13 hours ago, Rick310 said:
Great work Rob!!
Rick
Thanks Rick.  I keep having to decide how much detail I want to add...and at this scale too much can be very distracting....and not enough ...things begin to look toy like.
Rob
Current build:
Finished build:
Current build(On hold):
12 hours ago, druxey said:
Impressive at that scale!
Thanks Druxey.......Searching for good scale door knobs, I had to rely upon my imaginative skills and ingenuity.  I broke open a very old(unusable rally) shotgun shell used for bird hunting, and I sifted through the shot and found the right size, that would work as door knobs.....and VIOLA.
Rob
Current build:
Finished build:
10 minutes ago, Luis Felipe said:
Hi, congratulations, at the scale that you are working achieve this level of realism and detail is a major achievement. Looking fwd, are the hull plans ready?
HI Luis.  Thanks...Vlad is waiting for the laser cutting to be completed...before he sends me my copy of the hull bulkheads and keel.
I'm hopeful, that they will arrive before the end of next month...hopefully sooner.
Rob
Current build:
Finished build:
I made a new bell and housing.
Rob
Current build:
Finished build:
Didn’t like the look…..too modern looking.
Edited by rwiederrich
Current build:
Finished build:
Here is the first one I built.
Didn’t like it either.
Rob
Current build:
Finished build:
Finally I built the final one that will be mounted after it dries.
Rob
Current build:
Finished build:
Finished the compass ….bell assembly.
Rob
Current build:
Finished build:
Nice detailing Rob, a nice assembly of 'assemblages' mate, she certainly will have a lot of nicely detailed deck furniture.
cheers
Pat
Thanks Pat.  I’m hoping to make all the deck furniture before I get the hull bulkheads from Vlad.
Next will be the helm tiller box and wheel.
Rob
Current build:
Finished build:
4 hours ago, Glen McGuire said:
Fine work, Rob.  As usual!  That bell is particularly well done.
Thanks Glen.   I try.
Now onto the helm tiller box and wheel.
Rob
Current build:
Finished build:
Rob
  It's like you're making your own 'ship kit' ...
Johnny …….we literally are.  Rich typically makes deck and profile drawings of our projects….based off of Duncan McLean’s eyewitness accounts.    The hull plans can be mass produced if one were desirous.
Rob
Current build:
Finished build:
Making nice progress Rob!
Rick
Thanks Rick….I appreciate that.
Rob
Current build:
Finished build:
Started on the helm steering box.  First coat of paint....still needs sanding and another coat....plus the addition of the wheel.
Rob
Current build:
Finished build:
I finished the helm by adding the wheel.
Rob
Current build:
Finished build:
I’m beginning to build the first of many gin blocks.    Here are some pics of construction. They are less then 1/8” wide.  Tony boogers.
Coper soldered and with metal sheeves.
Rob
Current build:
Finished build:
I blackened the gin block.
That is 42LPI chain.
Rob
Current build:
Finished build:
I began soldering the next one.  Final grinding is next.
Rob
Current build:
Finished build:
1 hour ago, uscharin said:
Once blackened they look very, very convincing.  So tiny.  Great work, and how many do you need to make?
About 15 or so.  🤪. Thanks
Rob
Current build:
Finished build:
Finished up 5 more gin blocks.   That makes six.   Still need 10 or so more. Painted them and still need to clean them up and finish them off.
It only takes about 35 minutes a piece.
A little hammering, 3 cuts,  one soldering of the eyelet, micro internal grinding, place the sheeve and TaDa……
Rob
Current build:
Finished build:
1 hour ago, Dr PR said:
Rob,
Very nice work!
For me making a bunch of tiny complicated parts like this is like banging my head against the wall - because it is so nice when it stops.
I definitely have to work over my towel in my desk drawer to keep from losing them, when they eventually slip from my fingers.
 Thanks for looking in.
Rob
Current build:
Finished build:
1 hour ago, Rick310 said:
Rob, those gin blocks are especially well done!  Mine almost killed me!   Beautiful job on the helm as well!!
Rick
Thanks Rick.   Tomorrow I’ll show exactly how I make one.   It’s quite easy actually.
The real trick is knowing how to force the perspective of its function.
You see, for a chain to properly fit in and around the sheeve, the body frame of the block must be large enough.  However, if the sheeve is too large the chain binds between the sheeve and the frame of the block
To prevent this from happening and to keep the block frame within the desired scale of 1/8”, you have to undersize the sheeve. The chain I use is the smallest available at 42LPI  and it still needs room to move within the block.
A true scale gin block is probably less then 3/32”. in this scale of 1/96.  No one can make them that small and not go mad.
Bluejacket doesn’t even use iron stropped gin blocks on their  Red Jacket clipper model.  Just large single blocks without a truck strong back tied to yard bands.  So I have a ways to go.
I’d like to see your gin blocks.
Rob
Current build:
Finished build:
