I suspect that, rather than a "vacuum" causing the injury, it was the peak differential pressure of the shock wave caused by the ball's passage on soft tissues. The turbulent, low-pressure region associated with a high-speed projectile is directly behind the ball, so the "vacuum" itself would have little to do with causing the non-contact injury IMO.
  There seems to be disagreement on this topic.  During the war with Mexico, Thomas Jackson (later 'Stonewall' Jackson) had a cannon ball pass between his legs (spread in a stance) as he was rallying his men.  There were no effects.  I suppose if the 'miss' is less than an inch by a high velocity shot, there might be effects ... but I don't think the Mythbusters would take this chis challenge on - even with a ballistic gel simulation.
AI Overview
No, a solid cannonball passing close to a body will not cause injury; a person is only at risk of injury if the cannonball makes direct contact.
  • Shockwave: The shockwave from a single, non-exploding projectile like a cannonball or bullet is not powerful enough to injure a person.
  • The "shockwave" of a near miss: The idea that a bullet or cannonball passing by can cause a shockwave injury is false.
  • Historical reports of near misses causing death are likely due to misunderstandings.
Without daring to comment on the potential for "near miss" injuries, I'll suggest that, in naval combat, it was the "splinters" (which could be multiple feet in length) sent flying by the impact of roundshot on the ship's structure that  did most of the damage to human bodies.
Trevor
AI Overview
I think you can take modern equivalents into account as well. How many WW1, WW2, or even Vietnam war stories involve bullets whizzing by perilously close (and in some cases dinging off) helmets. Or dud artillery shells landing between soldiers’ feet (lots of those stories). All resulting in minimal to no injuries at all (maybe a strong need to change one’s pants).
Andy
Quando Omni Flunkus, Moritati
USF Confederacy
In the 1915 shelling of Kavalla by RN monitors the Farman biplane acting as spotter was torn apart by turbulence from passing shells without actually having been hit.
STAY SAFE
current builds:
Two different things, really; turbulence and pressure waves.
Turbulence is the disruption of air as a result of something passing through it. The air can move dramatically in different directions. Yes it can be violent, even modern jets need to be careful of wake turbulence when operating near one another.
In your example the asymmetrical action of the turbulence, and the resulting aerodynamic forces acting on a relatively fragile airframe exceeded its structural strength. I very much doubt that the pilot was killed by the turbulence, or even the blast concussion from the fired gun (had he been foolish enough to be flying that close), more likely the abrupt stop when he unexpectedly returned to sea level sans aeroplane.
Have a look at the research done by John Stapp in the 40s and 50s (he’s the guy who rode the rocket sled “al fresco”):
https://en.wikipedia.org/wiki/John_Stapp
Andy
USF Confederacy
Andy, both of the crew went into the Aegean trapped in the wreckage.
STAY SAFE
current builds:
The energy delivered to a target by the shock/wake system is of the same order as the energy loss due to drag over a short distance... which is fairly trivial for most practical cases especially when taken over an 'edge' rather than the total loss integrated around the entire surface.
OTOH the blunt trauma from a 'spent' projectile incapable of perforating a blanket or cloak was sufficient to pulverise the rib cage and internal organs of a sleeping soldier in the lines of contravallation. He was found dead with no external wound, beyond a contusion where the rolling shot had hit him, and the shot lodged neatly in the hood of his cloak.
Others lost feet 'stopping' spent shot rolling slowly over the ground.
There is also of course a significant concentration of momentum in the muzzle field gasses - amounting to about 35-50% of the shot momentum, so blast injuries in the immediate vicinity of the gun is probable (combination of the bulk motion of the restrained propellant gasses to muzzle exit and the 'nozzle' expansion of the gasses after the shot clears plus an amount of blow-by ~ around 10% of the additional momentum is from the losses between shot and bore, but this does reduce the 'additional' work from *after* muzzle exit...
(Similar claims made about the 50 BMG can be demonstrated false by firing (from outside the muzzle field) between the triangles formed by a House of Cards - the wake/shock doesn't disturb the cards, and a hit (even a very glancing one) is required to knock them down).
Super-sonic reports vs surface area and velocity can be quite violent indeed, however. The indirect damage, via a small body (cannonball), simply travelling at supersonic speeds would be minimal indeed. Such a small object simply flying through the air might burst a delicate eardrum if zipping within an inch or so of someone's ear, but I doubt that much more damage would occur. Could cannonballs fly that fast in the 18th century? 'Yes', they actually 'could'... but they'd have to powder the behinds of those cannonballs close to the maximum charge allowed before blowing up the cannon! Not a good thing to do if you intend for that piece of artillery to survive the battle! Odds are that most of those cannonballs were flying below the speed of sound where minimal effect would be noticed until that ball actually 'hit' something, then all hell would break loose, splinters would fly, rocks would become deadly projectiles, etc. Reports of 'Wind' injuring and killing people were likely nothing but circumstantial observations made by folks who were too damned busy being scared to death, during battle, to truly pay attention to who really got hit by what! Lots of 'legends' come to life from stuff like this. Gregory 'Pappy' Boyington is a perfect example of exaggerated truth! He's definitely one of my hero's, but if you read 'his' book... you'd also do well to take most of it with a grain of salt. As with 'anything'... take great care in what you truly choose to believe! 🤔
Edited by tmj
Even if a spherical ball could leave the muzzle at supersonic speed (very improbable with black powder as propellant), it would very quickly decelerate. The aerodynamics of a sphere are poor indeed!
Trevor
A 32pdr ball from the Blomefield pattern gun at the (late) middle gauge and with the turn of the century Waltham Abbey cylinder milled powder should still be sonic at about 500m. Smaller bore guns tended to be longer, relatively and could have significantly higher muzzle velocity, but lose velocity slightly more rapidly. 24pdr 9.5ft also around 500m, and the 18pdr 9ft a bit less ~475m, while the 12pdr 9ft is sonic at about 425m. The later 58cwt gun is slightly 'more' by virtue of its lower windage, but not by enough to render the very popular 55cwt guns obsolescent. Carronades are high subsonic (and with a few of the lighter rebore patterns of guns being roughly sonic at the muzzle).
Muzzle velocity is expected to be above 500m/s for all of these guns rising as the calibre falls to about 540m/s for the 12pdr. (Sonic ~340m/s) (explicit muzzle velocity measured by Navez on an electro-chronograph for the 24pdr is 1720 ft/s, using the later shot and the standard military powder made up from high quality new powder mixed with small proportions of recovered powder to moderate the velocity to provide a maximised consistency of power)
French powders are weaker, especially early on, though they recover most of the deficit in power between 1827 (where they are testing with Pont de Buis hammer milled powder) and 1843 (where they have a cylinder milled powder from Ripault in their testing programmes). There is still a small deficit recorded between French powder of 1860 (noted by the French as being the same as Ripault/1843) and 70 year old Waltham Abbey powder, when tested by Lt Mordecai of the USN. French guns have a narrow spread between their high and low gauges and use a higher line of metal to get a slightly longer but-en-blanc along the metal and marginally more consistency. Even with the much weaker powders indicated from their 1808 and 1811 gunnery manual their artillery is supersonic at the muzzle and for a few hundred metres downrange. The velocity deficit by the 1840s is on the order of a few percent, and not a critical difference - pointing is also detached from the line of metal with the universal provision of tangent sights.
Edited by Lieste
