tys sailor lol i might have an update later today will see what happen
ok in the pic u will see this pic the back of the keel not to sure if i should sand it down theres a big gap sand down in side of the slot of the bulkhead some help on this part be nice
post-2052-0-78118500-1387521916_thumb.jpgpost-2052-0-56531700-1387521943_thumb.jpgpost-2052-0-86118500-1387521958_thumb.jpg
Hi Dragzz,
I just had a look back through your log and  it looks to me that the slot the frame is sitting in, in the last bulkhead, will need to be sanded down to allow the frame to sit flush with  the top the bulkhead also, looking at your second photo,  the edge of the frame sitting against the bulkhead will need to be carefully sanded so that the tang fits into the slot in the keel to keep the line of the stern post true.
Hope this helps
Cheers :cheers:
Jeff
Current Builds;
 HMS Supply
Completed Builds;
AL Swift 1805; Colonial Sloop NorfolkHMS Victory Bow SectionHM Schooner Pickle
Hi,
to me it looks like it just needs to be tilted to fit, i mean, the slot and the part that goes into it are of the same width and it looks like they can fut into each other. If you can t tilt it then i think the problem might be the order in which you put togheter the parts. Just my humble opinion, from what can be seen in the pics, anyway shaving it off to fit won t cause major problems..
Tomas
I would have thought the keel should have been totally assembled before you got this far........but I can't see the plans from here ;)  I would probably free up that last bulkhead,  so it is movable to some degree....it can be cemented back in place after the part is installed.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
tys for the info jeff just going sand very light then at each time
tys popye but the bulkheads are all glued cant take a part at all  this is the way it is in the plans and in the book going to sand little at a time dry fit it each time  tys for all your info
will update real soon
here i just did a little sanding on the part in the pic u will what i mean just doing a little at a time this is where iam at  now
post-2052-0-19830800-1387610555_thumb.jpgpost-2052-0-13879500-1387610570_thumb.jpgpost-2052-0-15284400-1387610588_thumb.jpg
sailor was not that i was thinking to hard at it lol  in the part i was sanding i found a little warp in so for now i put in water for a bit then in the clamp for the night see how it looks then  look for update soon tys
yes jeff so do i or i got fight  on my hands lol it should be ok
Ahoy Dragzz :D
I had a slight warp in my keel. I wetted one side "lightly" and then put it on a piece of wax paper on a glass surface, covered it with another piece of wax paper and then my building board and a 15 pound dumbbell. The next day it was fixed. I did not soak it because its ply and I wasn't sure if the glue used was waterproof.
 On with the Show.... B)
  J.Pett
“If you're going through hell, keep going” (Winston Churchill)
Current build:  MS Rattlesnake (MS2028)
http://modelshipworld.com/index.php?/topic/45-model-shipways-rattlesnake-ms2028-scale-164th/
Side Build: HMS Victory: Corel
http://modelshipworld.com/index.php?/topic/3709-hms-victory-by-jpett-corel-198/?p=104762
On the back burner:  1949 Chris Craft Racer: Dumas
http://modelshipworld.com/index.php?/topic/939-1949-chris-craft-racer-by-jpett-dumas-kit-no-1702/
Sometime, but not sure when: Frigate Berlin: Corel
http://www.corel-srl.it/pdf/berlin.pdf
tys for the tip jpett
as u can see in the pic i got a new xmax gift i got to open one and o ya i was so happy anyways in the pic as u can i got the warp out and it fits just right and it levl as well
post-2052-0-39650900-1387769401_thumb.jpgpost-2052-0-00168300-1387769412_thumb.jpgpost-2052-0-96416900-1387769423_thumb.jpg
tys jeff it came out great now i can move on yes the keel holder is great i love it i can lots with it iam going to wear it out lol   going to take a bit of a break for  Christmas see u all in a bit
from dragzz u all have a great  Merry Christmas
happy holidays to you as well....good sir!  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
ok i got board  so in the pic u will i got the lower deck in place not glued still have to plank it just getting ready  so far so good let me know what u all think
those have to be some really deep slots,  to be a single piece part........usually,  it's split in two.   are you going to plank it after it's cemented in place?    it would be a good way to hide the slots.......by planking them over.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Ahoy Dragzz :D
Looks good.
If and when you glue that deck I would have her in the wood stand and not the Amati. I use the Amati and it will not prevent the deck from adding a twist to your work.
I had some issues with the deck forming to the curve of the deck and the sweep of the hull. I ended up having to wet the deck after gluing to get it to relax. Please let me know if you find the same. I am considering redoing mine
  J.Pett
hello popeye yes the deck will be planked it will cover the slots that u see in the pic
hello jpett i will let u know what happen to it going to plank it soon will see what it looks like befor i glue it in place
hello all jpett was right  iam going to redo the deck the wood used to plank  is not good most of mine is warped and does not look good at all going to order new wood thin stuff is not good going to use a bit thicker i think might go wallnut decks let me know what u think
here is a pic of the strips that i got  to use not good to me at all
I am going to start construction on the HMS Victory by Corel in January. I am now checking the contents and reading the limited instructions,  In your photos, what size wood did you use to hold the keel in place? Also are you going to leave the ship natural or the painted version?
I will be following your effort to construct this beautiful model.
hello harm welcome to my build log   what i did for the keel was build a keel holder for it  make sue that u build one u will need it . it will hold it in place so it dont get a twist in as u build . as well make sure that u look over all the wood in the kit for warped parts cuz my keel was warped some of strips of wood as well if u need to see the pic of the keel holder i will post it for u  the wood for the holder is 3wide 2 1/2hthe base  2x4 at the front
post-2052-0-72942500-1388168691_thumb.jpgpost-2052-0-14441400-1388168796_thumb.jpgpost-2052-0-61693300-1388168806_thumb.jpg
the slot u see in the wood is about 3 16 of an inch  hope this helps u
yes harm iam going paint it
Edited by dragzz
here is the wood strips iam going to use for planking the decks light wood
are you going to do scale planking?   one thing I always see in a kit,  is that they always include .5mm  planking,  that is 5 mm wide.  if it were to be scale planking,  they might have been better to include 2 - 3 mm wide planking.  as far as cutting the length goes.....I take the easy way out....I cut them to the length of two ribs.   I draw lines at each rib......sometimes I will draw lines in the centers between each one as well.  I do a center line down the middle for the king plank{s}.    you can't really go by these measurements though......even the manufacturer can be a bit off with these measurements.   then you could mass produce the planking and do the calking around the edges.
    I use an archive pen for that......India Ink.   I have used crayon as well....but it's a bit messy.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Ahoy Popeye :D
I have noticed most kit supplied lumber is out of scale when it come to the decking. The Vic is 51'10" at her beam and 3mm would be my best guess, I did 48 planks at a foot width. Do you know how wide the planks were on a ship of the line.
Edited by JPett
  J.Pett
hello popeye   the planks iam going to use is a 1.1x5mm iam trying to build here for a good friend i had if u know what i mean i think its will look just fine
hello jpett  hope u feel better
up date real soon     just trying to do the best i can
hello jeff   thay are a bit wide but that ok   like i was say i have to do with what i can get from the hobby shop that all thay had
Edited by dragzz
