Grizzly had many interesting toys, ehh TOOLS ;)
BUT I guess they are all 110 V... Here we use 220-240V... :(
Cheers!
Finishing Titanic 1/350 scale from Minicraft, Plastic. Partly scratch. Loads of PhotoEtch.
Upcoming builds: Syren from MS 1:64, Pegasus from Victory Models 1:64, Surprise from AL 1:48
Cheers!
AC -converter/adapter is all you need, has worked for me before moving to the US :)
What I understand, Sherline is the machines!      If I only had the money... :(
Edited by Nirvana
Respectfully
Hi Ian
I use a scheppach DMT450  benchtop lathe. It costs about £280
It has a 1/2" through hole on the headstock which is important if turning long yads etc.
And a between centres of 445mm.
I added a 3 jaw chuck which helps a lot and I built a 3 roller fixed steady from MDF for it.
I have found it very good for spars and masts. I have turned all of my Victory ones even down to 2mm dia.
Of course at that diameter it is sandpaper rather than a chisel.
The steady is required if you go to that sort of dia.
http://www.amazon.co.uk/SCHEPPACH-DMT450-445mm-Woodturning-Lathe/dp/B00FBD2MMU/ref=sr_1_6?s=diy&ie=UTF8&qid=1407761322&sr=1-6&keywords=scheppach+lathe
Nick
What about this multi purpose machine?
The Unimat 83000  it seems to drill, lathe, mill and sand-- I am sure it could make the coffee to?
Just google Unimat 83000
HMAV Bounty 'Billings' completed
HMS Cheerful - Syren-Chuck' completed :)
Steam Pinnace 199 'Billings bashed' - completed
HMS Ledbury F30 --White Ensign -completed 😎
HMS Vanguard 'Victory models'-- completed :)
Bismarck Amati 1/200 --complete  👍
HMS WARRIOR Billings just started
Thanks for posting this, I love old machines.
That is a neat machine for 1852 and set up to use common power source. It looks like it has power feed and cross feed, Did not see change gears but lots of steps in the visible pulley's. wonder if threads could have been cut in a repeatable manor. Even dividing provisions. Be nice to have the resources to preserve that thing and make it available to others. Takes  high skill to take a rough casting, do some rough machining then hand truing and fitting everything. Each part being a unique piece, probably obtain castings for parts but need a good machinist to hand fit any replacements. Not just everyone would be allowed to run it. That machine and a metal Shaper could make almost anything to close tolerances.
jud
Edited by jud
Hi Ian B
On the Unimat question, they have nothing in commonm with the original unimats which were great little machines.  Personally they are OK but only OK once you get around all the time spent of changing from one function to another.
But it comes down to the question of what are you going to use it for and at what size.  As an example I have just sold my very large modern lathe/Mill with DRO's etc as I move away from model engineering and into ships again.  I will be using my 50 year old faircut junior http://www.modelenginemaker.com/index.php? which is more than sufficient and big enough.  more importantly its solid which means less vibration etc when cutting.
just my personal thoughts
Ian
Still Sane? who knows, who cares
Current Build Panart deck section
What a beautiful machine.  Good luck on the rebuild.
Bob
Current build:  SS_ Mariefred
Cheers Bob  must get cracking now my other machines have been sold.  its extremely solid which is why i like these older machines
Ian
