Hi everyone,
To start pins for the first planking on a double-planked hull, any recommendations on a good pin pusher?  I used the Latina (or maybe Amati) Nail Nailer on my Badger, which worked fairly well.  It pushed nails into the plywood bulkheads just enough to hold the glued plank to the bulkheads, but not all the way in which made removal very easy.  I pulled mine out of storage this afternoon, and it looks like it's bent and no longer usable.  It wasn't built of the sturdiest construction, so I'm looking to see if there are any other options that people are happy with.
In the alternative, are their other preferable ways to pin the first planking to bulkheads?  I didn't particularly have much luck with hammering nails in with a ball peen hammer.  I thought about maybe using a Dremel to pre-drill holes, but the pin pusher seemed much easier.  I also saw that there are things called "T-Pins" out there, but not sure if they are all that helpful for planking work.
Thanks very much!
Hi  Mike
I use map pins And push them into the bulkhead adjacent to the plank I am gluing
The pins I use have a plastic head about 6mm in diameter which holds the plank
until the glue dries
Hope that helps
Regards
Ken
Under construction  US Brig Niagara
Completed  HMB Endeavour - Caldercraft
 Hi Mike:
  I too found the Amati pin pusher lacking. When I did some digging, I found the model railroading people use a pin pusher as well for the tracks.
 The one I got is very substantial fits into the palm of the hand and is thicker at the business end.
 They have different sizes for different pins. The other thing I found was the cost was cheaper than Amatis. Now this was approx. 7 or 8 years ago.
 Hope this helps you.
 Dave
Hi guys, thanks for the replies, I really appreciate it.  A few follow up questions if you don't mind.
Ken, are you able to push the map pins all the way to the hilt?  I found at least on my Badger that the bulkheads were too firm to just manually push the pins all the way in without pre-drilling holes.
Dave, do you remember where and what model your pin pusher is?
Tom, I saw those pliers last night and wondered if they were any good.  Thanks for the suggestion.  Micromark seems to offer three sizes in nails - do you recall which you use?
Hi Mike
Yes I can.
You have to be careful not to split the bulkhead ply.
But as you said pre drilling a hole could help
Regards
Ken
Hi Mike. I didn't buy any nails with the pliers, but have used them on all kinds of nails that I have received with various kits, as well as regular sewing pins.
I used a pin pushed for the inner planks, and you also can get them with an auto stop to prevent pushing in to far (have a look at CMB web site). I then used map pins for the outer planking, and found it best to use a small panel hammer to help push in
Glenn (UK)
Guest EricD
I use a pin vise to drill a hole big enough to take the nail in the plank and push the nail in and glue on the plank.  Then I give it a few taps with a hammer to hold it until the glue dries.  The small nails don't get in the way and you can easily pull them out with pliers.
