I had a build log of Pilar before the content was lost and wanted to repost the photos.  Pilar was Ernest Hemingway’s faithful yacht, notorious for chasing big Marlin, Tuna and German u-boats.  Many people call it The Pilar or El Pilar, but it is just Pilar.  I posted a history of Pilar on the Nautical History Forum for those who are interested.
The plans come with color photos
The kit includes Lime, Ayous, Mansonia, Mukali & Sapele
First step is to fix the bulkheads to the keel.
Scott     :pirate41:
Present Build
AL's "King of the Mississippi"
Future Build
AL's "San Francisco II"
AL's "Sanson"
Previous Builds
Constructo's "Louise" (Victorian Steam Launch)
Constructo's "Pilar" (Ernest Hemingway's Fishing Boat)
Midwest's "Maine Peapod"
I know the importance of the frame being perfectly straight, so I wanted to come up with a jig that would keep the keel from twisting and at 90 degrees to the bulkheads.
Keeping the keel straight
Fixing the bulkheads
Bulkheads fixed
Frame complete
Next will be to plank and attach the bridge deck.
Scott     :pirate41:
Present Build
Future Build
AL's "Sanson"
Previous Builds
I decided to alternate Mansonia and Sapele veneer to plank the bridge deck.
Bridge deck planked and attached
Hemingway ordered Pilar with the back 10 feet of the stern lowered 1 foot for fishing, so the main deck is 2 pieces.
Aft main deck reinforcements attached
Bending aft main deck
Aft main deck attached
Fore main deck attached
Main decks attached
Next will be to fair the frame in preparation for planking.
Edited by birchbaysider
Scott     :pirate41:
Present Build
Future Build
AL's "Sanson"
Previous Builds
Frame faired and ready to plank with Balsa filler blocks at the bow
Attaching garboard strake alongside keel
Attaching sheer strake
Since Pilar's stern had been lowered 1 foot for fishing, the first strake from the top to extend the length of the hull would be the third one down.
Garboard & sheer strakes attached
Next will be to take some measurements and plan how to finish planking the hull.
Scott     :pirate41:
Present Build
Future Build
AL's "Sanson"
Previous Builds
I put temporary battens in place and marked the positions with tape.  Due to the shape of the hull, the way the planks wanted to naturally lay was to pile up on top of each other near the bow, so I thought this boat would be a challenge to plank.  But since almost every plank needed to be tapered one half width at the bow they were easy to bend into position.
Temporary batten
Temporary battens position marked with tape
First strake next to the garboard
Halfway
Near finished
Planking complete
Hull sanded and ready to paint
Next step will be work on the stem and keel.
Scott     :pirate41:
Present Build
Future Build
AL's "Sanson"
Previous Builds
You make planking look like a piece o' cake. Very impressive.
D'Brat
Current Build - Bluenose II - AL
In the wings - HMS Supply - AL
Cutting the rabbet for the stem took some time getting it straight, the right depth and width so there would be no gaps.
Rabbet cut, stem bent & keel planked with Mansonia veneer
Planking the aft main deck with Sapele veneer
Planking the fore main deck
Main deck planked
I built the display stand to hold the hull steady while marking the waterline.
Display stand planked with Sapele veneer
Brewed some joe & marked the waterline
Next will be to start construction of the cabin.
Scott     :pirate41:
Present Build
Future Build
AL's "Sanson"
Previous Builds
Planking cabin sides
Visible portions of cabin & bridge parts planked
Attaching cabin sides
Bridge window frame & cabin front planked & attached
Next will be to construct the cabin roof.
Scott     :pirate41:
Present Build
Future Build
AL's "Sanson"
Previous Builds
Cabin roof attached
Planking cabin roof
Cabin roof completed
The bridge console frame had to be carefully shaped to fit in place and then removed for completion.
Bridge console
Cabin door made from varying grain types of Sapele strips with some decorative carving
Completed bridge console
Next up will be to add some edge trim and varnish everything topside.
Scott     :pirate41:
Present Build
Future Build
AL's "Sanson"
Previous Builds
Mansonia edge trim & window frames installed
Poop deck supports attached & everything topside varnished
I had some Sapele veneer from a previous build that was a different grain type than the veneer that was supplied with this kit and alternated them on the cabin roof.
Sapele veneer
Cabin roof
Next will be to construct the seats and complete the bridge.
Scott     :pirate41:
Present Build
Future Build
AL's "Sanson"
Previous Builds
Bench seats
Captain's chair
Fish fightin' chair
I thought that Pilar needed a gaff hook to land all those big Marlin and Tuna so I fished a barbless hook out of my tackle box and made one trying to make it look well used.
Gaff hook with wrapped handle for improved grip
Bridge completed
Next will be to build the hatch frames and complete the poop deck.
