That's some really nice sewing work you've done on your sails Frank. So the rigging fun begins.   ;)
Cheers
Hi George,
Thanks for checking in on my log! Yes, the fun is just beginning! I do enjoy the rigging process, except for the fact my eyes are going on me making it tougher! :)
Frank
Awesome work on your sails they look so good. They will certainly add a huge "bling" to your gorgeous ship. The bolt ropes work is excellent! Did you use ropes from Chuck as well, and what size?
Cheers,
Michael
Michael,
Great to hear from you! Thanks for the complements! It is appreciated. Yes, I am using the ropes from Syren. I originally was going to use the .035 line for the bolt ropes, but I have changed my mind and moved up to the .045 size. I think they look better! I am keeping track of all the different dia's I have been using for both the dark brown and tan lines. When you reach that point in your build, I will send the list to you if you would like!
Thanks,
Frank
Hi Frank. Another pictorial reference I have used is Clayton`s scratch built Vasa web sight. It may not be 100% correct in light of the latest findings but it is pretty close.
https://sites.google...dishwarshipwasa
/Mark
Mark,
Thanks for the link! Another great site for photos of the rigging. I added it to my bookmarks!
Frank
Hello!
Thanks for all the "likes"
I just returned from a great week of fishing down in the Florida Keys and I finally was able to get back to work on the shrouds and ratlines!
I made some spacers out of metal wire in order to try to keep my deadeye spacing consistent.
Finished the lower mizzenmast shrouds and tackle.
With ratlines installed
Now I added the Lower Mizzen Stay.
View of lower mizzen ratlines and stay
Working on the mizzen upper ratlines
Mizzen topmast sail almost finished with "pre-rigging" and ready to mount on mast soon
Thanks,
Frank
That's some really great work Frank! She looks marvelous!
Cheers
GEORGE
Nice Frank,
Your rigging and sails are looking super great.
Michael
Under the table:
Woody Joe Higakikaisen
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Hello,
Thanks to everyone for the "likes"!
George and Michael,
Your kind thoughts are appreciated. Hopefully I'll be able to improve on my limited photo taking abilities and improve the quality!
Thanks,
Frank
Hello,
Continuing on with some rigging of the mizzen mast.
Mizzen topsail pre-rigged and ready to mount on mast.
Attached sail (but not aligned!)
I ran the running lines thru the blocks, but I left most of it loose for alignment and leveling at a later time. (after all the standing rigging, shrouds, and stays are installed)
Some completed lines.
Now I'm moving on to working on the lower main mast sail!
Thanks,
Frank
She's looking great Frank. The rigging and sails are making her look more and more complete!
Cheers
GEORGE
Frank,
Excellent progress. Looking very excellent. Adding sails was a "grand slam" idea (:-)
Michael
Under the table:
Completed:
Vasa-Corel -
Frank,
Michael
Thanks Michael!
I'm working on the lower main sail now. I will post pictures soon.
I hope all is well!
Frank
Thanks again for all the "likes"!!!
So now I started working on the lower main yard and sail.
My goal was to create a partially hoisted sail, similar to
Karl's fine log and the 1/10 Vasa at the museum. This is my first attempt at doing something like this (vs having a sail completely furled or fully open). So let me know your thoughts so that I can see if this will be something to consider in future builds!
First I attached the rollers to the yard then I attached the main sail to the yard. Since I am attempting a partial hoisted sail, I left this sail at its actual dimensions.
Blocks attached to the front of the yard and line pre-rigged.
Blocks attached to the rear of the yard / sail
Each end of sail furled and lifting lines attached.
Looking at front of sail fully "pre-rigged" with lines and with the sail partially hoisted. Remember, previously, when making the sail, I inserted a 22 gage wire along the bottom of the sail to help it hold its position.
I added the blocks to the bottom rear of the sail and pre-rigged some more lines.
Here are some pictures of the yard and sail mounted onto the mainmast. Remember, a lot of the pre rigged lines will stay loose and unfinished until later in the rigging process.
Yard attached to the mast
Lifting lines finished to deck
Front of mizzen sail attached to deck
Now I am starting to work on adding the lower main mast shrouds and ratlines.
Thanks,
Frank
Love the "half-furled" look of it Frank. Looks great in place, and leaves more of that marvelous detail visible, while not taking away from the look of functionality. Very nice work!
Cheers
GEORGE
Wonderful work on the sails!!!
Love it :-)
XXXDAn
Frank,
Boy did I fall behind on your log. Oh my, with apologies.
Your sails, stitching, furling, rigging are all first class works of art. Congrats your Vasa looks so excellent.
I will follow your lead and log advice when I get to where you're at. Yes as George noted, partial furling the sails is a great idea, allowing for a lot of weather deck details to remain more visible. I also very much like the partial furling because it then allows one to see the purposes of specific rigging lines, especially for non-ship hobbyists . Nice touch
Again such great scale detailing !!
Cheers,
MIchael
Edited by md1400cs
Under the table:
Completed:
Vasa-Corel -
Thanks Michael!
I am now working on the mainmast shrouds and ratlines. (Very repetitive, but I'll get thru it!)
Glad you liked the partial sail. I think it will look even better (hopefully), once all the lines are positioned and tightened down.
Thanks,
Frank
Hola Frank:
Undoubtedly it looks much better with sails than without them.  Congratulatios, very fine work.
Saludos, Karl
Karl,
I hope all is well!
Thanks for your kind comments. I keep referring to your pictures in order to help me out!
Thanks again,
Frank
That red is fantastic. What color and brand is that?
Your ship is awesome!
Salty Dog!
Glad you like the color!
The red I used ia number 435 Naphthol Crimson by Folk Art.
You can find it at a Michaels store or an AC Moore store.
Thanks,
Frank
Salty Dog!
Thanks,
Frank
Thanks Frank,
I'm so used to buying my paints from hobby shops rather than crafts shops.  I'm going to have to expand my horizons.  I really like that color.
Hello,
I made some more progress on my rigging.
I installed the lower main mast shrouds
Attaching the ratlines
Adding the main stay
Figuring out where all the running lines end up on the deck
Now I am ready to move on to the upper main shrouds and sails.
Thanks,
Frank
Great job on those shrouds, stays, and ratlines Frank. Outstanding!  :dancetl6:
Cheers :cheers:
GEORGE
Looking good Frank! I just remembered that it was mentioned on the Vasa forum by Fred Hocker that the last deadeye on the channels may have been a topmast backstay instead of a shroud.I don`t know if he had hard evidence or was just making an educated guess. I don`t really think it would make a whole lot of difference either way on our models. It seems a little difficult to keep up with the changes they keep making at the museum  :huh:.
/Mark
Edited by marktiedens
current build - HMS Vanguard - Model Shipways
Mark,
Should I just commit suicide now? !!  :)
I am all confused, working off of 3 different plans and pictures from Clayton, the museum, and other logs! I am working slowly trying to figure out where all the rigging ends up on the deck and railings.
I sure wish that the Vasa rigging book from the museum would have been published before I started the rigging!
Thanks,
Frank
