Welcome to Model Ship World
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. If you already have an account, login here - otherwise create an account for free today!
A Lorch Micro-Mill that never was ...
  • Please log in to reply
90 replies to this topic
#81
Dupree Allen
Dupree Allen
  • Members
  • 76 posts
  • LocationClarksville, AR
A very exciting journey through the eyes of an accomplished machinist and tool maker. Although most of us will never achieve this extreme level of tool making, it is an amazing example of work that can't be ignored. What a group of artisans who add new meaning to "We can build nearly anything from very little."
Edited by Dupree Allen, 29 December 2016 - 09:15 PM.
  • mtaylor and reklein like this
Dupree
"A slow steady hand conquers a fast shaky mind" - me
HMS Triton 1:32 Cross Section
#82
  • Members
  • 759 posts
  • LocationParis, France
Thanks for the kind words. Well, actually most of the really serious machining (namely the guides for the slides) was done decades ago by the Lorch-guys in Frankfurt/Germany. That really cannot be done with 'nothing', but requires a bigger and sturdier milling machine than I have. The quality of their workmanship is difficult to find these days. I also wished I could work with cast parts, rather than having to fabricate them.
About the scale: sorry, I am so familiar with the size of these machines, that did not think of adding a scale. The overall height of it is 35 cm or 14". for those across the water.
One of the most important aspects of the machine is the flexiblity in holding even tiny work-pieces. The dividing head offers a wide variety of work-holding options using the spindle-tools from the 6 mm-lathe, such as 3- and 6-jaw-scroll-chucks, independent 4-jaw-chucks, ring- and step-chucks, face-plates, as well as the whole range of collets from 0.3 mm to 14 mm diameter.
3-jaw chuck
Step-chuck
Ring-chuck
Independent 4-jaw-chuck
A very old face-plate (I have newer model too, but this is not refurbished yet)
The dividing head can be positioned at any angle between vertical and horizontal. Direct dividing is provided for by a drum with three rows of 8, 10, and 12 indents respectively. This allows the milling of prisms or pyramids with 2, 3, 4, 5, 6, 8, 10, or 12 sides. A worm-wheel of 40 teeth that is driven by worm on the axis of which is mounted a dividing plate with 90 teeth provides for indirect division of up to 3600. While such divisions are unlikely to occur in practice, the fine angular movement is useful for shape-milling against a schedule table. When the indent is disengaged the worm-drive can be used for round-milling.
Dividing head in horizontal position
Dividing head set at an angle
Worm and dividing plate for indirect dividing
Collets for work-holding are particularly useful, as a wide variety of small parts can actually by milled from round material of various diameters and then sawn-off from the stem held in the collet. The collets, a holder for standard 6 mm end-mills, arbors for slitting saws, as well as a small boring-head are stored in a fitted antique box.
Antique collet box adapted to the use with the micro-mill
To be continued ...
Edited by wefalck, 29 December 2016 - 11:19 PM.
  • cog, mtaylor, WackoWolf and 9 others like this
#83
BANYAN
BANYAN
  • SPECIAL CONTRIBUTOR
  • 1,950 posts
  • LocationMelbourne, Victoria
Aghh! Now you have done it - I am very jealous of that fabulous set-up :)  Some great flexibility of function you have created in that machine Wefalck.  Any left-over bits I could you use with my Lanco?  (Sorry being a bit cheeky there).  Seriuosly, a really useful set up for small part machining.
cheers
Pat
Edited by BANYAN, 29 December 2016 - 10:56 PM.
  • cog, mtaylor and donrobinson like this
Current build: HMCSS Victoria (Scratch) - underway
Next builds:    HMAS Vampire (3D printed resin 1:350)
Built:                Battle Station (Scratch)
                         HM Bark Endeavour 1768 (1:64)
#84
  • Members
  • 759 posts
Tonight I did some test-runs and made some short videos, showing the machine in action:
http://www.maritima-...urces/MF-V1.mov
http://www.maritima-...urces/MF-V2.mov
http://www.maritima-...urces/MF-V3.mov
http://www.maritima-...urces/MF-V4.mov
:champagne:
  • mtaylor, WackoWolf and aviaamator like this
#85
cog
cog
  • Members
  • 3,201 posts
  • LocationGelderland, Netherlands
Wefalk,
The only result I get from your videos are errors both on Quicktime and on VLC
  • mtaylor, WackoWolf and jud like this
Carl
Builds
Kit Wood
Dolphyn [Corel] 1:68, Higaki Kaisen [Woody Joe] 1:72
Kit Plastic
IJN Musashi [Tamiya] 1:350
Finished builds
Scratch: Sea Witch 1:109
#86
  • Members
  • 759 posts
OK, it appears that some people had problems with displaying the movies on non-Apple devices. Here another try:
http://www.maritima-...omill/MF-V1.mp4
http://www.maritima-...omill/MF-V2.mp4
http://www.maritima-...omill/MF-V3.mp4
http://www.maritima-...omill/MF-V4.mp4
http://www.maritima-...omill/MF-V5.mp4
http://www.maritima-...omill/MF-V6.mp4
  • mtaylor, BANYAN, druxey and 2 others like this
#87
donrobinson
donrobinson
  • Members
  • 1,315 posts
  • LocationPrince Albert Saskatchewan Canada
Very nice machine
#88
cog
cog
  • Members
  • 3,201 posts
Thank you for changing the video type Wefalck
  • mtaylor and BANYAN like this
Carl
Builds
Kit Wood
Kit Plastic
Finished builds
#89
  • Members
  • 759 posts
Hope everyone arrived well in the New Year !
Here a few additional pictures of the machine with the attachment for indirect dividing mounted. It also shows the over-arm (or rather under-arm) to support longer and slender parts. Both were already fabricated some 15 years ago for the use on my lathe.
The first picture also show a micrometer depth-stop for the vertical slide, which was made some 20 years for use on the small 6 mm-watchmakers lathe.
  • cog, mtaylor, WackoWolf and 4 others like this
#90
mtaylor
mtaylor
    Bilge Rat
  • 14,221 posts
  • LocationMedford, OR
Pure engineering artistry, Wefalck.
  • cog, WackoWolf and druxey like this
Licorne - 1755 from Hahn Plans (Scratch) Version 2.0
Triton Cross-Section
USS Constellaton (kit bashed to 1854 Sloop of War (Gallery) Build Log
Wasa (Gallery)
#91
michael mott
michael mott
  • Members
  • 3,570 posts
  • LocationLake Wabumun, Alberta, Canada
Lovely Machine, was good to see it in action also I now have a better sense of the size.
Michael
  • cog, mtaylor, WackoWolf and 1 other like this
Current builds  Bristol Pilot Cutter 1:8
                                Skipjack 19 foot Launch 1:8
                               Herreshoff Buzzards Bay 14 1:8
Other projects  Pilot Cutter 1:500
                         Maria, Sloop 1:2
Restoration      A Bassett Lowke steamship Albertic 1:100
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
Welcome GUEST to the Model Ship World Community.
Please LOGIN or REGISTER to use all of our feautures.
