'Put breaching ropes on the Port Carronades..(Starboard still to do)'   ^_^  ^_^  Jeeez don't you just hate nit-pickers like me  :P  :P  :D  :D
Really looks the business Rob, am enjoying your build.. the figures will be a nice touch, they show the scale of things brilliantly!
Roll on more updates..
Stay Well
Eamonn
Current Build   :  HM Schooner Ballahoo
In the Pipeline :  HM Cutter Sherbourne, HM Mortar Convulsion, Emma C Berry & C18th English Longboat.. Eventually That Is..🙄
Thanks Jim,
Wonderful kits aren't they :) Time for another update.
* Breeching ropes are finished.
* Skylights have the windows in place and grills stuck over them. I glazed the skylights with clear seal, which gives a really nice old effect. I much prefer it to using clear plastic... Sorry about the pictures... they don't really capture it.
* Built the ladder to go inside the companionway (although it turns out you can barely see it at all through the partly open doors... - I know it's there! :) )
* Put the windlass together, and the pawl bitts.
* Added the flue and trim in front of the grating.
* Put more eyelets and cleats onto the deck.
* I've also glued lots of these parts onto the deck now (except the windlass and pawl bitts). Need to read up on making square holes to complete the windlass, and put pins in the bottom to locate them firmly.
Think that's pretty much it. Hawse holes and scuppers next :)
Edited by robdurant
Time for another update, now I've had the chance to make a little progress...
First, the channels placed together (those brass photo-etch deadeye strops are fiddly little blighters, aren't they :S )
Then I turned my attention to the rudder... The area above the plating was painted first (before plating), and the plating put on... where the rudder post comes above the deck, I'm leaving it natural. I've also drilled and filed out the square hole for the tiller. I was dreading this, but taking it slowly, it went okay.  Next the pintles and gudgeons were fitted, and the rudder put in place...
Finally, last night I started the elm-tree pumps:
Thinking it'd be worth putting a band round the top to add a little detail? What do people think?
I've been using a small pillar drill for the holes... it'd be a real fiddle without it. It's really come into its own over the past few tasks.
Happy building!
Rob
Edited by robdurant
A little update...
I've completed the fore-bitts, and painted the pumps. I haven't put 'iron' bands on them yet, but I may do that before they go onto the deck. Otherwise, it's just navel pipes to put into the deck, and I'm onto the bowsprit and masts! (I also departed from the official colour scheme, because I preferred it this way :) (and it's my model ;) )
You can barely see that big gash in the upright with the naked eye, but lighting and camera seem to be conspiring against me!! Oh well... back to the sandpaper!
Happy building
Rob
Hi Rob,
Yet another Pickle! What fun. I'm just about to start this model and I see there is even another build by spyglass.
Where did you get the little sailors? They look wonderful.
Best Regards,
Rick Shousha
Montreal
Rick Shousha
Montreal
Hi Rick,
They really are fantastically designed and prepared models... really good fun (if a little fiddly in places - the carronades especially). The figures are Amati, and I got them from Cornwall Model Boats (in the UK), here:
http://www.cornwallmodelboats.co.uk/acatalog/amati_crew.html
It's so helpful having other people building the same kit... it really adds depth and insight to the (very good) plans and instructions provided by Jotika, and gives hints on how things can be improved as you go... It also helps to avoid the pit-falls that I suspect I'd be jumping into all too easily otherwise.
I'm sure you'll get great pleasure from building this kit... It'd be great to see a build log as and when you start :)
Rob
Edited by robdurant
More progress...
I thought it would be nice to try and get some reasonable photos of Pickle around about the half-way stage... so here they are...
I've also started making up the masts... (although they're all dry-fitted without fids at the moment)
Still not decided on the colour scheme for the masts... we'll see. Probably yellow ochre below the tops, black at the tops, and something above... (but what??)
Happy building
Rob
Greetings,
I`m partial to Timbermate. It comes in a variety of colours and can be thinned with a little water. Bondo is, of course, wonderful but, you`ll have red dust in your house for a month.
Now, I have to get back to my own Pickle build. I will have questions of my own tomorrow.
Best Regards.
