Hello Jim, welcome to MSW. I echo what Allan says.
The tool-aholics here are probably all hoping to see a useful 'clamping device': I know I am ✔️
STAY SAFE
current builds:
cablejim
I cannot see the image, only the path to your android device.
could you please re-post it
Thanks
Alan O'Neill
DFXLII
I REALLY like the  clamps in the first photos.   Regarding the last picture, if the planks are spiled or alternatively  pre-bend the planks as demonstrated by Chuck Passaro, there is  no need for any kind of pins or clamps when gluing a strake in place.  Just a little finger pressure while the glue of your choice sets up.  I find PVA will hold a properly spiled or pre-bent plank in less than a minute.  Some members like to use CA and I am guessing that would hold in a few seconds.  Do you bevel the edges of each strake to account for the radius of the hull?
Thanks for sharing your clamp designs!!!
Allan
Hi: I usually use epoxy glue for all my planking. Even though most of the time (with lots of experience) my planks fit pretty good, I like to clamp. I have been milling castello and just recently used hickory for planks and I usually put a slight bevel on the edges, but not much. They a both pretty hard and demand some care shaping and bending. Thanks.
