20 hours ago, MikkiC said:
I want to smooth out that awkward looking bungle so that the transom doesn't hang below its supports thus creating a nice, cleaner line.
I greet you. The line is easy to maintain. I did the same thing on my boat. Fingers crossed for progress..🙂
San Martin kit...
Edited by Ondras71
Ondras.
Done : President - https://www.modelforum.cz/viewtopic.php?f=177&t=90230
Under construction : Roter Lowe - https://www.modelforum.cz/viewtopic.php?f=177&t=114576
Member of the organizing clubhttps://wchs-c-2023.klom-admiral.cz/en
@Ondras71 I find this kit rather awkward, different from other galleons from shape to construction. My kit was only a partial, so aside from keel, bulkheads, and few odds and ends, I basically have to build most fittings.
I like what you've done with the stern doors and the painted decorations. The colours look great.
Mikki
"You're gonna need a bigger boat."
Working on: Dusek's San Martin
Completed: Good ol' first ship build- Constructo's Albatross; Mamoli's HMS Bounty; Mamoli's Golden Hinde; Amati's Drakkar; Occre's Revenge; Artesania Latina's San Fran
Still working on 1st layer of hull. I know. It's been a hot minute, but work, life, end of summer outdoor stuff, etc. It's almost completed and ready to sand. I haven't been able to find wood for 2nd layer yet. Everyone in U.S. is out of the size I need. I plan on working on deck next. Need to cut away supports, plank decks and inside of bulwarks, and put supports in before 2nd layer of plank. Oh, and I have to deal with the keel.
Mikki
Witch Kind of wood you search.
Aktuell Build:
Ranger - Corel
Victory - Corel
Endet-Build:
San Martin - Occre
Cala Esmeralda - Occre
Lady Nelson-Victory-Modelle
Gorch Fock-Graupner 1985
On Stock :
Yacht Gretel - Mamoli
Oseberg - Korabel
Naval Models - Paranzella
I haven't made much progress as I've been busy with other things. I can't get used to this "adulting." I've been trying for a few decades, but I haven't progressed all that much. 😁
The first layer of the hull is finally complete, sanded, and patiently waiting the next layer. I chose 1 x 5 x 500mm walnut. Why? Because I don't have the means to mill my own lumber (yet 🤞). I bought it from Model Expo. The quality looks good.
I finally got the deck glued in. I used 0.5 x 5 limewood and stained it golden oak. I didn't score any of it with a pencil. This result just happened. I'm not convinced about the colour, but I'll know better once I see some fittings sitting on it. I'm working on the inside a bit so I can put in supports. I will definitely crush the sides otherwise.
Onward.....
Mikki
Slowly but surely I'm moving along. I'm working on deck trim so I can install supports. I changed the deck colour from golden oak to red oak. I prefer darker colours. I should've gone with red oak at first. That change took a bit of sanding.
Mikki
On 10/10/2024 at 6:44 PM, Louie da fly said:
Looking very nice, Mikki. I hadn't noticed this build before. I'll pull up a chair if I may.
Steven
Of course. I'm honoured. And any advice you have is gladly taken.
Mikki
Well I'm still putting in supports. Need to finish one side so I can make the other side level. While I'm waiting for glue to dry, I decided to work on those toothpick doors and build a few ladder rather than watch the glue dry. 😁
Mikki
Rather than post a bunch of pics, I thought this would be easier.
I made some templates from a different model and kept them. I used scrap wood for rails and the ends of the 0.5 x 4mm that was left from inside bulwarks for the rungs.
For the door trim: I traced door onto a pice of scrap, cut it out, soaked some 1 x 3 walnut and let it sit in the form for a bit. I glued it on and used nails to hold it.
Not sure what I'm going to do about door hardware yet.
On the door pic, I didn't decide to put a base on trim until afterwards. If it doesn't clean up well, I'll try something different on the next one
Mikki
Finally starting to put walnut on the hull! Still have to attach the stern post....of which I think I've made 3? Now to find the correct one..... I still have some filing to do, but I tend to cut around the cannon ports a little larger and file to size.
Mikki
And as this is in the line of many: I've hit a small obstacle. The area that gets the painted decorations should be 15mm, but I somehow ended up at 13. I could have probably left it, but then I would have to sacrifice those 2mm from a strake. It would not look right, so.....I built it to where it should be, added another 1st layer of planking behind it, tore out the bulwark supports (that was not fun), cleaned it up, and put in new supports. Yes, it's a setback of my own making, but at least it was fixable. I still have some filing and sanding to do. Onward
Mikki
Little by little she starts to come together. 'Tis a slow go to get everything lined up and fit.
Mikki
A little more progress. Next pic I take, I'll take from bow.
Mikki
One more to the wale, then 2 more, then another wale. After that, I'm gonna work on the other side then rinse and repeat.
Mikki
And....I have used the veneers (0.5mm) for 2nd layer of planking on previous builds, but I chose the 1mm for this one. So far I prefer the 1mm. Yeah I pre-bend it, but it's nice to work with. It doesn't splinter at all, and it sands pretty well.
Mikki
That’s what I always do, plenty of scope to sand out errors. Your second layers are coming along very nicely.
Edited by Slowhand
Misspell
Slowhand,
Current build Apostle Felipe - OcCre
Polacca scratch build from Amati plan - on hold
San Martin - OcCre
HMS Resolution - Corel
Half Moon - Corel
Dragon keel boat - Billings
Some progress: both sides planked to the lowest wale. Now it's gonna get a little hairy because she's got a big belly on her. I decided to start framing gunports. I keep forgetting to do this earlier in the build. I don't know why.
Mikki
Oh I'm nearing the end here. She needs hiccups cured then a good sanding.
Mikki
Happy New Year to all! I wish you peace, happiness, and smooth sailing.
Mikki
Well the hull is at least planked. It needs a good sanding (outdoors), but since it's about 0 degrees (- 18 C I think ) here, it will have to wait. I'll have to work in other things until a thaw graces the region.
I'm undecided how to finish the hull as in stain, clear coat, etc. I'm happy to take suggestions. Some days I like the colour variations in the walnut and other days not so much.
Mikki
Looks great
-18 🥶.
Best to wait for warmer days
The recurring question, clear coat, stain, paint??
Hide a nicely planked hull, or not
This will be your own difficult choice 😉
Thanks Patrick.
As for painting a hull: never gonna happen unless it's for decorations. 😁
Mikki
Your planking job looks first rate. As far as what to finish it with I can’t help you but I do understand your sentiment as I felt the same way when I finished the walnut on my catboat. I often look at it and think I’ll paint a waterline and some colour below it, and maybe I will someday. Anyway your beautiful ship inspires me to get at my kit.
Ian
