Post 1
The Beginning
I start this log before starting the actual build as I am completing to gather the research involved after having selected a subject. This build will include more Boothbay Built vessels, and I chose to study our  brigs.  I began some time ago with the following image from our local Boothbay Region Historical Society of the Torrent.  She was one of the last brigs built in 1855 and will surely be part of the story.
1. 1983493519_hb-01torrentpaintingatbrhssmalljpg.thumb.jpg.5d24f2253e32de557ac40459de510bbc.jpg
This painting was made in Genoa, Italy  I believe in 1856.   Apparently, a result of a practice of the time, where an aspiring artist would sketch, then quickly paint and sell an image to the visiting captain.
I am naming the project Brigs of Boothbay.   The first recorded Brig in 1825, was Albert and the last recorded in 1855 was the HG Berry. I will represent both within this log, but the real build will be the newer and large vessel of 1855.  I will build that vessel. H G Berry as a POF build partially completed on the ways. But first to explain the plan:
I turned to the wonderful book, the Shipping Days of old Boothbay by George W. Rice. There and within a few other sources, we have found recordings for 32 brigs built here between 1825 and 1855. I will include that list in a table later.  I characterize the list as follows.  The early brigs included at least one full rigged version, but soon most became half rigged.  The hermaphrodite brig [ I am told here in Maine is a half brig] was apparently preferred on the coast associated with Maine sailing.  It seems that much of service was to and from the West Indies, however the practical need to sail up wind remained the deciding factor. To sail from New England to New York and beyond means up wind all the way!  They often took lumber, dried, or salted fish south and brought molasses and trade goods back. Reading further though the book, Mr. Rice tells of many worldly voyages to the Caribbean, the Mediterranean and further in these sturdy vessels.
The earliest Boothbay brigs were roughly 75 feet and just over 120 tons.  After 1850 they passed 200 tons and by the end of their run in 1855, they, including Torrent and H G Berry, were 110+ feet and roughly 320 tons. There are five of each large and small, and that is what I plan to show……bookends one might say.
  • Large Boothbay brig; Plank on Frame.  H G Berry  112 ft 320 tons.  .....I believe after taking time to make frames they are a feature of the build.  The easy way to make that part of the show is to have the vessel partially planked and decked, so one can see inside.   Then I also like to show a vessel sailing.  My solution this time will be to have two vessels.
  • Small Boothbay brig;  POB partially completed kit hull.  Albert 75 ft 120 tons......Retasking of an old build.    I started the kit for Kate Cory years back.  I had two hulls and at the time thought to build two whalers.   I will continue the log of that build using one of the partially built hulls completed as a period schooner after this build.   The second hull was to be an 1829 Massachusetts brig Pavilion. I will use it for the small brig I reference here. The completion of that model will represent all the rigging and sails that obviously cannot be shown with a vessel under construction on the ways.   She will be called Albert, the first brig built in 1825 but will represent all the 5 smaller versions. They were built 1825 to 55.    She was 120-ton version brig and will be shown under light sails [ most furled]. Thus, I can complete a full build [ sort of]. And I can at least practice all the tasks. Furling silkspan will be a new one to me.
My last two builds, if combined, were like this one. One was plank on frame on the ways and the most recent POB sailing. They were done at a comfortable 1:48 scale.   As I look around at my partially completed projects and consider the practicality of sharing displays, I have decided to try this build a bit smaller at 1:64.
The brig H G Berry I plan to build as the feature of this project is one of the last four Brigs locally built.  For the image I will use Torrent shown above. As partially built, that will be limited to the hull.   Four of the five large Brigs were built in East Boothbay, so I will select East Boothbay as the site.   Torrent and H G Berry were built less than 150 feet from each other less than a year apart.  I must assume with so many people working amongst the yards in this small village, that very few variations existed.  I will explain that more in an update about the local shipyards.
There was an interesting twist to the original design of Torrent to record but not build, and that was altered some 15 years after. The captain’s cabin like a few other brigs of the time, crossed the entire deck. Most would have maintained deck level passage outside the cabin. This cross-deck configuration forced the crew to climb on the roof deck to tend sails and to gain access the wheel, located aft of the cabin.  To avoid all this interruption, the original build moved the wheel forward of the cabin and used chains from the wheel art to the rudder post. The full after deck area, normally for the wheel ,was incorporated into the captain’s cabin.  The noise of the chains was apparently unpleasant to the captain’s companion. The owner cut off the aft section of the huge cabin and replaced a normal wheel and exposed deck aft of the cabin.  That revision was a more normal configuration that I have read was shared on H G Berry
next up getting plans
all for now
Post 2
Choosing the hull plan and settling in on the common location
I have been studying the whole Boothbay region early shipyards over the winter and have taken on the editing and updating of the current vessel database.  I will be giving a talk on the subject in August.  The following sorted table is the current listing of the 32 Brigs built here in the region between 1825 and 1855.
  • 2.   1130870660_hb-02boothbaybrigssort220602pdf.thumb.jpg.3e22e0e57c42fa3df738197d0a80d1e0.jpg here is the full list sorted by size.
  • 3     652671653_hb-03listofallbrigs.thumb.jpg.0753e1a7b78d50b2e8b00d33025906c6.jpg
  • here is the list of the 5 larger Brigs.  They were built in 1852 to 1855, which is clearly the end of the era and set the date for this log.  The last one launched was H G Berry.   I have done some searching and went, as I have before, to the Main Maritime Museum vessel plans and selected a brig built in Harpswell, Maine just 30 miles away.  The plans advertise the half brig Mary Hamilton, built by Curtis & Estes, Harpswell, 1853. Length 119’. One sheet of lines. Drawn by George Parker. Reconstructed from builder’s half model. H G Berry 112 feet.
  • 4   897763791_hb-04listofallsmallbrigs.thumb.jpg.c2954f0dafc3e509c62eb260adb15d9b.jpg
  • here is the list of the 5 small ones.  They are 75 to 80 feet long and 120 to 147 listed tons.  They were built 1825, 30,36 ,44, and 55, which also covers the whole period.    As described in the first posting, my plan is to take that mostly built hull and retask it. The two paintings of Boothbay built brigs do help confirm the sail plan.   There are no other surviving documents to copy, I am following the assumption that there’s little variance in the general shape of the rig between these times.  I suspect the materials of the rigging would have been different over thirty years and I will try to look at that subject as we advance.
