Margin planking continuing.....
Another length should fit on each side before I reach the curve of the bow section.
Also done some testing of marking the maple planks with a sharpie and getting a slight bit of bleed into the planks, so I will varnish the edge of each plank before marking the edges for caulking.
Jim
Current builds:
HMS Snake
HMS Hood
Mechanical Solar System
Completed builds:
HMS Ballahoo
Looks the absolute biz Jim.
I have 5 margin pieces per side to get from Bow to stern, could probably have gotten away with 4 but I was leaving plenty for room for error.. ^_^
Great colour contrasts at the transom, should look really well back there !
All The Best
Eamonn
Current Build   :  HM Schooner Ballahoo
In the Pipeline :  HM Cutter Sherbourne, HM Mortar Convulsion, Emma C Berry & C18th English Longboat.. Eventually That Is..🙄
Finished starboard side of margin planking. Just one more piece on starboard and the scarfing to go.
Eamonn - this picture should show the bow piece I have used.
Completed port side margin planking.
Edited by jim_smits
Jim
Current builds:
HMS Snake
HMS Hood
Completed builds:
HMS Ballahoo
Had a couple of days off work leading upto Easter, including my Birthday on Wednesday (Thanks btw Eamonn!), and managed to make some more progress on the build.
Planked the inside of the bulwarks and re-cut the gun ports. Applied filler to the planks and sanded back. Also added in the main wales.
Finally got to a position to start painting the hull inside and out. Also gave me a chance to really stretch the legs of my airbrush I bought a couple of months back.
Bit of playing round with paint and thinner combinations, and came to the conclusion that only a hint of thinner is really needed. Gave the outside of the hull a coat of dull black from Admiralty Paints. And....... there really is nothing like a coat of paint to show up all the flaws in a hull....!
Loads of micro cracks in the planking and filler sections. I think I will need to apply some additional filler with a metal scraper and really drive the filler into the cracks.
Edited by jim_smits
Jim
Current builds:
HMS Snake
HMS Hood
Completed builds:
HMS Ballahoo
Got the main painting of the ship out of the way finally!
Took several layers of black sprayed on with the airbrush. After each layer any cracks located were filled and gently sanded back and a further layer of black added. eventually got to a point where I as happy with the finish.
Next step was to add a coat of yellow ochre to the top section above the wale. Needed two or three coats to get decent coverage over the black undercoat but the airbrush made this fairly quick and painless. Finally, some Tamiya tape was used to cover over the band of yellow to be kept over the gunports and a further couple of coats of black used. Stripped back the tape to leave the finished look.
Got a couple of small bleeds under the tape but nothing major, and a slight touch up on the top edge of the wale is required. Also need to paint the transom area by hand.
Painted the inside bulwarks with red ochre by hand with a couple of coats.
After final touch ups, I'll almost be ready to start the decking process.
Jim
Current builds:
HMS Snake
HMS Hood
Completed builds:
HMS Ballahoo
Another update.
I've now marked the waterline and painted the lower hull in white stuff.
I used my helping hands to hold a B pencil at the desired height and carefully marked the waterline onto the ship.
Mixed up a paint for coating 'white stuff' onto the hull using 80/20 white to yellow ochre to give a off white cream colour. Gave the hull a three coats to give an even finish. Need to smooth the finish with some ultra fine grit sandpaper but essentially ready to start the decking process.
Jim
Current builds:
HMS Snake
HMS Hood
Completed builds:
HMS Ballahoo
Wonderful stuff Jim.. you'd want to have seen the Heath Robinson affair I used to draw the waterline, I'd swear there was a spring in there somewhere.. :huh:  ^_^
All The Best
Eamonn
My Ballier kicks back in tomorrow !
Minor update.
I've now marked in the butt shift pattern on the deck. As a result of this I also remade the margin planks at the stern posts to make it a little wider. This now gives an exact fit from the bow piece to the stern of 11 'shifts'. This should make life a little easier. I've gone with a deck plank length of 120mm, so a shift of 24mm in each case.
