Flying Fish by MikeR - 1:64 (3/16" to 1 Foot) - from Model Shipways plans
1911 Europa: Steel Bark, 131 ft length, 24.4 ft beam, 15 ft depth of hold, 108 ft mainmast height.
1851 Flying Fish: Wooden Extreme Clipper Ship, 220 ft length, 40 ft beam, 22 ft depth of hold, 150 ft estimated mainmast height.
In all fairness, this isn't an equal comparison, as the steel bark was originally constructed as a light ship while the California Clipper was a purposely built merchant vessel designed to powerfully sail through some of the toughest seas on the planet. Still, the latter vessel is referred to as a "Tall Ship" and she's a lovely ship. However, America's original, genuine "Tall Ships" truly scraped the skies and would be a wonder to behold today.
Link to comment
Share on other sites
14 hours ago, ClipperFan said:
Snug Harbor Johnny
That's a beautiful photo. What would be amazing to see would be how your Flying Fish would absolutely dwarf this modern day steel tall ship Europa. I'm going to look up the specs on the two to share and idea of the comparisons. But you're right, this image proves exactly what I'm talking about. In fact, in this image, based on the direction of the flag at the mainmast she appears to be sailing upwind.
  Flags are 'funny' things - the wind can whip them around all kinds of ways, and the presence of sails forces air outward and upward due to to the increased pressure.  My guess is that the shutter snapped at the instant the flag was in a position other than the direction of the prevailing breeze - or that it is actually angled a bit towards us (versus away), or a combination of both effects.  BTW I can only 'dream' about building a clipper model as fine as Mike R's ... and eventually I'm likely to give it the college try, you know, 'Win one for the skipper'. 😉
Current project(s): Gorch Fock restoration 1:100, Billing Wasa (bust) - 1:100 Billings, Great Harry (bust) 1:88 ex. Sergal 1:65
Link to comment
Snug Harbor Johnny
I think you're right that the flag is being pushed by a different wind than the sails in your beautiful Europa picture. She definitely appears to be sailing with the wind directly abaft.
I know what you mean, when you discuss the incredible artisanship of modelers like Mike R with his beautiful Clipper Flying Fish. The metal crafting and wooden spar scratch building that's done so casually is just mind-bending for novices like myself. EdT has set the bar at an unbelievable level. I have to admit to having a bit of a personal bias towards the two Glory of the Seas models, since I was deeply involved in collaborative research that led to a point where Vlad was able to create hull molds. Rob Wiederrich's 1:96th scale is a beauty to behold and I personally consider her to be the most accurate replica of the ship to date. Meanwhile Vladimir's even larger 1:72nd scale continues to be rigged and is another beautiful rendition of McKay's long lost final Clipper. A Nautical Research Journal article I wrote nearly a year ago is finally going to be published in February's issue. It should include some never before seen photos, courtesy of author Micheal Mejelde who was intimately involved in Rob and Vladimir's project.
Link to comment
17 hours ago, MikeR said:
Today I made the iron sheet blocks,  I used .013 brass and cut them out on my scroll saw.  I glued 2 pieces together and glued the pattern on. That way both sides will be the same.  A little sanding and they were ready for assembly. I cut 1/16" tubing  for rollers and spacer and soldered them in.
Mike R
MikeR your delicate machine work is simply amazing! Thanks for sharing.
Link to comment
Great metal work Mike.  I wasn't aware the Flying fish only had a single topsail........?   1851 build might mean prior to being Howes Rigged.
Fantastic work.  One observation though......those yards would not have been strapped to the masts, but parrelled for ease of movement up and down the masts
Rob
Edited by rwiederrich
Current build:
Finished build:
Current build(On hold):
Link to comment
Rob the plans that I have for the Flying Fish show the truss and truss bands on the lower, topsail, and top gallant yards.  The royal and skysail have hinged parrels.  I see in the Harold Underhill book Masting & Rigging that it is only the lower and topsail yards that have the trusses.  I have been following the plans so far, other than the color, I do not paint my models I like to use different color wood.
Link to comment
I'm confused.  Why would anyone want to *band* a yard (Irregardless of having a truss), that NEEDS to travel up and down the mast it travels?   Yes the main and LOWER topsail yard are trussed...because they do not move up and down the mast.  The lower topsail yard in a Howes design is fixed with a crane to the mast cap.  But if you are only using a single topsail.(As what appears you are modeling)...it must travel up and down the mast freely by way of a hinged parrell.  Your topsail yard is banded to the mast, making it stationary and immovable. Your wonderful work on your chain/gin block tys and haulyards will not work with a stationary banded yard.