Before we get too far in, I need to figure out where this representative “ways “are to be located.  4 of the 5 larger brigs and 3 of five of the smaller brigs were built in East Boothbay. Also, some of the owners were there as well.  I assume that I will be using storyboards as part of the display and not be trying to build a huge diorama.  H G Berry was built in the Charles Murray yard close to the wharf where a working vessel would have come. See the map for more info.
  • 5.   744262885_hb-05ebbmay1857.thumb.jpg.d2fc356e45de18383d80605fab30d3b4.jpg   here is an 1857 map of East Boothbay. I have annotated the main yards. The receiving dock for daily shipments from Portland is just north of the Murray yard on that point of land.  This view shows where 7 of 10 of our smallest and largest brigs were built.  Just for the record, 12 other brigs [ call them mid-sized] were built in this small village in the same period.   Thus at 19 of 32 it is still the main location. I will give a short summary of the yards in a separate update.
Let’s get started on the drawings for H G Berry
This for me will be a multi-step process. I am truly finding my way. I first embedded a scan of the length section into cad and scaled it.   I will use it to develop the frame spacing, Keelson assembly and building board layout.  I have also taken the cross section and used it to draw first the stations as if I am building just bulkheads and then slowly adding mid frames.
  • 6.   94511588_HB-06FRAMINGLAYOUT.thumb.jpg.53a61e2f6f229e9a7f290a15c2696b12.jpg here is the length section in, and the full frames roughed out. This first attempt in the new software simply takes the stations from the drawn plan, scales it and then divides the stations. If I were going to cover up the frames I could simply move forward.
  • 7      749201802_hb-07keelsonassy.thumb.jpg.430d1f8e1b844feb5a9a6ce277561120.jpg here is my first draft of the keel keelson, risers, stem, and sternpost assembly drawing. More work to do here. Much more to do here.
  • 8.    347348585_hb-08buldingboard.thumb.jpg.b3803443807dab54a0bea7a93994b8d5.jpg here is the first draft of the building board layout. This will come last after I decide on the right spacing of the frames.  Again much to do
next up more reading, practice with new apple software and sail plans
Edited by Jond
Post 3
Apple vs Dell and a retired amateur ship modeler
I started on a slow slide down a slippery slope maybe 3 or 4 years back buying my first iPhone to replace my aging android phone. I about a year later I realized my android tablet was long in the tooth, so I went with a new iPad to link to the phone. Then an iWatch that answers if I cannot find my iPhone.  Then last xmas, with my aging dell, to go all in with a new iMac.  It all sounds easy right……It really is a major event.   I have entered a whole new universe.  I will not go far to explain all the effort of the transition. It is like moving to a new country and learning a new language and then realizing the difference in culture.   More than that…truly.
The part of the universe that is relevant to the build is the migration from an old turbo cad that I knew how to play with in 2d, to the cad systems available on iMac.    VERY DIFFERENT!  I had thought that this next build would be my entry to elementary 3d.  The obvious example being the outer and inner curves of all those frames.  My colleagues had convinced me to try Delphship and model the hull first and stations would come out just right……..so far as I can see nobody does that on iMac unless they have a masters in IT.  The first thing they discuss is adding a second operation systems to my nice new machine to run programs….eeek no thanks.
I gave up on finding Delphship or any of those systems talked about and raved about in this forum and similar google and YouTube searches.  I finally bought the Turbocad for iMac thinking I would quickly migrate and then be ready to learn a little about 3d…….ugh…..  everything is different. Anyway, that is my rationalizing for taking short cuts with no further apology.  Please understand all below is limited to 2d drawing on new [ to me] software.
Design basis for HG Berry
Starting to build a vessel with no drawings is always a challenge.   As stated above I first rationalized the basic design by getting lines for a similar aged, locally built vessel and moving on.   That is only the start. Things to solve knowing I am only doing partial deck down….so by example the sail plan is not critical on this vessel other than major spars, bowsprit etc. the line drawings I got are very basic and only show what would have been available with a half model.
So first up…….How is it framed?  How are the stem and sternpost to be modeled?   Fortunately, in an earlier build Aphrodite, an 1853 ship built in Boothbay, I got into the books by William Crothers.  For this build, I will start with the American Built Packets and Freighters Of The 1850’s within which he includes a Brig Volonte : 1852 Wm H Webb in New York.  She was 112 ft and 307 ton.  That’s the same length and rating we are doing here.   That means with some guesses I can use his details and move forward.
  • 09   1481433377_hb09hberrydraftframelayout.jpg.64e6332d15ff1f748f0c6efb1ebbf80c.jpg
  • here is a first draft of a typical frame lay out.
Frames….I am still thinking this through.  Last time was my first time, and I struggled [ working 2d cad].  I chose to make every frame with an added 1/16 inch extra outside and inside for sanding once in place.  Skilled modelers, many in this forum have mastered using 3d where the software calculated the right curve and bevel so one might simply connect the lines. That way one gets almost a perfect frame inside and out before installing it.  That as of now is over my pay grade     So as we start, I fully am aware of the challenge and managing expectations, the need for sanding. I am also nervous as I move from 1:48 to 1:64.
  • 10   955023878_hb10version2offramelayout.thumb.jpg.8fdb6f7ca0279e80d55220818c3115ad.jpg Here is the second draft of the keelson and frame layout.  Mast locations and more thought at the bow and stern.  next up the plankshear etc.
The source used to draft of the keelsom assembly I showed last time came from the Crothers book.   Working at this small scale, I will combine parallel pieces…the  shoe, keel, one piece a space and then keelson, riser1, riser 2, one piece. . This is the kind of short cut I meant.  I know the true modelers would make each piece and the bolt them etc. They make me humble
Sailing plans.