Scott     :pirate41:
Present Build
Future Build
AL's "Sanson"
Previous Builds
Hatch frames
Poop deck frame
Poop deck frame attached
Poop deck underside
I installed the acetate windows and kept accidentally poking them out, so I put some temporary covers over them.
Poop deck attached
Mast frame, anchor cover, companionway door & lid installed
Next will be to paint the hull.
Scott     :pirate41:
Present Build
Future Build
AL's "Sanson"
Previous Builds
Originally, Hemingway ordered the hull to be painted black.  After a few years he had the hull re-planked with Mahogany and it was left all natural above the waterline.  The kit shows white below the waterline with all natural wood above.  The restored Pilar in Cuba has a red, yellow and black hull with green and natural wood above deck.  The pilar replica in Florida has red and black below the waterline with natural wood and green above.
Early years of Pilar at sea
Restored Pilar in Cuba
Pilar replica in Florida
I like this color scheme because of the contrast between the white, black, red waterline and natural Sapele wood.
Next will be to construct the flying bridge.
Scott     :pirate41:
Present Build
Future Build
AL's "Sanson"
Previous Builds
This is a wonderful visual diary of a beautiful build.  As I get ready for the next steps with the Pilar, I want to thank you for taking the time to reconstruct your log.
"Go placidly amid the noise and haste, and remember what peace there may be in silence." - Desiderata by Max Ehrmann
Thanks for the comment, Jon.  There's not much info on this kit and I wanted to share my build log with others who are interested in this famous American fishing boat.
Scott     :pirate41:
Present Build
Future Build
AL's "Sanson"
Previous Builds
I'm not fond of working with metal, so the flying bridge was a challenge.
Marking holes to be drilled for the flying bridge
Installing flying bridge railing supports
As you can see in the photo, Pilar actually had six galvanized pipes running from the bridge up through the poop deck to the flying bridge, but the model has two.
Hemingway at the helm
Flying bridge platform made from Mansonia strips
Flying bridge complete
I alternated grain types of Sapele veneer on the poop deck like on the cabin roof and I think it turned out looking fine.
Next step will be to work on the skylight, prop and rudder and small metal components.
Scott     :pirate41:
Present Build
Future Build
AL's "Sanson"
Previous Builds
I painted the cabin roof black below the skylight to give the impression that the dark cabin is below.
Skylight
Lights, cross bitt & air shafts painted
Port holes, air shafts & position light
The model has one prop, but Pilar actually had twin screws.  Hemingway ordered the boat with a 40 hp 4-cylinder Lycoming engine for trolling in addition to the standard 75 hp Chrysler Crown reduction gear engine.
Prop & rudder
Nameplate, stern roller, stern cleats & live well frame
Scott     :pirate41:
Present Build
Future Build
AL's "Sanson"
Previous Builds
Greetings Scott,
Nice model of Pilar. Wooden Boat magazine did an in depth article on her recently. I wish I had kept that issue. After seeing your build, I will be getting the kit soon. It will be good to get away from spars, guns, rigging, etc. for a while. She looks to be not much more than 24", so she is a good size too. I might try to model an engine for her as well. If remember the article, her main engine was a gasoline fueled flat head straight 6 cylinder, but she also had a smaller engine for trolling. Very interesting model and I give credit to Constructo for manufacturing the kit. Also, your work on her is top notch.
wq3296
Greetings Scott,
Relative to your message, the Wooden Boat issue in question could have been as far back as Sept.-Oct., Nov.-Dec. of '13. Yes, library will be a good option.
wq3296
Thanks for the info.  The article is in the July/August 2013 issue of Woodenboat Magazine.  I put a hold on it at my local library.
When Hemingway had the flying bridge added it came with a Model T steering wheel.
Scott     :pirate41:
Present Build
Future Build
AL's "Sanson"
Previous Builds
Greetings Scott,
I found an article online at www.woodenboatrepair.com. There is a picture of the Pilar replica showing the running gear. It is quite different from what the Constructo plans might show and truer to how she was built. You will note that the propeller shaft extends from the keel and is closer to horizontal, and that the shaft support is a casting. Further, the rudder is part of this skeg assembly, which is the way she would have been built. It looks as though Constructo was playing it by ear when they designed the running gear.
wq3296
Thanks for the link.  I've included it in my post on Pilar in the Nautical History Forum.
Scott     :pirate41:
Present Build
Future Build
AL's "Sanson"
Previous Builds
Pilar is finished, but sometime I would like to add outriggers and make it a real fishing boat.
I'm gonna need a bigger boat
Scott     :pirate41:
Present Build
Future Build
AL's "Sanson"
Previous Builds
Greetings Scott,
Really like the paint job and precise work. Good job. If you like older power boats, take a look at BlueJacket's 1941 Chris Craft mahogany runabout.
wq3296
Thanks for the compliment.  BlueJacket's Runabout looks like a great kit, but way out of my price range.
Scott     :pirate41:
Present Build
Future Build
AL's "Sanson"
Previous Builds
