I'm wondering how other molders store their fine saws. I must had a dozen or more in two different categories. One for regular cuts and the other for metal or harder woods. I want a way to store them so they will be readily available yet not so lose as to damage the blades. There must be a way. I'm sure you have the answer.
Thanks in advance for your help.
Larry
Sorry, I left out the "hand" part of this....hand saws.....I must be getting old(er)....
Edited by LFrankCPA
I wrap them in oil impregnated paper and store them in a drawer in my work table.  The paper is the kind that is used to wrap metal parts like bearings.
My advice and comments are always worth what you paid for them.
If, you have the wallspace, get some pegboard and hooks and hang them.
I trace out the saw on a piece of 3/4" pine board, and then add 3/4" all around.  Then I glue a 3/4" x 1/4" strip on the tooth-side of the tracing.  Then I drill and embed a couple magnets into the board and stick the saw to the magnets.  The wooden strip on the tooth-side locates the saw on the board and protects the teeth.   Then you can screw the board to the wall, or carry it around as needed.  I also have made a 'holster' for my japanese saws, sort of like a six-gun belt holster.  It works for me.
Edited by Bob Blarney
  • 11 months later...
I made the description, of the idea of a shopbuilt magnetic holder too complex to understand.  It's quite easy to do.
Oh, and a light spraying/wipedown of vegetable-based kitchen canola oil (i.e. rapeseed) such as PAM, works well  against rust, and can be washed off easily with soap and water.
Always used CR-56 or WD-40 on all my blades, power and hand saws. It's light, and easier to wipe off when you need to use the saw.
GEORGE
Take a length of plastic hose 1/4 inch 6mm, cut to length of the saw blade, slit full length then slide over the cutting edge to protect the teeth even when hug on the shop wall.
Current Build
HM Granado CC
Past builds
 HMS Chatham CC, HM Convulsion CC,  Duke William German Kit, Fair American LSS, The Wright Flyer MS