The fore mast.     I have searched the net and many books for the smaller brig design. Chappell has  few examples to use.  First up is to guess if there were three each square sails on a shorter foremast in 1825.  It seems clear in the 1840 images that a higher mast and four sails was the way of the world.  Pavilion 1929 from my last study was converted to whaling in 1844 was always 4 sails on the foremast.   As the three images of local brigs all show four and I am going in that direction.
Location of the masts.    I went to 17 examples on the web and measured on the screen to determine the position of the two masts. They were all different.  I took an average just to see where it fell…not sure yet what a right answer might be.    Reading Crother’s book on The Masting of American Merchant Sail in the 1850’s  he wrote in one place there was lots of variance in this aspect to sail rigs.  He then figured out a standard tied to Lloyds standards.  He shared two different methods.
One is based on placing the masts, so one is 10% aft and the other 34% fore of the midpoint of the waterline.  That means the sum or more than 40 % of hull length between the spars.    The second method is based on the ships overall length….used in the table in his book. The subject of the book is merchant sail and clearly the majority are three masted barks or ships.  He did include a few brigs with partial information.  The Volante masts were recorded to be 24% forward and 12% aft of the mid-point.  It should be noted as well that Volante was a full rigged brig.  I am not smart enough to say that re rigging a vessel from full to half brig would include restepping the mast.   Common sense says no, they would have remained in place.   That means the sum of 36 percent of the hull length separating them and a bit forward of center.
So what to do
HG Berry large brig…. When I take the painting of Torrent and measure, that does not match with Crothers projection. The mast separation is a little less and the masts are clearly centered.    Maybe it was artistic license? Regardless as I am laying it out now the artists choice looks good to me and I feel it should be ok to use that as a basis.
Small brig, former Kate Cory design…. Taking a look at the Kate Cory hull and sail plan drawn by the master Erik Ronnberg, we find the following.   Using the waterline, we go back 8% and forward 30%. And using the full length, we go back 6% and forward 27%. That really is not far away from what Crothers was saying.   So I think I am better to use the existing sail plan as prepared by Ronnberg and be happy…..it looks good on paper
•    Stick with the painting…it looks good
•    Stay with the kate cory rig as the difference are truly subtle.  By staying I have a complete coordinated sail plan that I can plot out for making sails.
Next up get some wood and start of smaller brig rework.
Post 4
Getting the side section figured out, buying some wood, and starting the small brig
This episode has been fun.  I am slowly learning the steps in migrating to the apple version of 2d Turbocad.  Following my plan, I have used the painting of Torrent as a key element.  Here are four views that I used in scaling things
  • 11   1121474275_hb-11torrentpaintingaftcabin.jpg.24fd0659561f8cb7855dc284279fb35a.jpg The aft half of the hull to show placement of the cabin.  See in this view that the wheel was brought forward of the cabin and mast placement.  A very unusual element that was changed as per the record.  I am not modeling the wheel there and will have a normal after deck and wheel as both vessels, Torrent reworked, and HG Berry were described.   As I learned both the Berry and Torrent had the cabin clear across the deck, I will follow that idea.
  • 12.  403008245_hb-12torrentpaintingforecabin.jpg.1c29324b14933e2c61a90b992f999fa6.jpg The forward half of the hull for measuring the mast placement and getting the shearlines feeling right. I also used this to locate the crew cabin
  • 13   1002157515_hb-13berrymanondeckdetail.jpg.e61a51e75eceebb402dfbdf4ae54d116.jpg A detail with a sailor of the fore deck helps in determining the height of the main and fancy rails
  • 14   895559915_hb-14berrymanatwheelcrop.jpg.ea13258810f4dee249bde9fabe8e050a.jpg A detail with the helmsman.  I also used this view or setting the height of the cabin roof and rails.
  • 15     1006680635_hb-15beerypaintinganddrawingsmall.thumb.jpg.db0698d9a650cf54ec21ef32708068c8.jpg here  is a working view where I did not embed, but just brought the photos onto the screen for comparisons.
  • 16.   212401502_hb-16berryxsectionwithrails.thumb.png.06259d96e41e62cdb9087748d883e499.png here is my current draft of the side section.  I think I can now get going on the main elements like the stem and keel assemblies
The small brig Albert [ et al]
In the following view I have taken advantage of having two hulls to retask from whalers.
  • 17.  507997620_hb-17EEE_1347.jpg.076c346b7c9249ac32794f2843e1e214.jpg  the two hulls: the far one is our brig. I removed the former poorly installed copper and got ready to rework the hull. I am using the near one as a work platform to build up the masts and spars.  This approach is nonlinear, as I can work a little on the spars, then work a little on the bottom, and then work a little on the new POF brig.
The wood for POF
I have read so much by the experts that better modeling comes from better wood.  My last two builds were in Poplar and Maple.  Easy to get and easy to work with.  For this project I may have gotten ahead of myself, but I have splurged.
  • 18   1794186539_hb-18EEE_1350.jpg.5bdf204e655ffb67929cdc4412cef4fb.jpg here are four pieces of Costello that I bought online.  The dark color I found was a coat of wax.
  • 19   hb-19EEE_1352.jpg.728387666065f063fa3e33953e585e19.jpg First up was some initial cutting on the normal table saw to get all pieces under ¾ inch in one direction.  I then used my model table saw to make up a supply of 3/32 by 5/8 and ¾  pieces to make frames [ based on 12-inch frames that I am still reviewing] and a few at 3/16 to make up the keel and stem assemblies.  I have to say I understand all the accolades. This is beautiful wood. I hope I can do it justice.
  • 20   1895577729_hb-20EEE_1353.jpg.43d21973f76ae2ab576696dd1925a23e.jpg here is an early progress shot on the spars. I include images of the Crothers books that are so invaluable.
  • 21   1399460997_hb-21EEE_1351.jpg.4b3c3e2ee81b3978f5daf1cbe5fabe89.jpg here I have filled in the whale cutting whole in the former whaler. I also made up a template for setting the sailing brig in some water.
Next up the keel and stem assemblies
All for now
Post 5.
Actually, getting started….maybe
I find that those of us in Maine get invaded every summer by family and friends looking for the sea. Of course we join in with them. That means a few false starts are involved with all planning.  So be it…June was a little progress.
