These are two models of the Swedish Visby class corvette. I bought this design but had to make some modifications to print it in 1/700. Even at first attempt they printed great. Will enchance the model with PE and bit of work. I think with proper paint job will look nice on a sea base display
IMG_20240825_213842.thumb.jpg.d593b8da930abf16a0cf9de34f857b82.jpgcapture-18.jpg.53bcf1f7f32687798f4394d61a9466b5.jpgK32-HSwMS-Helsingborg-02.thumb.jpg.81b527c6196e83f30ecadd7088a720b0.jpg
Very nice printing Mike,
I also have one of the Corvettes under printing.... mine is not 1/700 scale. Mine is larger and will be R/C
Respectfully
Visby is the one with the single antenna on top whileH ärnösand is the other with the upgraded radar mast.
After a coating of neutral grey it was to start masking for spraying the darker grey. The side grills were made with carrier fishnet cut in oval shape and glued on a black area for maximum contrast. It was the closest thing to the real that I could think of
The base.
Sided were primed and painted in the same camouflage scene.
Styrofoam with heavy gel on top. I used a tooth pick making parallel lines to form waves. Then applied few gesso layers to smoothen it a bit. Around where boats will be placed, I spread with my finger some gel to make a smooth surface. Then sprayed blue. Then Tamiya clear blue. Then some white preshading. Ready for boat instalments and final work.
IMG_20240928_121453.thumb.jpg.502fbe2b9468c1911d895e212a5114dd.jpgIMG_20240928_152610.thumb.jpg.49272dab9aa20ee5dbbc73cec6671a11.jpgIMG_20240928_155110.thumb.jpg.e54d4180dfc2fe4c58872a368d897f09.jpgIMG_20240928_155041.thumb.jpg.b0e8297c8fa1547020bd81cbf121992e.jpg
I procced in the same way as usual. Only difference this time I extended the use of silicone to all white areas to avoid the "dry" looking of my previous themes. The whole thing was covered with 2 ingredient varnish like these used on automobile industry.
IMG_20240928_155041.thumb.jpg.993b6e545eef1f1c1e7a176962f528b6.jpgIMG_20240928_155110.thumb.jpg.d9f9c0026baac3a6bfd04991305ba3ee.jpgIMG_20240929_134944.thumb.jpg.8c379ae3092205aeccbc7be244bcf14c.jpg
IMG_20240929_135009.thumb.jpg.0ef7b6fb3e125536882bfcd2fa667c1b.jpgIMG_20240929_134956.thumb.jpg.8dbfea9cfa2bd4abfab19306dae3ee7b.jpg
Then i decided to add smoke as a final touch
IMG_20240929_143537.thumb.jpg.65c76cbca562f38d5ca80d91df46970a.jpgIMG_20240929_143527.thumb.jpg.a6b9301b18f71bedc0dbe3b980cd0a02.jpgIMG_20240929_143617.thumb.jpg.a60811d6b47a3d77aebdf1dfde9eca41.jpg
Small built but with noticeable effect
Edited by mikegr
