Hello,
I recently posted an extensive tutorial on how to paint cast metal ornaments for ship models. In this tutorial I will skip the basics of preparing and priming your model detailed in the previous tutorial, and instead skip straight to painting some small scale historic figures.
Step 1: color block
The first step after priming your model is to block in its basic colors. Simply use a fine brush and paint the elements of the figure in the color you want. I advise to use a small amount of colors as this makes it easier and results in a better looking model. Using more than 4 or 5 different colors is usually a bad idea, as it will confuse the viewer and look amateuristic.
Note: For this tutorial I used a white primer because it photographs easier. Normally I would use a black primer as its easier to get good coverage. A white primer is harder to cover with colored paints, often needing two coats to get good coverage.
Step 2: Wash
After you have applied the colors on your model it does not look great... yet. A very easy way to bring out the details in your figure is to apply a wash. This is a specialised, watery thin ink that runs into the recesses of your model while staying clear of the raised areas (sort of). Paint manufacturers like Citadel and Vallejo have a range of these, in various colors and I can highly recommend them.
The trick with washes is to be very generous in applying them. Use a larger brush and "flood" your figure, allowing the ink to run over it and into all the recesses. If a certain area is heavily flooded, use a brush to wipe it into different areas of your model until you get an even coverage. Don't be put off if it looks "too much", after drying the effect is much more subtle. In fact you could use a second layer of wash after drying to get more intense shadows. Usually one application is enough though. Washes take a long time to dry (relatively speaking for acrylic paint) so you can speed things up with a blow dryer if you want.
I used Agrax Earthshade (brown) shade from Citadel on the entire figure. You could use different color washes on each section but I wanted to get this aged, slightly yellowed painting look anyway. Usually its not worth the trouble using a blue wash on blue parts etcetera unless you are aiming for a specific result. 99% of the time I use a black wash or a brown wash for everything.
Step 3: Highlights
Once the wash has dried your figures will look pretty good. One could stop here, if you are happy with the level of detail. However, with a bit more work the models can look even better.
By adding some highlights you further bring out the details and "depth" in your models. You could argue that the natural lighting falling onto your model is already doing that, but experience learns that small figures need "a little help" to augment this lighting. We do this by adding highlights to areas of the model that would naturally "catch" light. Usually the raised areas.
To make highlights simply apply a lighter color of the one underneath with a fine brush. Using acrylic paint its very easy to mix up a nice range of colors quickly. Be sure to thin down your paint a little bit wit water so it flows easily. Don't paint straight from the pot as it will give a blotchy result and often is a struggle to apply.
In the picture above I added lighter browns to the raised wrinkles in the trousers. I used a beige color to touch up the shirt of the guy on the right and the flesh/face parts on both figures. You can already see the model coming to life. Let's add some more detail highlights:
I mixed some lighter blue and touched on the jacket in places. Don't overdo it, just a few small fine lines here and there is all it needs. I used white to clean up parts on the left guy, his belts and ends of the jacket arms. I used a gray to highlight the black hat and boots, with a fine pure white dot on the boots to suggest "gloss". The shirt of the guy on the right was finished using some lighter beiges.
Finished & Some Thoughts
Here's some pictures of the finished figures, which took less than 1 hour to paint up.
Some final thoughts I'd like to share on painting miniatures like this:
Small scales:
As you can see from the examples above, small figures like these don't hold up well when photographed up extremely close. The result can look disappointing when in reality when viewed from a normal distance they look fine/great.
Keep in mind that when painting on a very small scale (these are 1:85 I believe) it is really difficult to paint each individual detail. Often the detail is simply not present in the cast model, because of its small size. Things like eyes, lips or even hands are merely "suggested" at than really sculpted. This calls for a more "suggested" style of painting too. You should aim to get an overal look of a figure, letting the shadows and highlights doing its work. By keeping things a bit vague you let our brain "fill in the blanks" often giving a much better effect than trying to paint in all details. Overdoing the highlights or trying to paint in eyes or other small details often results in a weird cartoonish look.
Another couple of figures I did on this scale:
Take it easy
Don't worry too much about making things perfect. Even if you do a color block and 1 layer of wash, your models will already look great. Applying the small highlights is something learned with practise. I encourage you to give it a try, as you might be surprised about yourself. Even if you do it in a basic fashion it will provide awesome results. Whatever you do I assure you you can do better than just flat-coated figures with awful shiny Humbrol.
Love to hear your experiences, if you paint something up using my tutorial post some pictures here for us to see!
Edited by ChrisLinden
Finished: Pinta, Amati
Current Build:  Friesland Mamoli 1:75
Another excellent tutorial Chris. Thanks so much for taking the time and effort to develop this and share it with us all - especially those of us who are "chromatically challenged".
Maybe someone should suggest to the mods and admins that this and your other painting tutorial should be put onto the database with the other tips and tutorials. These are both great for beginner and experienced modellers alike.
Carl
Completed builds: AL Bluenose II 1:75  Gallery
                              Amati Hannah SIB 1:300  Gallery
Current Build: Bluenose II - SIB - unknown scale
  • 1 year later...
I have used this technique to paint the figures for my latest build, the Italeri MTB 74 (scale 1:35), and am happy to say that it works wonders. The Citadel washes (such as Nuln Oil) are water based, so can be watered down to cater for a lighter wash on the faces and hand. Thanks Chris for posting this.
Cheers,
Jonny
Caldercraft HM Cutter Sherbourne Kit Bash - Scale 1:64 - http://modelshipworld.com/index.php/topic/10547-hm-cutter-sherbourne-by-jonnyamy-caldercraft-kit-bash-scale-164/#entry317289
!!!ON HOLD!!! Mantura/Sergal HMS President - Scale 1:60 - http://modelshipworld.com/index.php/topic/5589-hms-president-by-jonnyamy-circa-1760-sergal-160/
In the Pipeline:
18th Century Longboat - Scale 1;48 - - http://modelshipworld.com/index.php/topic/11273-18th-century-longboat-model-shipways-by-jonnyamy/
Completed Builds:
40 Foot Gaff Cutter - Solid Hull Concept Model
Caldercrafter HM Mortar Vessel Convulsion - Scale 1:64 - http://modelshipworld.com/index.php/topic/8593-hm-mortor-vessel-convulsion-by-jonnyamy/
SCRATCH BUILD - Vagabond 19 foot Sloop - Scale 1:20 - http://modelshipworld.com/index.php/topic/10172-vagabond-19-6-keel-sloop-pob-scale-120-by-jonnyamy-small/#entry302726
  • 8 months later...
Cheers,
Jonny
Glad it helped! Looks fantastic Johnny