  • 22   1315484446_hb22EEE_1357.jpg.9d7d5f71c76452a3e0d5fa6c03f2580e.jpg here we see the mast assembly for small brig progressing, so they will be ready when the hull is fixed up.
  • 23.   179970237_hb-23EEE_1355.jpg.c9eafd49b98d1ecdc118b857e92f258b.jpg  here we see the keelspan, stern post and stem assemblies being readied, and the keel set on the building board.
  • 24.   1169859430_hb-24EEE_1354.jpg.6abba5e1a22c914cd7029065743e50f7.jpg here is my first frame being cut out for glue up.
  • 25.   1534531524_hb-25EEE_1356.jpg.ad94c875bb7e96853b2b9cbad9e1d61e.jpg  I am not very good at copper tape. I have found that I need to use contact cement to get it to hold.
  • 26    2034534945_hb-26EEE_1360.jpg.3661f2b459361a4b57be5fbfad61a185.jpg I am slowly getting my production sequence up and running for all those frames. I am using a sheet of plexi glass and slide two prints of the frame under, so I can slide around and glue up the pieces for the two halves.
  • 27   999922346_hb-27EEE_1363.jpg.ffc8cefac274a25406710bb811393c5c.jpg here the copper is done for the small brig and now the topside of the hull and deck need attention.  I have lots of clean up on the paint etc. and am now experimenting with the layout of the deck.  The blocks are experiments in form.
The deck houses??
The paintings I have of the two local brigs show the main cabin going rail to rail.  I get the logic of it, example how does the owner /captain and or family sail without an enclosed head?  The vessel is not big enough to have one forward as did the ships of the time.   How is that done without the cabin reaching the side?  The small brig at 75 feet does not have much space for crew deck house.  Using proportions now I see the small structure.    It seems easy to find sample plans of naval brigs of the time. It is the commercial ones that I am struggling to find.
  • 28   104189709_hb-28EEE_1365.jpg.3d2be2a9fb9d81f8b4fbb4fa74b24edc.jpg I mentioned before the challenge of learning to use tubocad on an Imac as part of this build. It is coming along, as I am sticking to two dimensions and leaving enough wood for fixing.  The Costello wood [ new to me] seems very easy to work with, so I believe careful sanding will work.  If not, I will be in trouble.
  • 29   1002506631_hb-29EEE_1366.jpg.b9587cf136eaff69ef922cecdbadc55c.jpg The next trick is to decide which method to set frames.   The easy way is to have a jig that sits above the rail height and receives the extended frames.  Once they are in internal ceilings and shelves / deck beams etc. are set and all is good, off comes the jig.  I am starting off thinking that is my method.   I took offsets from the frame drawings and roughed out the plywood jig.   We’ll see how it goes.
Continued with the small brig on deck and the large Brig frame building reviews.
Small brig
Like many experiments, when they don't work out, I have gone back to the drawing board. Another oops happened with the main mast location on the small brig.
In the study I described above, the Crowther’s book described placing the main mast at 10% boat length behind mid-point.  Despite that recommendation I was satisfied then to keep the Kate Cory layout…just a little back of midpoint.   Well, that did not work out.
30.     2072120688_hb-30EEE_1367.jpg.223441e43210190a9dc419c92b086767.jpgIn this photo I have moved things around, and found that to get things in and to look like several other brigs, I need move the mast aft to a point 10% behind center, I then have room for the center hatch, the forward cabin, a pump etc.  [this move will impact the sail plan slightly as it will likely shorten the boom accordingly.  We’ll see when I get there.
I also need to decide the size of brig’s boats.  Many whalers had “tail Feathers” sticking aft holding a spare boat.  I do not see those in the images of the merchant brigs.  I have yet to cut them off this hull and will study a little more, but I think they need to go.   I learned in an earlier build that following Lloyds rules, this size vessel only needed two boats.  I assume both would be rigged above the forward cabin when offshore. I am currently showing one at 18 and another at 14 feet. [ that is work in progress]   I suppose I should be adding some tackle lines to show how they were handled.   Again, we will see later when we get there.
Large Brig
On the large brig, I have the jig loose but in place and am starting to check out frames.  This will be a long straight work program to get enough of them made and checked, so any adjustments made to the gig can be done before I start. As an example, the frame shown fits fine.  The few behind it need the jig to be sanded back a bit.
31.     hb-31EEE_1368.jpg.797c576eae6fb95e135cb274d6e23b49.jpgThis view shows some progress with one frame that actually fit.
more coming
   It’s time for my first show and tell at our Downeast Shipmodeler’s guild monthly meeting. I got things ready for the local group critique and went off to Bath.   They were kind….truly as the small brig needs lots of clean up.  One smart guy said....hey that looks like one of those kit whalers........
Small Brig
32.   1297650891_hb-32EEE_1369.jpg.3696db63c92f0e6a707d98d0f6b5911e.jpg   in this view we see a few more changes.  I have roughed out two deck cabins, the hatch and shown the plan to store boats. I am starting with the cabins as a similar size as in the painting of the 112-foot brig.  They look too big, but I cannot shrink them too much, as they need to fit bunks galley people etc.
33.   686132802_hb-33EEE_1370.jpg.bf9d593784daace364172448e6784084.jpg   I have also roughed out the windless and hatch and placed the first dead eyes.
34    137791595_hb-34EEE_1371.jpg.4970e4695b7e17cae0d4f54ccf6e6a51.jpg this view shows placement of the aft cabin works. I have enough room to squeeze in the helm, a lazarette, bitts and binnacle.   There just is not enough room at the midship hatch, so I will shrink that cabin a bit. As to the boat on the stern, I am still wondering about the whaler designed tail feather to support the smaller boat aft.  As of now they are coming off.
35.    678040189_hb-35EEE_1372.jpg.23df5c65403a87a8fb7d533c5738e2ab.jpgsurprise. I have treated myself to a new Byrnes disc sander.   Wow it is a great addition and will surely improve my work. Sanding my first frames was wonderful.   It will take some learning to get the bevels right.