Tonight I will fix the bow and stern pieces in place and start the centre line planks and work outwards.
Jim
Current builds:
HMS Snake
HMS Hood
Completed builds:
HMS Ballahoo
Nice.. spent some time today finalising the margins.. little more work required there before I'm happy with them.
My deck planks are a little shorter at just shy of 90mm ( just over 18ft in full scale) the same as my hull planking.
Best of Luck Jim
Eamonn
Some good progress on deck planking last night.
I'm using 120mm deck planks, sanded to size and to give a smooth finish, then a coat of satin varnish is applied to the edges and allowed to dry before using a sharpie to colour the edges black to simulate caulking.
I've started with the centre line of the deck and gradually working my way out towards the margin planks. The margins are not yet glued in place as I want to be able to cut the nibbles and 'caulk' the margins outside of the ship before fixing in place.
Made a start on nibbling the foremost margin plank on the starboard side. Using test deck planks for the moment, but got the first three nibbles cut in place. Used a heavy duty x-acto blade and VERY carefully cut the nibble. I used the test planks to mark the two points at which the deck plank 'intercepts' the margin to mark out the size of cuts to make. The test planks were then shaped to fit for a final check on the shape. Minor adjustments made using a needle file.
Happy so far with the process but it is quite stressful the more nibbles are cut as there is more work to lose if an error is made. If in doubt, cut less and then file to shape.....!
Once all the nibbles are finalised for each margin plank, it will be varnished, 'caulked' and glued in place. The proper deck pieces can then be cut to fit and glued in.
Edited by jim_smits
Jim
Current builds:
HMS Snake
HMS Hood
Completed builds:
HMS Ballahoo
Very nice Jim, definitely want to try this next time - clarifying question, are you glueing the deck planks as you go to help keep the margin planks in the same place?
Cheers,
Jason
In the shipyard:
Crazy decking fun today!
Completed the starboard side of the deck. Nibbing and joggling initially went well and got the first few sets of planks fitted properly. However ran into a potential problem with the planks amidships, with the last plank laid leaving a gap of only 2mm. Gave it some thought, and decided to redo the margin planks from amidships back to the stern. Used a wider plank, shaped to fit the bulwark but left the other side flat to fit against the existing planking. This gave a good result but took a while to redo.
Dry fitted all the pieces and ensured everything was correct, and then removed them all, varnished the edges and coloured with a sharpie. Then glued all the pieces back into place starting with the margins.
Just need to repeat with the port side of the decking.
Jim
Current builds:
HMS Snake
HMS Hood
Completed builds:
HMS Ballahoo
Fantastic Jim, you have set a very high standard.  One possible suggestion if the planks aren't glued - I believe that there would not have been any butt joints between the hatch/companionways where a regular plank length would have been sufficient to cover distance between them.  I found that out after I had done mine on Snake but luckily I was able to hide the main offender with a slightly re-positioned companionway coaming.
Cheers,
Jason
In the shipyard:
Planks between the deck fittings have been replaced as per advice - thanks Jason.
Also, added the nibbling and planking at the port bow section. as before replaced the margin plank amidships. Still need to finish the stern section and then sand down the deck for a fully smooth finish.
Edited by jim_smits
Jim
Current builds:
HMS Snake
HMS Hood
Completed builds:
HMS Ballahoo
Decking is now complete!
Had a minor issue on the port side. After dry fitting multiple times and being happy with all the plank shaping, I proceeded to glue all the pieces in place. Got to the final plank that was to fit against the amidships margin plank and suddenly there is a gap....! Only about 0.5mm but seemed to appear from nowhere after all the dry fitting had been very snug. It's not very noticeable so I have gone with it and fitted the plank so that the gap is on either side and so makes it less noticeable.
Filed the gaps for the anchor rope and the masts and given a coat of satin varnish. Will give it another couple of coats tonight and then move onto the bulwark capping rails.
Jim
Current builds:
HMS Snake
HMS Hood
Completed builds:
HMS Ballahoo
