Bonjour, j’en suis à faire mon deuxième projet après celui du BLUENOSE d’artasania latina, voici qu’avec mon ami Pierre, nous commençons tous les deux à distance, moi à BOIS-DES-FILION (Québec, Canada) et lui Granby (Québec Canada )
nous aurons besoins d’aide et de conseils pour réaliser : LE HMS BOUNTY d’Artasania Latina
esperant recevoir vos judicieux conseils !
Voici que déjà une question ?
le premier couple ( pièce # 4 ) dépasse la quille environ 5 mm , dois je la sabler pour être égale ? Si je la monte, le pont sera plus haut à cette endroit !
quel est le meilleur support pour la quille et s’assurer que les couples sont bien droit ?
 Felix, welcome to MSW but I don't speak french. Glad to have you aboard.
Here's already a question?
The first pair (piece # 4) exceeds the keel about 5 mm, do I have to sand it to be equal? If I climb it, the bridge will be higher in this place!
What is the best support for the keel and ensure that couples are in their right?
:sign:
Thank you all, I will try to translate my comments and questions, if there are manufacturers who are doing it now or we have already done it, I am open to any comment and stuff that could help me
Here is the support kit for the construction and I will place my keel to be able to align the pairs, to my question of the torque # 4, I put the laser and it confirms to me that it must be lowered to the maximum and sand it later if necessary, then sand the brown cut of the laser
Thanks
I suggest that if you haven't done it, open a build log for this model in the kit area.  It is the best way to meet others and get help when needed.
  • 9 months later...
  • 4 months later...