36     2146124316_hb-36EEE_1373.jpg.f84f348d5d9236f1c7a035b8bcb3287c.jpghere we see the first fully sanded frame.  it fit yippee
A final check before I move ahead with the cabins
37.   1512525497_hb-37smallbrigcabinlayout.thumb.jpg.5b09d2355dd85af0701350201503335a.jpg In this scaled sketch based on the painting of the larger brig, [ and the width reduced to fit the smaller brig…12 ft]. the fore cabin is 18 by 12 feet, and the aft cabin is 13 by 12 feet. A theoretical combined layout shows bunks for 3 in the aft cabin and maybe 7 forward. My plan is to move ahead with the cabins.  The fore cabin will be reduced about a foot or too in scale to make the deck hatch access seem more reasonable.  The boats I have chosen to use as of now are one at 17 on the stern and one at 19 feet on the roof.  One at 19 feet just clears the shrouds when rigging off the roof.
Now back to work...all for now
You seem to be cracking on at quite a pace Jon.  i agree the deck accommodation does seems to be on the ample side.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Ah, I like those small mid-19th century merchant vessels! Will be following further progress.
Just wondering, why you call her a brig. According to the terminology I learned, she would be a schooner-brig, because she has one full-rigged mast and a schooner-mast with a top-mast only, no square sails and no topgallant-mast. A brig would have two full-rigged masts.
Keith
I am always pleased when you drop in and gently shove me in the right direction.    I have since cut the fore cabin down to where there is reasonable deck access, but still enough room to carry on all the activities needed to be inside a deck crew cabin.   I assume in cold waters that to mend a sail, splice a new line, mend fittings, cook, sleep when possible for say 7 crew that 12 by 14 will have to do.   I also believe, but have no good source to support my felling, that the crew must have been reduced to no more than 10 when the Brig…..brigantine.  was only 75 feet long.   I have been reminded that even today, as in this summer, 5 adults sailed in a 32-foot sailboat for a week and no one was thrown overboard.
  Thanks
Wefalck,
I am honored at your visit….sorry for the abbreviations and calling all a brig.  You are absolutely correct.   According to my studies there are three brig configurations.  Then there is a fourth short name local to Maine. I also take issue with standing rigging …see below .... you can tell this topic is much on my mind.  A quick look at a dictionary online: I would also point out that if you go to more sites you can find more disagreements too.
hermaphrodite brig from oxford languages
1.    a two-masted sailing ship with a square-rigged foremast and, on the mainmast, a square topsail above a fore-and-aft gaff mainsail. **
brigantine.
2.    a two-masted sailing ship with a square-rigged foremast and a fore-and-aft-rigged mainmast.
** see my comment below re foresail.  I believe that definition is wrong because the need for head stay [s]
38.    1582027994_hb-38.jpg.3f1fed9b7f4c7004d7143e68ca70696c.jpg Please see a slide from my upcoming lecture on Boothbay shipyards…..the talk is more about who were there, when, and what vessels they built than any highly technical stuff. The images are off the internet. In the view on the left we have:
  • 1.    Lower left…full brig.  Squares on both masts
  • 2.    Upper left.  Hermaphrodite brig.    Where one square sail is on the main mast and staysails go forward, as there are two, a lower main stay and main topmast stay, that would interfere with a fore sail.  Note I prefer this view that disagrees with the dictionary definition!
  • 3.    Upper center. Brigantine.  I question some of the images here.  A Schooner rig has a jumper stay that is lower mast top to lower mast top and no head stay on the mainmast.  As a foresail is shown, it makes no sense to me that a main lower mast head stay be shown.     I am still looking for more images so that I can be more comfortable to model a foresail with boom and gaff.   if such a stay is there one can only sail on one tack.
  • 4.    I read last winter that in Maine, during the 19th century, the Brigantine was called a half brig.  Surely the logical thought could be half brig half schooner. The discussion of the standing rig configuration probably plays a part.
I would love to learn more about where the variations may have taken place. I am stating what I have read, not what I know. My reading here tells us, full brigs were early and two that were so launched were soon converted to “half brigs”. The prevailing southwest wind on the East coastline made the half brig [ brigantine] popular. Also it allowed smaller crews.  We also know there were many topsail schooners built here as well.
It seems there are many blogs, books, and samples regarding naval brigs, and they were often shown as full brigs.   I find very little information on these merchant vessels.   They seemed to stop in the late 1850’s. After our Civil War, the US ruled only domestic bottoms for interstate commerce, and the boom in building bigger schooners began.
Again, thanks for dropping in and I would love to hear if you could share more info or suggest any references.
Jon
Jon, I think the subject can be a treacherous field. Today, we seem to have a relatively clear terminology, even though there are differences in usage between the US, the UK, and continental Europe.
However, if you go to historical records, the terminology tends to be less clear. The same ship may be referred to in different records by a different classification. In addition, there were in the past various rigs, that we today would consider sort of hybrid forms and that do not fit our modern terminology very well. The hermaphrodite brig is a good example, as already the name indicates, something 'in between'. Arguing about terminology is rather futile.
I don't have strong feelings about the subject and only stumbled about it here, because for me the 'brig' is one of the relatively clear definition, because it is a vessel with two full-rigged masts, i.e. masts with top- and top-gallant masts. As soon as one of the masts only has a top-mast, things tend to become more complicated.
And don't think of the Mediterranean, where the so-called Polacca-rig, i.e. where at least mast and top-gallant were one piece ...
Carry on with the good work and research !
Edited by wefalck
Well, a snow (or Schnau in German) is a special variety: it has a sort thinner mast attached to the back of the main-mast, the snow-mast. The purpose is to allow the gaff to be lowered without interfering with the parrel of main-yard.
Occasionally, multi-masted or even barques had such snow-masts fitted.
The snow-mast largey disappeared in the second quarter of the 19th century, at least over here in Europe.
Wefalck
first thanks for your response above.  I went up the coast the other day with summer visitors to the Penobscot Museum in Searsport, Maine. I had not been in several years and it was fun to see the collection of models and paintings.    I wanted to increase what I had on Brigs.   There was a wonderful example display titled  hermaphrodite brig  so and so that gave even another explanation. It agreed with me that there are stays on the mainmast so gaff rigged fore is nuts.  They have spanker directly on the main mast....no spencer mast or snow rig .   I laughed and wanted immediately to share it with you with you agreement that some subjects have "alternate facts".   It seems alternate facts are an increasing popular event over here on our side of the pond.
