rodney1.thumb.jpg.ff16c36ad84d38195ad1da3857ddc6df.jpgrodney4.thumb.jpg.c145eb3b0b8b11693519e880f1e90ccc.jpgmesh1.jpg.6716faf3f6ed5af39049d7f4acd1cbbb.jpg
The Meng HMS Rodney 1/700 was my first model ship I used DIY thread railings on.
I used printed paper as a template, and it was time and labor consuming method, unfortunately.
rail1.jpg.c6a5b7e1b07d3eda6abe7768757e0c81.jpgrail0.png.7d21d811961171437470a42f01cdec4c.png
But I loved the concept. I improved the process by replacing the printed template with a laser-cut sawtooth. The pitch was 0.70mm.
rail2.jpg.3e3f6ccb67d1426ae913560b77c5db54.jpgrail3.jpg.0c9eb75b5f0cc7e68c24ce8fa4466d3d.jpgrail4.jpg.c1b9042d0e205db3ad57519cc3144de5.jpg
This is a test bed. I'll change the pitch.
The thread was 0.10mm thick Amann Serafil 180 polyester thread, and the pitch was 0.70mm. All the thread-winding progress is done within 10 minutes. I hardened the thread using CA glue, and the result was durable. I hope my idea was enjoyable.
1 hour ago, oren said:
process for winding
I glued at first and then wound without glue, like a bobbin. I soak all with CA to keep shape. The regular CA glue has high surface tension, so it tends to block tiny slots. I carefully removed excessive CA glue with Q-tips. I'm looking for more water-like glue.
Edited by modeller_masa
They do make a "thin" CA glue and an "ultra-thin".  I haven't used them so I don't know how "thin" they are.
Thin CA is pretty darn thin and will make a horrible mess in a hurry if you're not careful with it -- I shudder to think about what "ultra-thin" must be like. 😳
