My Veritas Miniature low angle  Block Plan arrived yesterday and it is a little ripper - I wasn't sure just how practicable it was going to be but a few trial strokes on some swiss pear straight out of the box convinced me, with shavings peeling away with little effort. I don't have small hands yet it was a natural fit into the mitt - so to speak - can see plenty of use for this and wasn't at all expensive costing me just $79au. Well worth the price of admission.
Cheers Pete
PS If you buy one don't throw the little cardboard square out - It is, quoting the instructions "a corrosion inhibiting chip offering continuous corrosion protection for up to two years"
I purchased these miniature planes and they just arrived yesterday. Thank you for the tip on the small cardboard squares!!! I totally missed that little detail and had thrown them out. They now have been safely rescued from the trash. Looking forward to making use of them.
Jim
Current Build: HMS Winchelsea, Model Shipways Mayflower
Completed Builds: NRG Half Hull Project
                                   Model Shipways 18th Century Armed Longboat
                                   Dumas 1954 Chris Craft 36' Commander
                                   Dumas 1940 Chris Craft 19' Barrel Back
1 minute ago, druxey said:
Tip: don't rest the plane on its sole, but always on its side. The blade will stay sharper longer.
Treat Druxey's advice as a rule. It really does make a difference.
I got the same plane a month ago and and am still smiling.
STAY SAFE
current builds:
PeteB,
Now that you have a high-quality plane, you may want to consider investing in a set-up for keeping your blades ultra-sharp. Here is what I use (photo from my Build Log here re: HMS Sphinx): a sharpening guide (for proper blade angle), stone, and rubbing pumice/leather strop. This is also referred to as a "waterless" sharpening approach which woks just fine for the type of wood planing we do in this hobby.
CAMSparsPrep01.jpg.7342e1c2b558e121c94baa0fa8423de5.thumb.jpg.552014d66780647c75cd482311613fb8.jpg
Ron
Former Director, Nautical Research Guild, 2021-2025
@modelshipdood on Instagram
Current Build: HMS Diana Update
Completed Builds: HM Gunbrig Cracker #13 (HM Adder Gunbrig)Grace & Peace (Wyoming, 6-masted Schooner), HMS GrecianHMS Sphinx (as HMS CamillaOngakuka Maru, (Higaki Kaisen, It Takes A Village), Le Tigre Privateer, HMS Swan, HMS Godspeed, HMS Ardent, HMS Diana, Russian brig Mercury, Elizabethan Warship Revenge, Xebec Syf'Allah, USF Confederacy, HMS Granado, USS Brig Syren
Veritas also makes a Honing jig for their miniature planes
05P8520-veritas-miniature-honing-guide-f-0111.jpg.2880b1ec162813e8c7e7ce3c26bddffe.jpg05P8520-veritas-miniature-honing-guide-f-0118-1.thumb.jpg.452f4be40501fa43c168aac8c051c90e.jpg05P8520-veritas-miniature-honing-guide-u-0314.jpg.fdd42501592053abbbb2b198f8b30b79.jpg
Jack
Current buildUS Constellation
59 minutes ago, druxey said:
Nice set-up, Ron. Whose sharpening guide is this?
The guide is a $15 one, probably Chinese. A little fiddly to set up the blade but it works a treat. The blade angle is spot-on. The secret sauce on my sharpening rig is the two-sided grit "diamond stone" that comes with an ingenious holder(heavy and thick-footed, no-slip rubber base); this also comes from China, I think. No slippage. Less costly than it looks.
I thought about Veritas ($) but I'm only using this set-up for my Ibex finger planes, no chisels.
Edited by hollowneck
correction text
Ron
Hi Ron can see one side is 1000 grit - could you let me in on the secret sauce recipe by whispering what grit you have on the reverse? Cheers Pete
