Along with victory cross section, that is almost done, the time has come to start HMS Victory.
Corel's kit is a bit old (at least the one I have) and probably I will have to make a lot of improvements/modifications
while building the hull, I have noticed that many parts did not fit very well, hull beams are looking quite old and  dry
I had to fill the gaps almost in every hull beam
Current builds:
Hermione la Fayette - Artesnia latina 1:89
HMS Victory - Corel 1:98
Completed builds:
San Juan Nepomuceno - Artesnia latina 1:90
San Francisco II - Artesnia latina 1:90
Victory cross section - Corel 1:98
deck planks were cut in 10 cm each and the caulking was made with soft black pencil.
 I have marked the deck with parallel squares just to ensure the right positioning of the deck planks. In some occasions I have to make micro adjustments to keep them in a straight line
always planking from center toward sides
Half done
need some sanding, caulking looking good for this scale (1:98) will be darker when oil is applied
with half deck oiled the difference is obvious!!!
Current builds:
Completed builds:
for deck planking I have choosen the "rule of 4", using 10cm planks. But unfortunately I couldnt avoid mistakesand had to redo some planks
almost done, the new planks are few tones brighter than the old ones, I guess I ll have to wait to see how are they look after oiling
Current builds:
Completed builds:
in order to make sure that all planks are aligned, I am drawing a grid and trying to align deck planks
after few hours the deck is comming nicelly
Current builds:
Completed builds:
  • 5 months later...
1562799894_deckplanking009upperdeck3fixed.thumb.jpg.6f20634cf4399b0edd4c557f964d3dae.jpg
I have to remove these blocks before finishing upper deck. Is not written into instructions but I am pretty sure are useless
Actually I had to work on third block too, I didnt do it in time, so in later step I have to make corrections
Current builds:
Completed builds:
Kostas, I agree with you that you were better off to remove the stubs of the bulkheads.  The moulded dimension of the top of the top timbers of the Victory  is about 5.5" to 7" depending if at the waist, QD, or FC so about 0.06" (1.5mm) at your scale.
I love that you are not trying to show treenails on the deck planking as they would have to be 0.008", nearly impossible to make and look good.
Your gratings look far better than seen in the majority of other kit builds. Did you make these are they from the kit?    It is hard to tell from the photos, but the openings would be about 0.03" (0.8mm) or less at your scale.  These look to be maybe a little large, but hard to tell from the photos.
Will you be following the planking tutorials here at MSW when you plank the hull?
I look forward to your next progress posting.
Allan
Thank you for your remarks.
I have tried treenails in lower deck .... disaster!!!!
Gratings are made from kit, but the frames I used darker timber and I have trimmed the top of the frames becouse I didnt liked them to look perfect square.
I have used different methods in my 2 previous builds, I am not sure which one I will follow. Actually I am not thinking of using brass plates in lower hull.
I have already finished first layer, I will post pictures soon.
I am monitoring 3-4 build logs at MSW for HMS Victory, but I have to decide which steps I will follow, some of them are quite complicated for me
Current builds:
Completed builds:
Working on first layer planking hull000.thumb.jpg.210ccacba88bb56ada533786ce870d3a.jpg
After the first basic plank, I will place 2 more.
The first 3 rows are placed in full length/height from bow to stern
Current builds:
Completed builds:
  • 3 months later...
First hole to be drilled have to be in the center of portholes, in order to be used for the cannon barels
next step, maiking several holes around frame to make easier the opening ports
In many portholes there was a missmatch with the wooden axis for the gun barrels, so I had to check and fix all the portholes
Next step was to attach the frames, in this step it was the rigth moment to measure and correct the size and the position of the portholes1098306548_dgunhull003.thumb.jpg.e90832f337a54d0f1c37092e81a9703c.jpg
Current builds:
Completed builds:
  • 3 months later...
Corel's Stern galleries are outdated or poor, so I will try to apply some fixes before painting
Starting with windows...
Corel's kit is providing a yellowish trasnparent sheet with the windows rails printed, so I decided to install new ones.
After many hours, finally all windows rails in place.
Next step will be the fisrt coat of painting using airbrush, in order to aply the less (thinner) paint as possible for the Gallery carvings
Current builds:
Completed builds:
On the  the right gallery, I have placed frames around windows, now they are looking more realistic.