EEE_1391.jpg.daebae468127495d65dc5bb07dae5c1a.jpgthis view belongs to the Penobscot museum. it is close to what I think I will be modeling
back to the subject ..I appreciate your suggestion of ...lets carry on
cheers
Rick
welcome from another mainer.  we have a group that meet up in Bath and would welcome you.   My recent reading included chapelle and he described the snow as did Wefalck to be rigged with a smaller mast, whose top fits into the cross tree as it sat behind the lower mizzen.  Think of the large diameter of the main mast on brig or mizzen on a ship and the challenge of the yokes of spars and a lower square sail.  I believe the snow was limited to brig and have read the name spencer mast when reading about a ship.
I am sure you know the penobscot museum well.   We had lunch in Belfast while up there..a great town.
cheers
Edited by Jond
Well, as I said earlier, there are many different alternative truths and alternative terminologies. There is no good in having strong feelings about these things.
I sometimes extrapolate from my native German language and there - to my knowledge, we only have the term 'Schnaumast'.
Another thing to keep in mind is that our ancestors were much less obsessed with terminology than we are today. I gather this terminology-obsession is due to the various maritime dictionaries that began to become proliferated from the middle of the 19th century on in particular. Also, the increasing presence of the Navy in various societies fostered the obsession with terminology, I believe.
The first frames are glued!
This story is more a saga, as I find my way through the fields of trial and error.  I am using 2d cad only and trying to make frames…tough to do when we get to the bow area.
  • 40   1381030267_hb-40EEE_1422.jpg.63c8219428f0d7ba1ec1f29eabc4166d.jpg here was my trial which ended with oops.  I just kept rough cutting the frames thinking that the slight bevel at the top of the jig meant something…..it did not    here are three frames that need to be rebuilt with a little planning.    My effort follows
  • 41.   708428469_hb-41reframesketch.thumb.jpg.bcf588a13ab31053339cc15dddadee6a.jpg here on the plan to remake frame 2. I turned on the layer for frame 1.5.  I then used seat of my pants judgement to decide where to cut the inside
  • 42   943682196_hb-42EEE_1423.jpg.80704c279ee95669915554e99973b819.jpg here is my first trial starting at frame 3.
  • 43   hb-43EEE_1424.jpg.f5600446d4368a04051511af00d328dd.jpg here are the first three rough cut. That means to me as far as I dare go with power tools
  • 44   2032697799_hb-44EEE_1428.jpg.ac5e46ac6823251e0f6c134b103b1600.jpg here is the stack cleaned up. In the end I made all five twice and two if them [ sta 1 and sta 1.5] three times.   I assume that with my methods I will still need to sand after I get them in place, so I left them just a bit heavy.   I also used this time to drill and place 24-gauge copper wire to simulate iron bolts and used liver of Sulphur to darken them.  I doubt they will be visible but would hate to find out later they are and find I didn’t have any.
  • 45.   1106482511_hb-45EEE_1429.jpg.63095cf8c06c04a7424f6ff0ca6d1566.jpg Here is my self-made jig.  I milled out some planks to use as spacers, and hope it works.
  •    46    807760266_hb-46EEE_1430.jpg.516ce371ee8693654b53217e9947b4f9.jpg tada!!!  My first three frames are being glued to the keel and jig.  The jig, at 4 inches above the keel, is about an inch above the future deck.
  •    47  2058841215_hb-47EEE_1431.jpg.288227b7295858b759aa57ce4d2037ac.jpg I am lucky that the clamps I made up for the last POF build are small enough to just fit through the smaller scale spacing.
  • 48.   940111966_hb-48EEE_1432.jpg.022043ad812437d6b3b492242b53fe26.jpgthe first view of what hopefully will be a progression of shots, as the work progresses aft.
Next up   I am working away at the mast trim out and deck work on the smaller brig and want to get the frames going forward on the big brig in place and figure out an approach to install deck frame clamps to make the structure secure as I move aft.
Yep, lofting cant-frames on paper or in a 2D-CAD is not so easy, particularly providing the addenda for fairing, when cutting them out of wood sheet.
thank you Wefalck for your sympathy...I am surely learning by trial and error.  But having fun
thank you Allan
I downloaded and started reading the article.     I am OK through the first 20 pages.  let's see how it goes as he gets into the real deal
I am also trying to find black monofilament to use for bolts, since I found I can see them.   the copper wire and trying to darken it is a pain.  Now I am getting to main area where they will be visible it becomes important.
thanks for the suggested reading
FYI Ernestina  is planned for launching this month.  I'll post and update when she does
cheers
jon
I thought that for encouragement of other learners like me, I would put together the sequence of a frame.    This is no museum piece, but it is fun to try to make bones, and I encourage others to try. This build is my second attempt.  The following photo group is the first half of a frame sequence.
  • hb-49EEE_1434.jpg.8591784206302ba36629c8e45de88de3.jpgTwo prints of the TurboCad layer “frame 18” with pencil marks for joints to be set under plexiglass sheet
  • hb-49EEE_1435.jpg.791d332b832975782ebae451b6d73e71.jpgCut out 3/32” by ¾” or 5/8” strips of Costello with butt ends glued
  • hb-49EEE_1437.jpg.1bee7b4fac9753e67393d72ff562eab1.jpgTwo half frames glued together
  • hb-49EEE_1438.jpg.9838a202f41f55a6f270cd26d4c85e1e.jpgOne copy of print cut out and white glued for cutting …lining up with other
  • hb-49EEE_1442.jpg.9e3039e9ffa6258309d5c030211f4c48.jpgRough cut
  • hb-49EEE_1443.jpg.6a87ddbfb5c8a6db9a58477c4efdbc88.jpgOutside shape
  • hb-49EEE_1444.jpg.9a44df972566eb529a949cbcbd784638.jpgInside shape
  • hb-49EEE_1445.jpg.9b998a1155cf87f45b51d6f144229e92.jpgSometimes I lose the ID label or keel marks. I keep the second print out and find several times it’s convenient to check back in, so I keep them.
