own HL build, so I'm following along to learn what I can. Good work so far.
Under construction: Mamoli Roter Lowe
Completed builds: Constructo Enterprise, AL Le Renard
Up next: Panart Lynx, MS Harriet Lane
In need of attention: 14-foot Pintail in the driveway
I am working on other hull details such as cutting the gun ports and adding the copper below water sheathing. The better quality copper was mostly missing from my kit, save for a few inches. I bought some stained glass flux, from a hobby supply, to use as a satisfactory substitute.
My painted hull is missing its shearstrake as it will be easier to add it after the paddlewheel sponsions are in place, following up with a black sharpie.
Sheathing done. Tomorrow the rudder, railing, shearstrakes, and finally adding sub assemblies  to the hull, masts, bowsprit, and paddle wheels. Though not obvious in the pic, the keel has sheathing.
Shearstrake an portholes in place and fitting eight eye bolts in the bow area for the bowsprit stays and rigging. I held the grommets, used for portholes, on a 16 penny nail and pressed them into their pre- drilled holes.
“Precise” locations for mast hole located. Jig made on drill press with the  slight back tilt for the  (F) fore mast and greater back tilt for the (M) main mast, for accurate drilling.
Ship posing with its main mast and both paddle wheel assemblies in place.   Before I glue in the masts, I will add the fife rails, debating whether to use the Britannia metal parts supplied, or to fabricate from wood. I am not sure why the aft rigged main mast has one. Maybe included in the original builders plans in case an owner wanted to square rig this mast(?).
I am redoing my forward companionway and a couple of other deck structures. I can do better. My ship with the deck house in place, not affixed yet, just a photo op.the windows on the pilot house don’t cut it either. I will re-do them.