I have already paint gallery parts  yellowish before installing the frames, So I will have to repaint them
The carvings on the side galleries (red arrows) are not present on the HMS Victory, so I have to remove them
Edited by kostas_gr
Current builds:
Completed builds:
Stern gallerie after painting, I need to correct some spots... I will fix them once is placed on hull
after the removal of the carvings, I have to redo the outside frames to match with the rest
Current builds:
Completed builds:
I am starting planking placing with wales first. The position is marked on hull, to avoid missplacing. (red arrrows)
I had to use bamboo sticks, to stabilize the upper side deck, couse I got tired to repair it again n again. (green arrows)
Current builds:
Completed builds:
Hi Kostas
Thank you for sharing your build, it is a pleasure to follow your nice work.
Are the stern and gallery lights (windows) from the kit?   The reason I ask is that the stern lights have nine panes in each light rather than the six shown in post #17 and I believe the gallery lights have two rows with six panes and the lower row with nine panes.   I realize this may be a kit design error.
Allan
Edited by allanyed
Hi Allan.
The kit is outdated with many errors. There where no panels for the windows, the kit had a yellowish transparent film, with the panels painted in black
***the pictures are taken from Sheerline's post
film1.jpg.08ab57e0241174e8e196ffbdd17103f3.jpgfilm2.jpg.2101212a6155a10ede899c5b324e84d6.jpg
I wasnt pleased with the outcome (using kit instructions), so I tried to scratch build them.
When I tried to create 9 panels (like in the original ship) it was almost impossible, maybe I should have tried a different technique..., so I did 6 panels per window and looked not tha bad.
The kit has a lot of outdated (or wrong) details and I knew I couldnt fix them all.
Current builds:
Completed builds:
Yes, making the framing for the lights is a challenge at any scale from about 1:48 and smaller.   I have even used wire for an experiment at 1:196.  At 1:98 the frame parts would be something like 0.01X0.015 so can be done with a good hard wood like box or someother tight grained hard wood.  For the future, maybe consider plastic frames.  There are styrene strips available at 0.010" X 0.02" that might work for you.   It can be mortised with out breaking for a good fit of the parts.   I like to make a template for each light then make and assemble the muntons and stiles on the template.  Once the framework is complete you can glue a clear plastic piece to the inboard side of the finished unit then glue the entire assembly in place.  Just be sure to have a ledge of some sort in the light opening to support the assembly when it is placed and glued in place.  It is a challenge to be sure, but they are a very visible and noticeable part of any model so worth the time and effort to make them as neatly as possible for many folks.
Allan
Thank you for your valid points, to be honest I should have tried styrene strips or even better to ask from a friend for a 3d printing....
I have started the second layer of planking, so new challenges ahead
Current builds:
Completed builds:
Planking the hull using 9cm walnut planks, using the "rule of three" ( 9cm : 3 =3cm space from row to row).
for the wales I have used 15cm planks (with rule of three)
there is color differences among the planks, especialy from the wales and above, sometimes becouse of the wood itself, sometimes becouse I have used more heat (using iron heater) than needed in order to bend them.
I will paint them black-yellow later, so it doesnt matter, but from the wales and below I will keep the nature wooden color so I choose walnut stripes that are similar (colorwise)
Current builds:
Completed builds:
working on second layer of hull planking
some gunports arent finished, so may look smaller. Stern galleries will need some repairs and definately a repaint (scheduled with hull painting)
Current builds:
Completed builds:
Hi Kostas!
You're working on a great model and doing a wonderful job on this Corel kit. Keep up the great work and don't mind the color difference between the planks it will pass in time due UV light.
regards,
Peter
On 2/17/2023 at 10:40 AM, Katsumoto said:
Hi Kostas!
regards,
Peter
I have used some extra walnut strips for wales and the color is a bit darker, so I hope UV light will do the work. The hull section above waterline will be painted, so I dont really mind.
Current builds:
Completed builds:
Your planking is exemplary.  It is a pleasure to see planking done as was done in actual practice rather than the fantasy planking seen so often.
Regarding the wales, they were commonly black, so yours being darker is probably a good thing.
Allan
Edited by allanyed