_____________________________________
The bow section is tough already, but with absolutely no predrawn cant frames it is fun.   I have no idea if this method will work, but here I go again
The following view shows a progressive idea. First is the book by Crowthers showing us how the bow was to have been framed.  The key for me is two knight heads and four hawse pieces 12” on either side.  In these views I have roughly shaped the knight head and one hawse piece on either side of the stem and tried to dry fit it.  Frame 1 is loosely set in place, and I am going to make up more hawse pieces to try to fill the gap. I have rough sanded using a Dremel, but don’t dare get over aggressive yet.  I have no way to say that what I am doing is accurate as there are no plans for me to follow.  My approach may work, we’ll see.
  •  1195108240_hb-50EEE_1449.jpg.2b1202daf04b4b52e7b8ddba5fa1ff2a.jpglooking forward see the hawse pieces glued
  • 1532108572_hb-50EEE_1450.jpg.32cfa80f58d2bb0ac5f93a3e3a022624.jpgside view...not a lot of room for cant frames.
  •  1968734437_hb-50EEE_1451.jpg.1e3a95bd30e9dd6b5f18e5ee53eab171.jpgfront view
  • 1301567257_hb-50EEE_1452.jpg.e0bf704a3f3b9abaeaabbbd3daf20087.jpgstarboard bow view
  •    888863889_hb-50EEE_1433.jpg.1d3616f6f436f0fbaa128209b70e0a80.jpglooking at the pages of the Crowthers book on framing the bow
Edited by Jond
Looking really good Jon,   Thanks for the updates, your build is a pleasure to follow.   Just so you know, your background study has been as interesting as any I have read here at MSW, kudos for doing all the research.    Did you give the talk you mentioned this month?
Thanks
Allan
Allan
thank you so much for your kind words.  Yes each build to me is much more than the model.   The build is an adventure.
My talk on the history of the Boothbay Shipyards, first 100 years is on the 25th .  I will share a few more points from it in the log here afterward as they relate to the build of these brigs.  I will call that brief bit ....brigs of Boothbay.
this afternoon we are having a tour on a historic vessel around the harbor and I will share that too.  I will send you the link.
To complete the above sequence, I record a few more views of the frame assembly
To complete assembling the frames I have made a new change. I used to use copper wire glue through a hole, filed smooth and then darkened with Liver of Sulphur.   I saw a trick somewhere of using black monofilament.  After finding no black in any local fishing or hardware store, I made some exchanges with an internet site to learn what the 10 lb vs 30 lb test line diameter might be.  I landed on 30 LB was the same as gauge 24 wire, then alas …”out of stock”.  So, I settled om 25 lb test and it works ok.  Before this next step I used a little water on the paper cutting guide and the edge of a chisel to scrape away the white glue.  I then used a Dremel and some hand sanding to improve the shape of the frame prior to drilling those roughly forty holes for simulated bolts.
•   100799638_hb-51EEE_1454.jpg.35fa7e95434b21d0353e8081e88b9832.jpg Here I am using a general glue as I fear the AC will eat the plastic
•    1503225200_hb-51EEE_1455.jpg.ab242d06503c0f48394eb4727fb77261.jpgHere after experimenting I found a new scalpel blade works best to cut off and scrape any glue residue.    After this step I will fine sand the frame before installing
In conclusion I want to admit what I am not doing ,that I am amazed to see the real pros do.
The real frames on larger ships according to Crowther’s were stepped. I.e. the first “floor “of a 12 inch frame might be 14 “ wide and deep and the first futtocks 12 inches. Then the subsequent futtocks or top timber stepped down in both directions as they reached to top.  Also, there was more science to the location of the joints.  In my previous build of a 100-foot schooner, I knew as I was copying the real vessel, Ernestina Morrissey, that the frames were all consistent, so stepping was not necessary.  In this model I cannot tell anyone what was real in 1840.  However…this is a 112 foot vessel. Not that much different than a schooner, EM was of the same size.  This is not a 200-foot ship.   So perhaps my short cut of making all the frames 12 inch all the way up may be accepted.
next up more on the bow
Now back to the bow
Here in my hand is the assembled ‘draft’ stem plus knight head plus four hawse pieces.   What to do next?
•    hb-52EEE_1456.jpg.ecd4a3c0d51f96fd228f52714a5bbc8b.jpg Here I sanded back and tested a few times and the pencil mark shows where I believe I need to cut it back and replace it with a forward cant frame
•     hb-52EEE_1457.jpg.4f18d3488c8716e77e720cb8400722a0.jpg Here miraculously the other side is almost the same
•    hb-52EEE_1458.jpg.a9c31f4a8d80d2d7645e192725809bec.jpg Here looking down on a loose dry fit, it seems that the square frame 1 will end up going in as planned. I am thinking two cant frames will make it all work
•   hb-52EEE_1460.jpg.d73a3289a144bf5400b1abd397d3a59a.jpg In this view I see in the photo that the two loose frames, 1.5 and 1, have slid back a bit.  With them plumbed, there should be just room to make the two  cant frames.
Now how to make them….the adventure continues how can I cut that and make it presentable.
Will this attempt be just a draft?  We’ll see
Edited by Jond
General update and progress on the small Brig……yes I should say half brig ….to be named Albert
If one cares why I number photos in my log, it is because they come from different sources, and I want to be able to file them away in chronological order close to the blog. Then if I want to dive into the folder, they are easier to follow.  It does take time and I am trying to find an easier way.  Now I am on an apple, they make it harder to rename each one.    I am now numbering each batch [ per post]. So just ignore my numbers.
54 updating the small brig sails
I have tried to work on parallel paths on this build. As I am working the deck on the hull, I am doing the masts and sails, so that when the deck is ready, much of the rigging and sails are ready.  I am not convinced this is easier than doing the work on the model, but it is faster and a little safter.  I can move things around and not drop stuff on the model deck as I do repetitive things like tie, glue and cut ratlines.  The following sequence includes some of the work I have done this month.
