Started working on the metal sheet blocks.  I’m following the same method I used for Glory of the Seas.    I used metal record tabs. Bent them in half to form the block body.  Marked and cut them.   But first I drilled all the mounting holes on the mill.
Here are some pics of the process.  Short but sweet.
Next, I’ll mount them on the yards when I get to that point and paint the entire thing then.
Each block is 1/8” wide.
Rob
Current build:
Finished build:
Current build(On hold):
13 hours ago, rwiederrich said:
I’m back from the best getaway ever in Sedona Arizona.
Rob,
These are really impressive scenes. They all look like lovely picture postcards. Whoever took these photos has a real eye for gorgeous settings. Thanks for sharing these. I hope you have a lot more to come.
@rwiederrich,
My 2nd Reconstructing Glory of the Seas article for the Nautical Research Journal draft was submitted on-time to meet their Winter 2025 issue. No guarantee it will appear in that one yet. By now you should have received both my final and then finished drafts. It was too late for @druxey to give it an editorial review. However, I learned how to use the internal Microsoft Word editor which gave me a 96%. Mike was nice enough to review my final draft and I made a handful of source corrections. One fascinating correction was the date of the San Francisco wharf scene is actually 1880 not 1877. Other than an honorable mention, @Vladimir_Wairoa had to be left out for a third promised installment. I have until December 31st this year to submit it and I fully intend to meet it. Vladimir's build is a fascinating journey of construction, tear-down and reconstruction. In the end he, as a relative novice to rigging a clipper ship, managed to create the most beautiful 1869 Glory of the Seas replica. Meanwhile, I included in the second article that Mike has declared your 1877 miniature to be the most accurate Glory of the Seas replica ever produced.
4 hours ago, ClipperFan said:
Rob,
I took all those images bro.   From hikes we took.
Thanks for the fine comments Rich.  We had a blast.
Rob
Current build:
Finished build:
@rwiederrich,
How fun.   I can’t wait to see it in print in the NRJ.  Very impressive work indeed
Rob
Current build:
Finished build:
Rob
Rob,
Check your emails. I sent both Microsoft Word document Google links to you. It's a long but I truly hope fascinating read. Without exaggeration, it's probably the most detailed recount of your systematic, highly organized rigging process ever written. There's tons of gorgeous photos accompanying it.
41 minutes ago, ClipperFan said:
Rob,
Did you include images of the finished model on display?  I didn’t see any. Cept with Mike and me.
Rob
Current build:
Finished build:
@Rob, Rich,
voice from distance or Hades . well covid is over thankfully.  ...Folks I have finally some positive update (at least for Rob), as per info I am to receive  cut stag hound molds by start of next week. it will be poplar layered wood by 5 mm thickness.  so I am immediately sending both to Rob. I suppose it is ok. I hope waiting was worth for you as soon as you received it. His workmanship is good standard so all pieces should match nicely. I cant wait.
Vlad.
@Rich,
I went "briefly" so far thru your Article. My goodness how many pages ! :)) would it be published as standalone book? :)  wonderful stuff indeed.
Edited by Vladimir_Wairoa
add
On 9/13/2024 at 4:47 PM, rwiederrich said:
HI Luis.  Thanks...Vlad is waiting for the laser cutting to be completed...before he sends me my copy of the hull bulkheads and keel.
I'm hopeful, that they will arrive before the end of next month...hopefully sooner.
Rob
Fingers crossed they will ;)
43 minutes ago, Vladimir_Wairoa said:
@Rob, Rich,
Vlad.
@Rich,
Oh boy.    Thanks Vlad.   I’m so glad you are over the Covid.
I’ve been on holiday(Anniversary) for the last 10 days …… Plus , I’ve been keeping busy with lots of mundane tasks.
It will be exciting to begin on the hull soon.
Again…. Thank you so much.   Any book yet?
Rob
Current build:
Finished build:
42 minutes ago, Vladimir_Wairoa said:
These were one of thoughest things to make for me - in 1:72. ! smaller ? no thanks :)) wow
Yeah …..tell me about it.  Mine are 1/8”.  🤪
Rob
Current build:
Finished build:
Rob
@Vladimir_Wairoa
Thank God you're recovered from the damn Covid. That is great news!! For the record, I only sent my 3rd draft to you, in hopes of collaborating about your timeline for building, tearing down and rebuilding efforts. The delay in getting the 2nd article submitted earlier was in large part my journey of discovery of your amazing build. Once I realized how complex alone your construction process was, it became clear there has to be a 3rd article devoted exclusively to your replica. The 2nd article is a very long one but it just felt right to cover Rob's fascinating rigging process in depth. By the way Vlad, even though I have no immediate plans to build one, I still want to acquire a set of the Stag Hound bulkheads just like I did for Glory of the Seas. I don't want to miss out on having a set for Stag Hound. Just let me know the costs and I can pay you via Paypal or even mail you a check.