Rick
Rick Shousha
Montreal
Thanks Rick, Jim,
I've never used something like that timbermate before... my previous models have all been fibreglass / styrene / etc... so a very different deal, but it does look like it could come in handy. Love this forum! I'm learning all the time. Good to have the warning about the dust, too... I build on the dining table, so I suspect that wouldn't go down too well.
I'll have to get down to the local diy store and take a look around.
Rob
I just used Timbermate with one of my daughters on a school project. We used it on a small balsa paddle and it worked out just fine. i was afraid the balsa would sand off around the filler but it was just right. I'm always afraid to use filler that is harder than the surrounding area. It's really hard to even out surfaces when that happens.
Actually, I really should put up a picture or two of the paddle. She put a Haida killer whale design on it stretching from one side to the other. it's pretty cool and makes me realize how much creativity we lose as we get older.
Cheers,
Rick
Rick Shousha
Montreal
So... I made up my mind. I really like the idea of the timbermate, but I wanted to avoid the walnut look, and I'd used walnut further up the main topmast than suggested in the instructions... so painting it was...
I finished putting the rest of the detailing onto the main mast today, and also started work on the crossjack (main yard). I only bought some digital vernier calipers a couple of weeks ago, but I don't know what I'd do without them now.
I also realised that leaving some full diameter wood at either end of the piece I was working on the lathe REALLY helped... Probably sounds totally obvious, but I was having all sorts of problems with it jumping out of true and splitting before, and now it's much better.
(I haven't trimmed the ends off in this shot)
More photos (and hopefully progress to show soon :)
Happy building
Rob
OK, so I'll have to get that Proxxon saw and then a nice, little lathe.
Eventually, i absolutely have to get a laser-cutter of my own, though.
Regards,
Rick
Rick Shousha
Montreal
So... time for another update. Not a lot to update, really, but just about enough to make an update worthwhile.
Yards complete, and driver boom ready for painting.
I've put pins in the schooner (fore) mast to take the yards and keep them in position during rigging.
I managed to make the 3mm rod shatter on the lathe, and there's only just enough in the kit to do the whole job, so I've ordered some more ready to do the remaining parts...
Happy building :)
Rob
Aah, yes. And I meant to say: Thanks Eamonn. Yes, it's moving along pretty well, now. I wasn't sure how the rigging would go, but so far, it's not too bad.
A sharp pair of sewing scissors, tweezers and good lighting seem to make all the difference... (although I still seem to need to attempt everything at least five times before it works out the way I'm after.
I also realised that one of the carronades was in the wrong place... it would have been in the way of the ship's boat... so I've moved that, too. Must remember, measure twice, cut once!
Take care
Rob
Time for another update... Hope you all had a very happy Christmas a new year :)
* Final spars are lathed and ready to go...
* Detailing put on the crossjack
* Pendants are on (I'll seize them to the foremost shrouds when the ratlines are tied and I'm comfortable everything's nice and taught.
and finally
* I've started putting on the shrouds...
You can see the little pile of jigs to keep the deadeyes in the right place while they're tied off. (32 in all, just for a little schooner... )
As always, all hints, tips and comments are appreciated and welcomed :)
Happy building
Rob
Yes, she does look a little lop-sided, doesn't she :)
Time for an update...
more standing rigging...
* I've finished the ratlines
* Made the mouse on each stay that requires one... I did this by wrapping the thread round a plastic tube with superglue on it... This could then be trimmed and glued on to the stay in the right position. I touched up each end with a little paint to cover up the white styrene ends...
* Put on the stays on the foremast and the schooner stay for the main mast (these are in place, but only temporarily fixed (by belaying them in the wrong place), before I finally fix the bitts.
Pleased with how it's coming on. The Jotika plans and instructions are excellent... even so I've had to stop and think about each stage before I've gone ahead... and even then I've had to undo and retie various bits as I haven't quite got it right...
Finally, here's how it looks so far... (sorry about the picture quality on that one)
Things may slow down for a while now, as I'm moving house across the country next month.
Happy building and thanks for the likes.
Rob
Thanks for the kind words, Eamonn. It's not up to your Ballahoo, which looks fantastic!, but I'm pleased with how it's turning out so far. Not far to go now!
Well, Pickle's moved...
A few more bits of rigging and a little tidying up... and a picture of Pickle in her temporary home with Royal Yacht Caroline...
Happy building :) Should be in the new house by the time I post again.
Rob
Edited by robdurant
