Looks like she's got a nice smooth surface to work with. Great job on the fiberglass/resin finish.
Hello Carl , thank you for your nice words on my effort to test  new materials such as fiberglass and resin.I also thank you for your likes.
Regards
Dimitris
Current Build: Amerigo Vespucci -Mantua- 1:100 scale
Completed Build logs: Bluenose II AL 1:75 scale
Gallery: Bluenose II AL 1:75 scale
Future Build: Royal Caroline -Panart- 1:47 scale
Lovely work Dimitris.
Just spent  time looking through your build so far, stunning work and your use of photo etch.
All in 1/100 gauge too.
Frank :piratebo5:
Hello Frank, welcome aboard , thank you for your nice comments and also for your time to read my build log.
Regards
Dimitris
Hello Dimitris,Kudos for trying this fiberglass method of hull covering,from the sample I understand why your  going this route, who was it that said "your a braver (better)man than I Gunga Din". Nice work on the decks,Well done, will follow.Edwin
Hello Edwin , welcome aboard . The truth is that i was a bit afraid of this method (since this is my second build) , but it proved to be not that hard.I thank you  for your nice words and also for your like.
Regards
Dimitris
Excellent work Dimitris!!!!!!
Kind Regards
Nigel
Hello Nigel , thank you for your encouragement words, your tips and also for your likes. :)
Regards
Dimitris
Hello Shipmates, a small update... I applied a second hand of car primer to the ship, the first one sanded with 400 grid.Some photos. :)
Regards
Dimitris
Hello shipmates, Mike I thank you for your nice comments for visiting my build log and also for your like!! :) :)
Nigel thank you for your likes and for visiting my build log!! :) :)
Kind Regards
Dimitris
Hi Dimitris
Great work and a lot of ideas that you are showing on your Amerigo Vespucci, you are showing a great skill of using fiber glass and epoxy . I just love all of your very fine deck detail, ENJOY.
Regards Lawrence
Hi Lawrence, thank you very much for your kind comments and also for your likes. As I said before I am determined to do my best on this kit (at least I will try, due to my limited experience on ship building). The instructions of mantua (In 1/100 scale kit only) have several flaws , so it is a bit of a struggle to understand whats going on . It will take a lot of patience and persistence  in the future... but that's the beauty of shipbuilding i guess... :) :)
Kind Regards
Dimitris
Hello shipmates, the 4th and the last coat of car primer it is done. Now it needs one more sanding with 400 grid sandpaper and it is ready for painting. Some photographs.. :)
Regards
Dimitris
You have made an excellent job of the glassing Dimitris!!
Kind Regards
Nigel
Good day Nigel, thank you for your kind words the likes and for your many visits to my build log.
Kind Regards
Dimitris
Dimitris,
Very very nice result there! That looks very smooth. Beautiful.
Cheers
Elia
Hello Elia, I thank you for your nice comments, for visiting my build log and also for your likes.
Regards :)
Dimitris
Hello shipmates , i would like to ask for your help on the following matter. The time has come for me to draw the waterline and the black and white strips on Amerigo's hull. I understand how to draw the waterline  since  it is parallel to the keel (i.e using a pencil jig). The black and white strips though seem to follow the deck lines as shown at the plans. Do you think  I should use a pencil jig for these lines also ? In  such a case, should the pencil jig's guide touch-follow the deck's ? I'll be grateful for any help and suggestions.
Kind regards
Dimitris
Hello shipmates,I thank you all for visiting my build log and also for your likes. A little  progress to my build.
Cheers :)
Dimitris
Greetings to all. Nigel-Carl-Brian , thank you for visiting my build log and also for your likes. Another small update to my build...
Cheers :)
Dimitris
Edited by Dimitris71
Hello Dimitris, WOW ,a totally awesome job on the finishing of the hull and porthole lines,To be truthful and as it was your first time you exceeded my expectations using this method, I kept your method for a future use. thanks Edwin
Hello shipmates! Elia thank you for visiting my build log and also for your likes. Mike thank you for your kind and encouragement words and also for your likes.
Edwin I thank you also for your visits to my build log and for nice and encouragement comments. And of course for your likes.
Lawrence thank you for your likes  for visiting my build log and also for your very encouragement and nice words about my work.
Now regarding the painting of the ship I use Vallejo model air with an airbrush.The primer was not Vallejo and on the second white stripe i noticed that the paint did not seem well attached. So i decide to remove the paint and applying a Vallejo surface primer that is surely compatible with Vallejo Paints.Also I noticed that Vallejo primer has more sticky texture. (Just in case to avoid future problems).
Cheers :)
Dimitris
Hello shipmates , Lawrence-Xristos and Mikegerber , Thank you for visiting my build log and also for your likes. :) :)
A small update...
Hello Dimitris, Awesome paint job, thanks for explaining the procedure ,I have been researching and debating with myself on which spray system to get,there so many and being a novice paint wise does not help,so thanks.Edwin.
Hello my friends, Edwin, I thank you for visiting my build log, for your nice comments and also for your likes. I am very glad that  I helped you . If you have any questions about painting procedures let me know.
Elia I thank you too for your nice comments, for visiting my build log and also for your likes.
Mike thank you for visiting my build log and also for your likes.
I did some additional work...
Cheers
Dimitris :)
Hello shipmates, Lawrence ,I thank you for your kind words for passing by and also for your likes. Edwin-Elia-Mike I thank you for visiting my build log and also for your likes.
I applied one more hand of red paint to the hull.
Cheers
Dimitris :)
Hello shipmates.
Carl thank you for passing by and also for your likes.
Elia, thank you for your nice words and also for your likes.
Mike, thank you for your likes and also for your kind words.
A Sunday update....
Cheers :)
Dimitris