@rwiederrich
with the tight timeline of a handful of days I didn't have enough time to go through and select more of your finished images.
Rich I just took about Two hours to finish reading your article. Wow!   So much information and discovery.  Great read.
Thanks for the many kudos and also referencing Vlad’s wonderful build as well.
A third article would do his build justice…… Good idea.
 It would be something if through this article a  museum would materialize.     😏
Thanks again my friend.  Great job.
Rob
Current build:
Finished build:
Rob
@rwiederrich
I did say it was long. Still, when Mike read it the only changes he recommended were a few reference corrections. I have a very solid 3rd installment devoted exclusively to Vladimir's build and I'm determined to submit that before the Jan 1st 2025 deadline. Next there's our Stag Hound project which I want to get a jump on. Next year is the 175th Anniversary of her December 7th 1850 launch. Donald McKay's incredible contribution to Boston's amazing fleet of California Clippers deserves to be recognized.
Congrats on your Anniversary Rob, and some great photographs there.  I enjoy landscape photography and really enjoy these.  It difficult to capture what the 'eye' sees and appreciate you didn't overdo them with HDR and oversaturated colour.
cheers
Pat
Two hours because I was reading it on my phone …………with a magnifying headset….🙄🤪👍
Current build:
Finished build:
@rwiederrich
And here I thought you were just relishing my erudite writing. Instead you were torturing your overworked eyes all along.
11 hours ago, ClipperFan said:
@rwiederrich
:dancetl6:
Current build:
Finished build:
ta daaaa
im now holding in my hands our stag hound coutouts. 2 sets.
sending it fastest/but relatively cheap way to US tomorrow.
Rob has all  the details.
no need to reimburse. this is courtesy of  friendship/ and your generosity by sending me books etc... although no real friendship can be bought by money , anyway ;)
Vladimir
add
6 hours ago, Vladimir_Wairoa said:
ta daaaa
Vladimir
So very much appreciated Vlad.  Your work can not be praised any higher....     And in 3~4 weeks, they will arrive and I can begin the hull......I'm so excited.
Rob
Current build:
Finished build:
Rob
@rwiederrich @Vladimir_Wairoa that's exciting news. I am so jazzed to see Rob start his "warp-speed" build. Meanwhile, even if you're not planning an immediate build, Vlad did you make a 1:72nd scale set for yourself? Rob, I hope the 2nd set is for me. I'm ready to contribute my fair share to get a copy. Just let me know who I owe what. Knowing that next year (just a few months away now) is the 175th Anniversary of the launch of Stag Hound, I can't think of a better tribute than to see her realized by Rob. Even if he just gets her hull completed. I just love the way Donald's son Cornelius McKay phrased it "The Pioneer craft of the California Clipper Fleet." Her successful career, although sadly way too brief, did indeed lead to a fleet of some of the most spectacular, record breaking clippers the world has ever seen.
Edited by ClipperFan
additional information
Vlad is sending your copy to me (from what I understand), and I'll pop it off to you.
As you are probably aware...McKay launched his ships with simple stub masts....so if I can pull off just finishing her hull by years end...I'll have launched her as was the prototype.  On her 175 Anniversary.  We'll just have to see.  No one knows the future.:default_wallbash:.
Rob
Current build:
Finished build:
Rob
Rob,
Just do your thing at your own pace. Whatever level of completion you achieve is whatever it is. I meant no pressure to push you, only my enthusiasm for the coincidence that our project just somehow happens to coincide with the Anniversary of the launch of a spectacular career for a man who now remains largely forgotten.
The anniversary is a great reason to make her hull completion a goal.
Current build:
Finished build:
Still waiting on the bulkheads to arrive.  Any day now friends....
Rob
Current build:
Finished build:
Looky. What I got today.
Rob
Current build:
Finished build:
Test fit the keel.  Nice clean aligned fit.
Rob
Current build:
Finished build:
Gluing the two keel pieces together.   I won't fiddle with this till it is full dry.
I’ll separate the bulkheads and put them in order.   She a lot smaller then Glory of the Seas for sure.
Rob
Current build:
Finished build:
