All I can say is IMPRESSIVE!
Jon
Hello everyone
I have decided to attempt to make the cannon for this build myself(emphasis on attempt, this is very much theoretical at this point.
I wanted to go with the configuration mentioned in "close up" by Tyrone G. Martin which was kindly pointed out to me by @Marcus.K.. The cannon found on the gun deck of the Constitution in 1797 appear to have been 30 x 24 pounders with a barrel length of 8ft. Apparently these were 1ft shorter than the standard length for this calibre. The cannon were made by Hope forge and an original pair can be seen outside the buildings of Savannah college of art and design
Below is the basic drawing I used as reference along with excellent measurements provided by Marcus, I will not publish his drawing here until I get his permission but it was a real help in making this first version.
I began by cutting square stock of 10mm x 10mm from a leftover stump and turned it down to 8mm on the lathe. I then marked out the relevant lines dividing the sections and cut the tapers first and then refined by hand. This process was by no means perfect. I am using a unimat that a friend recently gave me, i have no experience on a lathe and my lathe belt broke. In the process I broke off the cascabel and had to remake it separately. I also had a fair amount of trouble creating a finish that was acceptable but I can live with this as it will be cast in resin anyway.
This cannon still needs its cross braces, eagle emblem and fuse protrusion but if anyone has any views on how it can be improved before I take those steps please let me know. this is my first attempt so I can imagine I will get away without a remake. I do feel the reinforcement protrusions may be a little to pronounced but I cant decide if this will be a pro or a con once painted black.
Haiko
Considering you said you had no experience with a lathe, was working with a piece of equipment you knew basically nothing about, and it broke, you managed to produce a gun barrel that looks spot on to your drawing as well as the one seen outside the buildings of Savannah College of Art and Design. Well done!!! Knowing nothing about casting, I look forward as to how you create a mold so that you can cast numerous copies of the barrel.
Jon
Excellent work, Haiko.
But I have to state: I did find those Savannah guns only due to @Force9´s research.
HERE he gave his hints - I just followed his steps 😄
Concerning the short length of those early 24 pounder guns we know from James Fenimore Cooper´s 1853 "History of the United States Navy" about the events of the July 1812 "Great Chase one of the negative effects of those very short barrels:
Quote
 At  seven  minutes  before  two,  the  Belvidera, then  the  nearest  ship,  began  to  fire  with  her  bow  guns,  and  the  Constitution opened  with  her  stern  chasers.  On  board  the  latter  ship, however,  it  was  soon  found  to  be  dangerous  to  use  the  main-deck guns,  the  transoms  having  so  much  rake,  the  window  being  so  high, and  the  guns  so  short,  that  every  explosion  lifted  the  upper  deck,  and threatened  to  blowout  the  stern  frame.  Perceiving,  moreover,  that his  shot  did  little  or  no  execution.  Captain  Hull  ordered  the  firing  to
cease  at  half  past  2. stern  frame,  in  order  to make  room.
Its clear: the combination of a big rake, high windows and short gun barrels would allow the air pressure at the gun when fired to affect the ceiling of the after cabin. Another effect reported in Tyrone Martins "a most fortunate ship" was that the gun smoke was filling the gun deck with thick haze that it made further operations with guns very tricky.
Edited by Marcus.K.
"Pirate Sam, Pirate Sam. BIIIIIG deal!" Captain Hareblower aka Bugs Bunny
Jon
Good Morning Jon
Thank you for your really positive feedback. I am really enjoying the process of learning what to do and not do(it turns out that patience is a virtue)
I have started tinkering with the casting process and I can tell you so far I have established that the path to successful casting is narrow and full of twists and turn. I really hope I can get it figured out, I think it has potential to really help produce high quality cheap components.
I will report back as soon as I have it figured out...hopefully
Cheers
Haiko
Thanks for this info Marcus
Its crazy to think that this little difference in barrel length(1foot?) created such significant issues.
one thing which does however confuse me is this(extracted from Tyrone Martins Close up)....
I read this as to say that the 24 pounders had already been replaced by 1808, hopefully resolving the very short barrel issue. any ideas?
Cheers
Haiko
Oh, that's interesting. 😲 I did not notice this lines. I need to check my notes !! 🤔 Seems I did Fall over the same step, I so often complain about at others! The bias of interpretation without real checks.. Just because an idea fits to the total picture does not necessarily mean it WAS like that! 🫣
But: it won't affect your casting process and my intended reconstruction as both point on well before 1807 ... puh! 🤪
Edited by Marcus.K.
Hello Again
This post is a strange combination of attention to detail and complete abandonment thereof.
I Realised that the next step I needed to take would be to establish heights of the gun ports for the gun deck so that I could begin framing them. This required creation of cannon(see previous post) and carriages. The cannon are currently on hold as I am waiting for resin/putty to try and duplicate my sample cannon. So I began on the carriages with a specific focus on those dimensions which would influence the way in which the cannon projected from the gun ports. I decided to use this as yet another exercise in practice for the gun carriages which will ultimately be visible on the spar deck. This process has taught me a lot and I think the results of the visible carriages will be far better.
This process was surprisingly simple once I had made a decision on design. There seems to be fairly little information out there on exactly how these 24 bounder carriages looked in 1797 so I settled for a design from the 1768 book “A treatise of Artillery” by John Muller(pages 95,96 and 164). I was pointed to this by a masters thesis on the subject of gun carriages by Katrina Bunyard which I have attached to this post. Please note her summary of the document by muller(page 37) has some minor mistakes which is why I ended up referring to the original . It is worth noting that the Muller guideline has some flaws and there was some variation as can be expected.
I have attached a spreadsheet which can be used to calculate cannon carriage sizes according to the Muller measurements if anyone is interested. I also added a Imperial to metric converter to assist with the calculations. (only edit the red cells if you ever make use of this or the formulae will disappear.)
Using the dimensions for the short barrel 24 pounder gun I calculated the dimensions for this gun and assembled accordingly. I chose to leave off the truck and simply calculate the height of the carriage as if the trucks were there. I also gave it a solid base as this would certainly not be visible and I omitted the curve at the lower part of the side plates. I also made a mistake with the forward transom and put it too far forward(it is meant to be directly above the forward axletree. I only realised this once I had assembled all 30 carriages and decided to draw a line on the madness and left it as is. ..i would like to add that basswood is appalling to work with at this scale as it is continuously creating fluff which has to be addressed. I did this with a combination of sandpaper and passing the carriages over a candle flame to burn off these fibers.
I have yet again failed to create a proper database of photos on this but I began by cutting a series of stock from the basswood supplied in the kit. This consisted of the following
30 bases – 12.7mm x 2.5mm flat stock – cut 20mm long
30 front trucks – 4.15mm x 4.15mm square stock – cut 11mm long
30 rear trucks – 3.5mm x 3.5mm square stock – cut 11mm long
60 Side piece plank 1 – 1.5mm x 3mm flat stock – cut 20mm long
60 Side piece plank 2 – 1 mm x 2.4mm flat stock – cut 18mm long
60 Side piece plank 3 – 1 mm x 2.4mm flat stock – cut 16mm long
60 Side piece plank 4 – 1 mm x 2.4mm flat stock – cut 14mm long
60 Side piece plank 5 – 1 mm x 2.4mm flat stock – cut 12mm long
30 Transom pieces – 2mm x 5.9mm – cut 5 mm long
Beginning with the base I cut a template with the correct width for the front and rear of the carriage and transferred this to the base piece.
 I then placed the first 2 side pieces which cover the whole length of the base by aligning them with the marks I had made using the template and installed the transom.
 Once this glue has set I marked the correct height of the transom and sanded each one back to match this measurement.
Next was to sand back the rear of the carriage and square it off neatly until it was just slightly over the final length(19.5mm)
I then stacked the side pieces from largest to smallest stepping the side pieces correctly at intervals of at the rear of the carriage and allowed the front edges to hang over for future squaring off
I then installed the front and rear trucks
I then sanded the front face to bring the carriage back to final length and neaten off the front face(19mm) and sanded the sides to bring the side plates down to 1.82mm(in theory) and take away the excess material from the base.
Next was to make the recesses for the trunnions and shape them out with a round file.
20250301_162307.thumb.jpg.23ea1c734aceb7c049a50cc080ad8a49.jpg20250304_201929.thumb.jpg.44f593323d95aaeeffb9c2e8b02137fd.jpg
I then burnt all the fibres off with a candle and spraypainted them with a black basecoat. At this point I realised that my trunnion recesses were very poorly aligned and redid the upper plank of the carriage to create a slightly better result.
The last step will be to paint the carriages.
I am torn between the options of Spanish brown(a far more brownish red) and Lead red. I realise this will barely be visible but I would like to start my search for the correct tone in the right direction .
All the research I have done indicates to me that the most likely colour was indeed a red colour of sorts but the shade is the issue. Tyron Martin refers simply to “Red” in his discussions on the matter(at least that which I can find) and there is some reference to Spanish  brown in the ships manifests and my understanding is that budget was key in these things and Spanish brown was cheap. There does however seem to be contemporary evidence in models and paintings that a brighter red was used and I assume the constitution restoration was done with historical accuracy in mind.
In my mind have narrowed it down to the Spanish brown shown of this George Washington era building.....
and the red of the carriages as shown on the constitution today.
If anyone has any suggestions on what colour or shade might be most appropriate please let me know. I am sort of thinking I will go for a Red with a brown undertone but any suggestions would be swell!
As always criticism and feedback is most welcome
Cheers
TBE
Cannon Carriage Calculator.xlsx
Excellent research on the gun carriages to obtain authenticity for your model.
Quote
It is for the reasons you encountered in the your quote above that use the hardwood, boxwood, for any wood component that requires precise edges. It may be a bit more expensive and not as readily available in hobby shops (but certainty available on-line), but is well worth it. If you have read my log closely, I indicated when and why I switched woods. Typically, if the wood is to be unpainted, stained, or I need those sharp edges even if painted, I'll use boxwood. In my Rattlesnake model, I used different color woods in lieu of paint (except for black. Ebony was called for but I used paint for reasons of availability, health (saw dust not healthy), and resistance to bending).
Jon
Edited by JSGerson
Hey TBE ,
great progress! I fully agree to your point of view: nobody will really see them - maybe with the exception of those close to the waist of the ship were one maybe may see something below in the main hatch .. Hard to tell. If I look at my old 1/96 Revell-model one really has to try hard to see the guns below that boats stored there. Of course your scale is a bit wider .. but ..
When I do research for Old Ironsides my very first view is into Tyrone Martins "Close up" - and today I finally found some time to do so for this questions:
The only mentioning of something with color are mentioned for the very first years like this:
  • 13 Oct. 1799 -- "blackening the guns" .. Ships log,
  • Jun 1802   -- Gun carriage trucks had iron rims ... Receipt to Jon Taley, 13 Jun 1802, Samuel Brown Papers
  • 14 Sep 1803 -- "..scraping the gun trucks/axlestress and Black leading them..." Ships log
  • Jan 1804 -- painting gun carriage ring botls and leading blocks .. ships log
and for
  • Oct. 1804 -- "...repainting Quarterdeck Guns, they are now painted in light yellow in order to correspond with the patinwork of the quarterdeck.." ... Naval Documents relating to Barbary Wars
Also later there is often mentioned ".. scrap´d the gun carriages and put black lead on them " .. or ".. blacking .. main deck guns" .. or "balking long guns" .. "blacking carronades" ..
But - as far as I understand this - this may not refer to the color of the wooden carriages - than to the barrel itself. And the "blackening with black lead" may refer to graphite - and in that case was not used to protect the surface but to make sure axcle and the seat of the trunnions.
Black lead may refer to something like graphite .. as black lead - plumpum nigrum - was the name of that:
In Samuel Frederick Gray, A Supplement to the Pharmacopoeia (1821) black lead is described as Plumbum Nigrum - which seems to be the former name of graphite - although the text specifies is at iron and charcoal..
So I guess "black" is not the right color - and the only color mentioned in Martin´s list is the light yellow - to match the 1804 quarterdeck.
I did not find any other hint for colors of the carriage.
But: there are lists of colors delivered to the ship:
  • Aug 1803 -- Paint pigments in ship's stores included 305# black, 3 cwt white lead, 3 cwt yellow, 50# green ("verdigris"), and 28# red ("vermilion"). [Receipt for John Osborn, 1 Aug 1803, Samuel Brown Papers, MHS.]
and later:
  • 11 Jan 1804 -- Received 15 kegs of yellow ochre, 2 of red paint, 7 small ones of black paint, and 50 gallons of black varnish. [Ship's log, DNA.]
the August 1803 list indicates that the ship got "3 cwt yellow". A cwt is an old unit - C for the latin word "centrum" for 100. "hundredweight" is in the US the equivalent to 100 pounds. If the description would be meant in british units (I am not sure if the young US did already used their specific units - I remember some very interesting articles about this in Wikipedia!) .. well, if it were british, its even more: 1 cwt in Britain would be 112 lbs .
For us that means: the ship had at least 300 lbs yellow, and 28 pounds of red ("vermilion" - which was a bright and very expensive red - not to be mixed with the cheap "swedish red" which is also known as "Red Iron Oxide".
The Jan 1804 list talks about 15 kegs of yellow ochre and only 2 of red paint. A "keg" seems to be a barrel of about 30 - 40 pound ..15 kegs would then be about 450 - 600 pounds of yellow ochre. While red is again in a very small amount available. 2 kegs = 30 - 80 pound.
BUT: in Martins Oct. 1804 quote we learn that from NOW on the carriages match the quarterdeck in being yellow..
So if we look for those colors - and take that 2 days delivery as an indicator of the likely use of paint for carriages, we might notice:
1. vermillion red is not very likely
2. yellow, or ochre yellow is possible - and was used at least in 1804 - but obvously something else was common before Oct. 1804.
3. green ("verdigris") was the chosen color in 1812 for the features on spar deck - as we can see in the Isaac Hull model.
4. black was available in suffcient manner
5. red - not vermillion - but maybe such a spanish brown  - which the following paintings also would "allow" ...
1812Stephen_DecaturonUSSUnited-StatesorConstitution-Alonzo_Chappel1863.thumb.jpg.3201446f2626ff14557534af4bf9e12d.jpg
This painting by Alonzo Chapelle (done in 1862) shows Stephan Decture - most likely on board of USS United States - although the rounded rail in the background seems to hint on USS Constitution - still the shape does not fit. The gun carriage seems to be black ?
I looked for others - but the color is always hard to tell:
Isaac Hull patinted in 1815 for his 1812 victory .. is that a black capstan?
Baindbridge seems to be beside a yellow, ochre or brownish carronade carriage ..
And of course: the painters did most likely not really care for the PERFECT color of those details. They may just been "typical" paintings for them in those days.
There still was no "standard" - and most likely the captains may have used whatever was available and cheap.
My personal favorite today: black, [Edit with a day of reflection:] changed my mind: a red color seems to be likely - as red ochre was a typical choice - and what´s more interesting: even when Old Irionsides had her greenish bulwarks and deck details: her gun carriages seem to have been red [end edit]
or.. if you like - this brownish spanish "red" - at least either a very dark faint color - or an ochre or yellow color - which most likely also is a bit obscure and not very bright and clear. Your spanish brown is a perfect match in this regard .. but I fear: right now we just can guess!
Edited by Marcus.K.
I changed my mind: after checking on the Isaac Hull model of 1812 - in which the deck components were done in this special green already - the carriages seem still to be in red. A very dark, dull and faint red (maybe due to the age of that color).. but clearly a red.
Still .. its all just guessing.. right?
I was checking on other forums - the only discussion about red I found here - click me
It is for the reasons you encountered in the your quote above that use the hardwood, boxwood, for any wood component that requires precise edges. It may be a bit more expensive and not as readily available in hobby shops (but certainty available on-line), but is well worth it. If you have read my log closely, I indicated when and why I switched woods. Typically, if the wood is to be unpainted, stained, or I need those sharp edges even if painted, I'll use boxwood. In my Rattlesnake model, I used different color woods in lieu of paint (except for black. Ebony was called for but did I used paint for reasons of availability, health (saw dust not healthy), and resistance to bending).
Jon
Hi Jon
Thank you for your feedback and it is good to know I am not alone in my struggles. I Will take a close look at your rattlesnake and where you chose to use what woods. I would like to try and get the build done with as much wood from trees on the farm as possible(there is an old plum tree with a dead branch that I think may find its way into the build) but realistically I am going to have to buy in some of what you are suggesting. I must say boxwood is nice and easy to work with if you arent worried about fluff...which I very much am.
Cheers
Haiko
Gun carriages continued....
After reading through everything that @Marcus.K. so kindly shared I dissapeared down a rabbit hole of sorts. This excellent attention to detail and research has been a huge help for me in this project so far so THANK YOU again Marcus, it added a whole new layer of interst and meaning.
I decided that I would go for a "spanish brown"...which was apparently red....but almost a brown...confusing stuff...
I did some experimenting and I am not totally happy with the outcome but I am getting to a colour scheme which I will be able to live with when it eventually comes to the spar deck cannon. I think I will go with the same colours and techniques but I will add slightly more red and add a touch of darker brown. Hopefully this produces the results I need.
Below is the painted result of the carriages....perhaps too brown and not enough red but the light can play all kinds of tricks, they are significantly more "reddish" in person....clearly mor ework to do on colouring
Edited by The Bitter End
Guns!
So this has proven to be a real challenge. I turned one barrel on the lathe with reasonable success but I know I wont be able to consistently repeat this with perfect results another 29 times so I decided to go down the road of casting with some very mixed results. Here is the update so far.
I wanted to make my moulds with oyumaru or blue stuff but I cannot find either in South Africa. So i went for 2 other options....the first was a 2 part liquid silicon that would be poured around the cannon and then cut away to release the blank and then secured with elastic bands to re pour the liquid resin into it. This did not work at all...
Without the benefit of a vacuum pump to extract all the bubbles it created a mould full of imperfections. The elastic bank required to keep the soft silicon together distorted the mould and therefore produced a frankly rubbish result. The resin also left flakes inside the mould that would be very difficult to clean and finally the resin itself was very brittle and weak(this is clearly just the resin I used and I am not judging all resins). Here you can see the results of lots of struggling....
Next up was making moulds from thermal plastic. This process involved heating the product in boiling water. Pressing the cannon blank into the product until it was half in the material, then cooling the product in the freezer and then pressing a second lump of product on top of the cannon to make the second half of the mould...here you can see what this looked like,
I then pressed milliput into the 2 halves and joined them back together while it set(note the indexing holes and protrusions in the 2 halves of the mould.
This produced a reasonable result as shown below. the issue was that the mould struggles to release the material and it seems like the quality deteriorates after each attempt as the mould degrades. I do have a few ideas to improve this and I will report back.
I then made a little jig to file in the notch for the trunnions. As per the suggestion of Marcus, trunnions add an additional layer of complication to casting which I am not able to overcome.
I then added the trunnions and primed the 2 sample cannon with a grey primer...
44
I then finished them off with some black paint and this is where I find myself...
I did get the feeling that these carriages(built to the specifications mentioned in a previous post) were a bit on the small size. The carriages on the hull model also appear to be proportionally larger but I have also found examples in other research where the ratio between cannon and carriage seems equally disproportionate. Like this example of the constitutions 32 pounders from 1858..
My plan is to keep experimenting and seeing what works.
This means:
trying to produce a thinner more flexible thermal plastic mould with what i have already.
Trying to create a better silicon mould by changing the ratios of parts A nd B of the mix
Trying to buy oyumaru and having it imported into South africa
Trying a mould made from other materials like silicone and corn starch....
I weill report back soon.
Cheers
TBE
A gloomy discovery!
This is not the most proactive post but I Just realised that I somehow managed to mess up the spacing of the gun ports on the spar deck and they have to be gutted and redone.
The gaps between the forward and aft gun ports are 34mm at scale. When I went to mark out the gun ports in then waist I Realised that The maximum amount of space I could possibly allocate between ports while still having 5 ports is 24mm...essentially a 30% error. I could potentially live with this with some minor tweaking but the problem goes deeper....
The gun ports on the gun deck must be both equally distributed and centred between the gun ports on the deck above. This error on the spar deck means that the ports at the gun deck level would also have to be bunched at the waist area.
I did vaguely consider just leaving it as is but I realised that I am still only in the infancy of this build and I will put a thousand plus hours into micro measurements of perfection knowing full well that the bones are all wrong.
Wish me luck. I hope this can be fixed without destroying all that has been done so far,
Cheers
Haiko
For landlubbers and newbies in Constitutions early configuration:
Be aware that the configuration on spar deck changed between the beginning in 1797 to maybe about 1809/10 for which we have a sketch presumably by Rogders - showing still the orginal and equally between the gun deck ports distributed 7 gun ports in the quarter deck ...
Don´t be confused by that boat hanging in the david .. but I think one can see that the quarderdeck gun ports still are in between the gun deck gun ports, right?
... while the later in 1812 the Isaac Hull model already shows the 8 wider carronade spar deck gun ports which are - naturally - not perfectly fitting in between the gun ports.
Photo courtesy by Peabody Essex Museum, Salem, MA, USA
We know that the ship recieved in 1810(?)/11 the 16 new 32-pounder carronades.. It is very likely that the quarderdeck bulwarks were modified by then .. or maybe later in 1811 in Washington´s Navy Yard, when Isaac Hull took over the command and organized the refit. But that´s not very likely as the ship would have had no spar deck battery while traveling from Boston to Washington without the modification of the too small and too few gun ports. Possible - but not very likely.
So just in case someone wonders .. the early configuration differed a bit. And what we see today is still the 8 wider "Carronade" gunports per side along the quarterdeck.
Haiko, you sure know that the ship also did not yet have the "16th" "gun port" in the bow - which in fact is a bridle port - not for guns and which - when it was cut by Bainbridge into the hull in - was it end of 1812? - were even a bit smaller than the 15 gun ports on gun deck level.  .. just in case 🙂
Interesting maybe:
it seems the ship in Rodgers sketch seem to show upper gun lids on gun deck level. Which pretty sure wasn´t the case in 1797 and at least until 1804/05 when Cornè did his beautiful paintings. In those days the ship had detachable gun port lids.
But maybe the sketch shows detachable - but mounted and opened - gun port lids. ..
We assume them to be detachable at least until 1812 - as the 1812 Hull model again is shown in "battle configuration" without the detachable gun port lids (except the 2 most forward ports - where waves might be an issue even in good weather). Even in 1817 Ware Side view - no fixed gun ports yet ...
Edited by Marcus.K.
I do indeed wish you all the luck in the world.  Having just noticed for the first time on over a year the one repair for a misplaced gunport on the spar deck, I can offer that it does bother my perfectionist leanings.  On the other hand, I can live with the bad bones..
What was your reference point for locating your gunports?  The MS kit plans?
Hello Hello!
Thank you for the encouragement, I am going to need it. I am really trying to get my head around the idea that this is a marathon and thats ok, easier said than done.
I am using the traced Doughty plans for my gun port location. This is a very different arrangement to the MS Plans. 7 gun ports per side on the quarter deck and then another 8 open ports forward. I originally had partial bulwarks in the bow but now that I have ripped them off I am considering leaving those totally open....we shall see.
Cheers
Haiko
Interesting maybe:
Marcus my friend!
Thank you for yet another very informative and interesting glimpse into the confusing and colourful history of this ship.
I am going to go with the gun port layout on the doughty plans while assuming that the quarter deck has bulwarks and perhaps a totally open deck from the quarter deck forward(I will message you directly about this so as to not bore everyone too much with my questions.
As you mentioned the doughty plan also seems to show a very neatly spaced set of gun ports on the gun deck which fall directly between the gun ports of the spar deck(this is really why I am now redoing the spar deck ports.
