Really gorgeous work Rod!  Very impressive!
I love your case too.  Just out of curiosity, did you cut the plexiglass yourself, or did you have it cut professionally?  I'm trying to figure out what to do with my case, and weight is making me lean with plexiglass.  I bought a case from Model Expo for my Badger, but I have to source the glass.  Thanks!
Mike,
I bought 0.093 in. thick Optix brand acrylic sheet at Home Depot. The total cost was around $90 so glass might be cheaper. The acrylic sheets come in widths that are multiples of 12 in. My width was 12 3/4 in. so there was a lot of waste.
You can buy a tool to score and snap the plastic. If you score it many times perfectly along a straightedge and are very careful, it will snap right along the score. I screwed up my very first cut, so I gave up and used my table saw. I cleaned up the edge with sandpaper. The table saw turned out to be a good idea because I had to recut several pieces slightly undersized to make everything fit.
Rod
  • 1 year later...