  • • hb-54EEE_1436.jpg.ff205bc0bf602d532f7859cd00bc630c.jpg   Here I have trimmed out the yards.  This view shows my attempt to add wet white glue and weights to shape and hold the foot ropes.
  • •   hb-54EEE_1439.jpg.bd825db523d269163aa9e9c6a10ff922.jpg Here I have traced sails from the Cate Cory plan. I have left over painted silk span from the last build that was a bit messy. I like that feel of older rougher canvas for a sail that is on a working half brig.
  • •   hb-54EEE_1440.jpg.7f85bb43ee1eab9706c702fee9535399.jpg I built a light box and traced the lines onto the silk span
  • •  hb-54EEE_1441.jpg.dae565eadcebc12227ae856f6b0a043a.jpg  Here we are with the first one cut out and strips ready for assembly. I am using thin annealed steel wire around and thread on the head of the sail
  • •  hb-54EEE_1446.jpg.21da82595cf24d84749ef8d6ab2684d0.jpg  Here is a step I learned the hard way.  Model sails tend to grow.  Therefore, it is a good idea to take the model spar and as I did here cut the sails down just enough
  • •  hb-54EEE_1448.jpg.e9b057d801899f40c027e5eeb43b4a03.jpg  Here again I am tracing out the lines. In this view one can see I tried hard to make the back-to-back lines just a hair apart from each other so if one can see through the sail it looks like a double seem.  I did it but I cannot see through.
  • • hb-54EEE_1453.jpg.cf43830bb64603fac2cf9e4e644d401c.jpg   Here I have set the first sail on the trimmed fore mast. I am working on a spare hull and therefore dropsies don’t matter. I am debating if, or if how many lines I add before transferring to the model.  I think the lifts and sheets for the yards and sails make sense to do here
  • •   hb-54EEE_1462.jpg.c8aed2edcb1209f3fb3058d25eb125ca.jpg I moved the trimmed masts over to the main hull for some progress pictures. The masts have their shrouds and ratlines. Next up is all those little blocks.
  • •  hb-54EEE_1463.jpg.748b6a2d0e8e24b16af9049b0cb9d55f.jpg  Here the deck work is getting about halfway.  I need to figure out fife rails, and the rigging plan next, make a pump, complete the helm, add bitts etc. I did cut down the cabins some since i last shared them.
All for now
Cutting the bow stem assembly and trial fitting two cant frames
53    Well maybe cutting the bow frame assembly back for a frame worked.   I over cut it a bit with the band saw and made a little slice into the keel.  I tried to fix with clear glue and sawdust.
•    hb-53EEE_1467.jpg.5045f57d58d7bba5a2f7bfdbdb085ac4.jpgHere we are on the bandsaw ready to cut….
•    450955327_hb-53EEE_1469copy.jpg.76ffbceeb66c98ee129fc57be400f224.jpgHere the bow assembly is cut, and we see it from the side
•   1757452344_hb-53EEE_1468copy.jpg.74c1e460ed3e62315bea8ef1d90bb3c7.jpg Looking at the inside of the cut piece, there is still much sanding to do, and I am concerned as to access once in place for the inside.  Therefore, I think it is dry fit sand, then dry fit sand etc.
•    hb-53EEE_1470.jpg.35fff0ab95fdc7d4dcbe9c8d53866174.jpgHere I have dry fit two potential cant frames and frame 1. I also went ahead and glued in frame 1.5 as it rests on the keel, and I am now confident that it will work.
•   hb-53EEE_1472.jpg.6724832ee3a964a6203fdf2d28618511.jpg Here for the side all is loose, but it seems will work out.
•   hb-53EEE_1473.jpg.ed4b670eebc2c9cabb0e334e9b3fe256.jpg Here is a view of the bow assembly sitting on the frame 1 outline.  There is room, I hope, for two frames between to fill the gap.  The cant of them is “slight” just to divide the gap into three spaces. I will over cut them a bit as I need to turn them forward just a bit
•   hb-53EEE_1474.jpg.81a3f76424c0f8793a1d6ff78ed970a6.jpg Here the first one is made up and the second ready to go.  I am not sure how I can hold them in dry fits …. that is for next week
Edited by Jond
55 update on the build out of the deck….small brig
I am working my way from stem plus bow sprit to stern figuring out to build and place so I can get the deck work done and be ready to set the masts. Some os straight forward and some is guessing…let’s look
  •   hb-55DSC_1106.jpg.389d3f5154dd7ef965751755be69b829.jpg Here I am adding reef points to fore cousesail.  I have since played a bit to add other lines.
  •   hb-55DSC_1110.jpg.ae27196ff436a74afdba8ff0a453414d.jpg Here I have added a chain drive under the helm.  Thus, I believe I need two lazarette to gain access to them. the mock ups are to move around and decide where to put two hatches and what size.   I am not sure if they would have used the area aft of the cabin for other storage of say spare lines and the like…thus a bit of guess work.  Perhaps they had access from inside the cabin....that is my assumption after seeing that on both Bowdoin and Ernestian similar sized  schooners.  There clearly is not room for an aft hatch. I also added docking hawse pipe that was not on the whaler and an aft bitts.   The main sheet will be made there.
  • •  hb-55DSC_1116.jpg.8b9e91bfce5a5bcf90e229b000a659e2.jpg  Here I have built the main fife rail and pump. I plan to leave them natural as I like the look of the Costello.    I believe they would have had a simple log pump in these early vessels.  There was a maker of such in the same harbor. I used brass tube for the pump.
  • •  hb-55DSC_1117.jpg.469b69bb77957719aff22b33dfbf102f.jpg  Here I have made up a binnacle
  • •   hb-55DSC_1118.jpg.7718ffd2606f2cb2251813595bbab6f4.jpg Here with the cabin set the lack of room on a 76 foot brig / half Brig, is quite evident. It is easy to understand the act of building the aft cabin fully across the deck. I already stated earlier in the log that we know that was done on the larger Brig.
  • hb-55EEE_1497.jpg.f3d4e73c47878789e3bab4bcd2b89b9d.jpg•    General view of the aft half
Next up I have started the bowsprit rigging and the forward deck anchors etc.
