Picked up an old Model Shipways Gjoa kit.  The hull is not the usual basswood or mahogany I have seen in other MSW kits.  It is a fairly hard light brown with dark brown flecks in it.  Straight, coarse grain.  I thought it might be pine but haven't seen any with the brown flecks before.  Any ideas?
Edited by grsjax
My advice and comments are always worth what you paid for them.
Maybe you could post a close up picture/pictures from different planes?
Tony
Good point.  I have added 4 pics to the original post that show the flecks.  I thought they might be stains but a close look indicates they are part of the grain structure.
Oh, it's a solid hull.  I was thinking planking strips.  I'm guessing pine then.  MS used to use that, and far as I know, they still do.
Yes it looks like Pine to me, however there are quite a few different types of pine, and without a clear image of the grain and pore structure it is difficult to tell which one, there is a website, the name eludes me right at the moment where there are images of the structure of different woods that you could match to find out exactly which species of Pine if in fact it is pine.
Michael
Thanks for the info.  Found a website www.wood-database.com that has pictures of several different pine woods.  Looks like the hull is most likely eastern white pine.  Still not 100% sure but it makes sense that white pine would be used for a model boat hull.
I believe you are dealing with sugar pine. A good carving wood that is still used for professional towing tank models.
Pete Jaquith
Shipbuilder
Pete Jaquith
Shipbuilder