Just a side note, I see the very forward gun port on the antczak model(which is supposedly the as built configuration) appears to show hinged single gun port lids(I too think this is incorrect) on all ports except for the forward most port which shows a split lid. A confusing little set of choices. This gun port also appears to be spaced a little closer to the precious gun port than in the doughty drawings or indeed any of the paintings where this port can be seen(Damn cornes cloud of smoke).
constitution-old-ironsid-webconstitution-figurehead.jpg.c53d49d1e74f6e4729801e1df0be9c03.jpg
Cheers
Haiko
3 hours ago, Der Alte Rentner said:
Are you referring to the red painted port cover all the way forward?  Or the natural wood finished one just aft of that?
Hello again!
I am referring to the red painted cover all the way forward. Is that not a gun port? 😅 I kind of just assumed it was without thinking too much
Chwers
Haiko
I was trying to find photos of Antczak´s beautiful model. I remember we talked about it in our PN conversation - and I remember to have seen more photos than the ones I find right now. He did an exceptionel beautiful model, with a lot of very good, very interesting and very likely features for the 1797 concept (as I believe it was - of course nobody knows for sure 🙂 ).. But we noticed then and here again some strange features, which most likely were not existing or differing. The port with the red shutters is the "16th port" below the cat head - which must be that "bridle port" I referred to in one of my previous post. THIS - most likely - wasn´t existing until about 1812, when Bainbridge prepared the third 1812-15 war cruise - just after Hull came back from his defeat of HMS Guerriere. I am searching my documents - but I don´t find the sources for this statement! 😕 Someone able to help me on that?
The bridle Port - when added - was smaller than the gun ports following (as there is another later mentioning in one of the logs that the bridle ports were cut to the size of the gun ports - indicating that they were smaller before) - and I don´t find THAT sources either! Need to read my Martin´s "Close up"!! It for sure would have had a lid to be closed - as it was the one most affected by wafes from the bow. .. but I do not believe that it was existing in the early years.
If you compare with the Doughty Plan, you will find the very first gun port is just one before the fore mast channels.  Below the cat head: no opening in the layout - and most likely not in the later existing ship.
I compared the 1819 Ware Deck Plan with the 1849 Pook Gun Deck Plan and you can see the Bridle Port (red marked) in 1819 - being a tiny little bit smaller than the Gun Port #1 (green marked) - while in 1849 the bridle port hat the same size.
You also can imagine that any gun there would not have room to run inwards - considering the bow sprit sitting in the center of the deck. No "chase gun" on gun deck level.
Here you have a bigger shot of the 1819 Ware Plan - and you see the position and size of the Bridle Port ..
In a comparision of Doughty´s plan, Gillmers reconstruction of the 1797 status, Cornè´s 1803 paiting and Pook´s 1849 side view, we can see: in 1803 there seemed to be no Bridle port - although I admit: Cornè´s bow area is a bit awkward .. he seemed to have issues with perspective and dimensions here.. So it is not a proof - but a certain evidence I would give to Cornè.
My conclusion: I would rather NOT show an opening below the cat head. In my opinion (until I change it 😁) the first Gun port is the one just forward the fore mast channel.
Edited by Marcus.K.
Quote
I was trying to find photos of Antczak´s beautiful model. I remember we talked about it in our PN conversation - and I remember to have seen more photos than the ones I find right now. He did an exceptional beautiful model, with a lot of very good, very interesting and very likely features for the 1797 concept (as I believe it was - of course nobody knows for sure 🙂 ).
Marcus K - The original posting of Antczak's model images were originally on American Marine Models' website, but have since been removed. They have a memorial to Mark Antczak's memory which states in part:
Quote
One of Mark Antczak’s greatest achievements was his ¼” scale (1:48) full hull model of the USS Constitution completed in 1990. This model was on display in the Carew Tower Arcade and the well know Exactitude art gallery in Cincinnati. It was acquired by a local business man, but was subsequently put on loan to the Maine Maritime Academy in Castine, Maine where it was displayed for a several years.
However, I have not been able to locate an original source for those images now. But all is not lost, I made a copy of them as well as Usetosail who posted them on his build log of the USS Constitution post No. 556. Here are all that I have have plus three additional photos that Usetosail did not post.
On 3/15/2025 at 10:48 PM, The Bitter End said:
Hello again!
Chwers
Haiko
As confirmed by Marcus and Jon, I'm going with bridle port.