Do you see what I am pointing out?
Rob
Current build:
Finished build:
Link to comment
Rob
MikeR, I believe the point Rob's making is that, unless a yardarm is going to be permanently affixed to the mast, there's no need for a permanent band. In the case of all moveable yards, which sometimes were partially lowered when reefed in rough weather, they need greater mobility so they would only require the hinged parrell.
There are more than one image of McKay's last clipper which show a much simpler arrangement of all upper yards. By the way, your hardware work is really beautiful.
Link to comment
Rob & ClipperFan   Thanks for checking up on me and letting me know something is not right.  On going over the drawing again I found this note "Iron ring in band lined with leather and greased".  So I installed the iron ring in the band and the leather and grease you can not see.  I guess that is how this yard clamp works, it allows it to slide up and down the mast.
Thank again
MikeR
Link to comment
Thank again
MikeR
Yep, the perrell was leather lined and lubricated.   And had some play to it, so it would not bind under a heavy load.
Rob
Current build:
Finished build:
Link to comment
Rick thanks, it is a good way for me to pass the time of day. Except it goes to fast.
I turned the yards for the main mast and made the iron work for the lower arm.  I also  made that little jig to hold the yards while I work on them.  If only the foot ropes would stay the way they are now.
Mike R
Link to comment
Hello All
For the last few days I have been working on the main mast, lower yard and topsail yard. While working on rigging I broke the knuckle joint on the topsail bracket that holds it on the mast.  I do not know what I  caught it on,  I made another one out of  brass and broke it today.  I use my wood lathe and a file to turn 1/8" rod down to .039" or 1 mm. I then use a die to run the threads on.  I turned another piece of brass and made 2 more.  Then I thought about turning one out of steel. It should be stronger.  I had 1/8" stainless steel rods so that is what I used.  It took a little longer to reduce it to 1mm but it came out ok. I then ran the threads on and it turned out easier than I thought it would be.  I hope the steel one will last.
MikeR
Link to comment
Thank you Vladimir,  You did a great job on your repairs and I like your carvings.  One of these days I am going to have to try to carve a fish.
I have finished most of the rigging for the mizzen and main masts.  I still have to run the lines for the yard braces, but I will get to that latter on.   I had some belaying pins that I was using, they are very soft and I think they are made out of lead.  I am replacing them with pins I made out of 1/16" brass rod.  I am turning them on my wood lathe and using files to shape them.  I have made about 40 so far and only have 50 to 60 more to go.  I have been replacing them and tensioning the lines at the same time and I am also redoing lines that I found that were crossed or twisted.
Edited by MikeR
Link to comment
Wonderful work.
Rob
Current build:
Finished build:
Link to comment
Rob and Rick Thanks,   Rick working with a wood lathe takes practice.  A couple of suggestions, Use a very lite touch when turning very thin material for your top yards and I use the highest speed for the lathe to turn them.
I started making and installing rope coils, also tying ratlines.
Mike
Link to comment
Your scale permits you ample room and levity
The trick, I wish I had tackled, was truly modeling the limpness and natural hang.... in the bunt line ropes, as they come down and pass through the fairleads.   To keep them remotely taught, you unduly apply unnatural stresses on the shrouds.
How to tackle that will haunt me till I simply replace all the lines (On my new model) with wire, that I can bend to achieve the effect.
You are doing a fantastic job....and I'm quite impressed.
Rob
Current build:
Finished build:
Link to comment
Wow. Making your own belaying pins.
That is hardcore!
George K
Link to comment
Mike,
      When you rigged the tackles for the course, top, and topgallant sheets, how did you run the live ends to the pinrails? On the plan excerpt below, the live ends for the course and top sheets leave a double block on the deck by the mast and the rigging plans say that they are belayed on the pinrails. That seems odd to me,was hoping you might have some insight into how you rigged it.IMG_20230411_232828607.thumb.jpg.a5f761f641a83d817a5b3d1063fcd32a.jpg
Any help appreciated.
Thanks,
George K
Link to comment
Just something I noticed.....  You apparently ran the  lines down through the belay pin hole...then pressed in your belay pin to hold the line in place.
After secured...you then added your rope coils.    Interesting method....I never thought of doing that....I just belayed using the protypical way myself.
Your final look is very nicely done and clean....with appropriate addressed rope coils to boot.
Good job for sure.
Rob
Current build:
Finished build:
Link to comment
Good job for sure.
Rob
Oh wow. Did not see that.
It works, the lines look phenomenal.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
