A little background. Been modelling for along time mostly scale plastic modelling in 1/32, 1/35 and 1.48, primarily aircraft and AFV's. Have been actively modelling since 2016 after the customary return to the hobby stage.Have only ever built one marine based model and that was the Italeri Elco PT 596 which I attempted to detail but not to the level of you guys. Since retiring last year I feel I needed a new genre to tackle and hence my first venture into wooden ship modelling. I am going to attempt to build Chris Watton's, HMS Sherborne cutter. It is advertised as novice and I can say that's exactly where I place myself. Looking forward to learning.
Phil.
Current Build: Vanguard - HM Sherbourne.
Other builds: ICM Bristol Beaufort - 1/48
Completed Vessels: Italeri Elco PT 596
:sign:
Have as much fun as you can, enjoy the journey,  :cheers:
        USCG Harriet Lane
 BC, welcome to MSW. Glad to have you aboard.
Thanks Keith, hoping to learn lots.
Phil.
Phil.
1 hour ago, vvvjames said:
Welcome! Best of luck with the Sherborne, I'm sure you'll do great work with it!
Thanks, much appreciated, having an engineering background I must tend to not except “that will do”.
Phil.
Welcome Aboard Phil!  An old friend once told me that once I retired, I would be busier than when I was at work. I can vouch for that.  Lots of excellent modelers here on MSW who are willing to help and give advice.  Hope you'll consider starting a build log.
Welcome!
Wawona59
John
Current Project:
Wawona Lumber Schooner
15 hours ago, Jim Lad said:
Hello, and a warm welcome to the forum from 'Down Under'.
John
Thanks Jim, I won't mention the cricket.
Phil.
Phil.
Welcome!
Thanks John, I worked in the design industry all my life and that meant daily project deadlines that had to be met. Retirement has cleared my brain of all deadline anxiety, so life is a more relaxed affair. I will definitely do a build log.
Phil.
Phil.
3 hours ago, AJohnson said:
Welcome to MSW Phil!  :cheers:
Thanks Andrew, there is so much to read here not sure if I'm going to get any modelling done. The Sherbourne is due to be delivered on Thursday.......
Phil.
Phil.
 Phil, MSW is a treasure trove of information and it's well worth taking the time to read as much as possible before plunging headlong into your project. It will make your efforts much easier.
Edited by Keith Black
