Continuation
Replacement of grating
The grating made originally from materials of a set are replaced with grating  from a pear.
Best regards,
Garward
Is under construction Montanes
Ready models Golden Star Corsair San Francisco II
Bronze 24-pdr canone Le Fleuron
Bronze 24-pdr canone Le Fleuron (second version)
Continuation
Best regards,
Garward
Hello Garward,
There's not much to say about your craftsmanship then just awesome. animaatjes-smiley-met-bordje-66050.gif
Take care,
Anja
Those we loved but lost are no longer where they were, but are always where we are.
In the gallery: Albatros 1840 - Constructo
Good evening, Anja! Many thanks for an assessment of my work  :)
Best regards,
Garward
Hello Garward, and good to see you back at MSW 2.0!
A big Thank You for re-posting a lot of your pictures. This is such a great log, since you share all your small devices that simplifies tedious tasks.
Happy modelling!
Håkan
Previous builds
Kågen by Wintergreen
Regina by Wintergreen
Billing Boats Wasa
Gallery:
Garward,
Seeing her grow like this again ... amazing. There is so much to see - I even forgot about those splendid quarter windows.
Carl
Hi Garward,
I see this now for the ( I think ) 100 times and still I'm amazed with what you are doing.
Tremendous job!
I can use a lot of things at my own build.
Thanks for the detailed  pictures!
Sjors
I'm not sure how I missed your build on the old site, but I'm definitely going to be following from now on! She's a beautiful ship!
Thanks for the comment!
Best regards,
Garward
I have to agree with Anja. Your craftmanship is top notch. Great build/
Thanks for an assessment!
Best regards,
Garward
Hello, Håkan, I am glad to see you on MSW 2.0! I decided to systematize the report as it really got the big sizes and I sometimes should spend a lot of time for searches of concrete messages.
Best regards,
Garward
Hi Garward,
Tremendous job!
Sjors
Hi, Sjors, Thanks for the comment, I will be glad if it is useful to you my experience of construction of Montanes!
Best regards,
Garward
9. MANUFACTURING BARGE
Barge it is made on Alexey Baranov (Hamedal) technology: on a punch it is made of a papier-mache (a paper and glue PVA) the case which becomes covered putty, is ground and pasted over with laths, are established keel, frames and other details.
9.1. The punch
The punch is made on a basis false keel and frame headrails of a set: after assemblage of these details intervals between frame headrails are filled balsa by inserts (the rests and scraps after case Montanes filling). The punch is ground till the sizes considering a thickness of a covering of the case barge.
Edited by Garward
Best regards,
Garward
9.2 .Hull gluing together
The punch is covered by the aluminium foil preventing sticking of a paper to a punch (one layer of paper and PVA).
Best regards,
Garward
Continuation
Best regards,
Garward
9.3 . Hull hard putty
The shell of the case is slightly ground from the outer side, Kiel is pasted and for durability giving the shell is covered with a layer of the two-component epoxy hard putty applied to car repairs. The external surface of the received preparation is ground under an external covering.
Best regards,
Garward
Continuation
Best regards,
Garward
9.4. Hull planking outside
Interline interval pear and ebony fine line of nominal thickness of 0,5 mm,
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
9.5 . Hull planking from within
Before a planking of an internal surface the foil layer is removed. The shell surface under a foil practically doesn't demand processing before a sticker of levels of a planking.
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
9.6. Installation of details
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
