Hello from New Zealand, I have been offered some Basswood planking, normally I use Obeshi (Billings) which I find excellent. Has any member used Basswood and is it ok?
Looking forward to your opinions.
Da Lad
I have one of five hundred limited editions of a kit from BB and it comes with Obeshi planking for the hull.
This material is very soft and useful especially when adding a second planking to it..
As for this kit waiting, it will be even more elaborate .... ....  hopefully the idea of might work.
Just as i say, .... may work.
Results will show.
Use the Obeshi wood, as for the first layer of planking. then adding wood of your choice ...second layer is the thin option of wood.
Looking forward to see more of your progress.
Edited by Nirvana
Respectfully
I think many of the Model Shipway kits (Model Expo's line) use basswood for planking.   There's a lot of beautiful work here using those kits.
Basswood is fairly standard in ME kits. It's biggest problem is it is very soft. It is easy to work on especially sanding as one of the other members mentioned.  It also can be readily bent after soaking in water. It stains nicely unless you do not properly clean up excess glue on the surface. That can be easily accomplished by scrapping or rubbing with a q-tip soaked in acetone or Isopropanol depending on what glue you used (CA or PVA). Some folks subtitute better woods for key areas where color or hardness would be beneficial.
Best
Jaxboat B)
All of my boats are about 95% basswood.  Frames, planking, decks, cabins, masts, and on and on.
Bob
Current build:  SS_ Mariefred
It's ok to use. But beware it stains if you have dirty fingers. And I guess with a stain over the top of it will finish it nicely.
Regards, Scott
Completed builds:
Awaiting construction:
Wow, thanks very much for all the prompt answers, I am currently scratch building the "Joffre" (steam powered British tug) Just about ready to begin the planking which will be painted so I would think Basswood will be fine.
  • 5 weeks later...
Jaxboat,
You mentioned "... acetone or Isopropanol depending on what glue you used (CA or PVA)."
Just to make sure, it is acetone for CA and Isopropanol for PVA?
Richard T.
Richard
Member: The Nautical Research Guild
I'm with Cap'n Bob.  About 95% of my Druid is basswood and I have no complaints.  I will continue to do so.  I just used a gel urethane to maintian the wood color.