Edited by Der Alte Rentner
Hello everyone.
After the very demoralising step of pulling off all my spar deck gun ports I managed to make some progress again.
I dont know how exactly I managed to mess up the gun port placement so badly. Something about measuring once and cutting twice...I can't quite recall...anyway. I won't bore you too much with the repeat process but here are the basics...
I couldnt find any drawings of step 1 in the plans:
Then repeating the process that was completed in a previous post but this time measuring very carefully and this resulted in a far longer waist than before and slightly more elegant lines.
20250314_065400.thumb.jpg.dbbbbfaff76755ada16cd0fec06486c0.jpg20250315_202628.thumb.jpg.9259f4d3bcb638a898174054e963eaa6.jpg20250323_185553.thumb.jpg.40a5684fc6c045df8cbf2ccda5d5a564.jpg20250326_064719.thumb.jpg.467430e8b5fa5caa0860a54551cceede.jpg
On to the gun deck gun port framing...
TBE
For Framing the gun ports of the gun deck I began by marking out the locations of the gun port on the strake just below the plankshear in pencil. These gun ports are 3.1ft by 3.1ft at full size according to the Doughty plans, 12.3mm at scale. which is slightly larger than the spar deck gun ports.
For all reasonable purposes these are located directly centred between the gun ports of the spar deck. Here you can see the pencil marks as well as the X on the frames which need to be removed to accommodate the gun port.
Next I marked the upper and lower sills of the ports in pencil on the frames by measuring a uniform distance down from the spar deck to make sure that the gun ports followed the swoop of the spar deck fairly closely. and clamped a single strake to the frames to create on smooth line and did a final marking of both upper and lower sills. I then double checked this against a gun on carriage built to the naval spec. All these measurements dovetailed perfectly resulting in a cannon which was nicely aligned with its port as well as ports which looked fairly well placed to the laymans eye.
I then clamped a single long run of plank to the inside of the frames at the level of the lower sill so that I could mark out where the gun ports would land as well as providing a reference surface to put my main gun port sill beams against so that the barrels would all protrude and equal distance from the hull when the carriage was pushed up against the bulkhead on the gun deck.
Next was to take pear offcuts of roughly the same size(these were mostly from my learning phase on the table saw. I didnt need a perfectly uniform piece of wood, it just needed to be flat on one side and slightly thicker than the frame so that it could be sanded back when all was said and done.
I began with the lower sill, working from aft to forward, removing the frames that were in the way as I went. This did require a bit of steaming and bending to get the sill to follow the correct lines, particularly where the bow curved and where the frames had been removed. This process was then repeated for the upper sill. Please ignore the ragged egdes etc. only the internal frames of the gun ports will be visible after planking.
On to the verticals.
I made a small template to build the sides of the gun ports around. This ensured square corners and the right uniform width for all ports. Just a 12.3x12.3mm piece of wood on an angled stick.
I then installed the verticals.
And then some sanding. (I have a blister)
20250404_052517.thumb.jpg.6222ca85cde5f7f5a68b419ca58b6964.jpg20250404_052606.thumb.jpg.85e5a053084783ffe4ae3731afb06402.jpg20250404_052637.thumb.jpg.c2d76755cb7b30ce20e4dc6284000c18.jpg20250404_052702.thumb.jpg.f54dea85c8032269fda38fa1b4419f5e.jpg20250404_052714.thumb.jpg.c14ce4c299b70861fa142dcad0dea87c.jpg20250404_052726.thumb.jpg.9b862bb7e17c445108cf791334cd1989.jpg
Lots more work to do and cleaning up and sanding on the other side to get this done.
Cheers
TBE
28 minutes ago, Der Alte Rentner said:
Is it just me or are the gun deck ports slightly concave vertically?
The Spar deck ports look great.
Peter my good man!
Firstly, thank you and secondly I think you are both observant and correct. The way in which I sanded these seem to have resulted in the concave appearance that you are seeing. I am hoping that I can eliminate this with the 2 layers of planking I must still add over them. I must actually take a look at the Lord drawings and see what exactly the profile should be but it's definitely not like that.
I hope this can all be ironed out
Cheers
Haiko
