I scaled this model in 1/2" scale and Bluejacket Ship Crafters had some very nice cast Britannia lobsters but the traps were not available in that scale so I got the closest they had, 5/8" scale a little oversized but okay.
A surprising number of people think live lobsters are orange like a cooked one but most are a mostly brown base color with flecks of orange. my painting choices were quite experimental and serendipitously obtained. I had a number of old model paints from my train modelling supplies.  I started with a base ACCU flex Milwaukee Orange and then dipped it in Engine Black mixed with a bit of SP Daylight Red but wasn't happy with the result so I added some of the orange but it didn't mixed well. I think they came out perfect.
Bluejacket Shipcrafters lobster trap,
161732408_BluejacketShipcrafterslobstertrap.thumb.JPG.6dfc629e4b9db8e416f3e854d074b8b6.JPG
Actual Maine Lobster
My painted ones. The V notch in the tale indicates a female of reproductive age the was previously caught with eggs visible so the lobsterman cuts the notch and throws her back and anyone who catches her later will also throw her back (it's the law).
There are a number of odd colored ones found in Maine waters. Below are some from the Maine state aquarium.
You can see the escaping lobsters led by the Blue Lobster on the transom here
The white painting is done so on to the decking. I used mahogany strips that I soaked in boiling water for an hour and then fit and clamped with any method I could come up with until dried. Fore and aft king planks were installed and then the strips were laid.
I pulled the first strips in a bit too far and ended up with minor kinks at the forward corners of the cabin that I didn't notice until after the glue was dry so I left them, this caused the planking to not be parallel and I had to do some extra fitting towards the bow.
Most of the deck has been installed.
The bullhorns have been fashioned and installed
Starting to add the finishing touches.
The cabin portholes are made by laminating two pieces of the clear plastic and outlining them with a black Sharpie permanent marker.
Davit and block are installed.
 The opening window is a working window, I made a gas strut for it that works.
Life ring and wheel are Bluejacket Shipcrafters castings.
Keep those lines neat to avoid tripping on them.
Time to mark the waterline. I used my laser line tool combined with the digital level to locate it.
Bottom paint is done and red boot line was done using pinstriping tape. The block it's mounted on is a piece of driftwood found in Boothbay Harbor.
The decals were made with waterslide transfer paper using artwork I did on Excel and  printed using my inkjet printer and then sprayed with clear Lacquer paint, they worked flawlessly.
Hadn't planed on building a case but then I remembered the two cats in residence and made one.
This was my first boat model since 1967 and I had a blast making it, made plenty of mistakes but learned a ton.
I am now onto the Bluenose Shipcrafters kit of the Bowdoin Schooner, a gift for my Bowdoin graduate. Build log coming soon.
