Mike Dowling
Everything posted by Mike Dowling
  1. Hi again already!!! Can anyone tell me what 'bowsprit bees' are and what they are for
  2. Please could somebody tell me what 'bowsprit bees' are and hat they are for.
  3. Oh don't I just know it - like I said I have done the easy bit and guess what - there are no instructions at all, just plans to work from!! There have to be easier hobbies than this! Anyway, thanks all for the kind comments so far!
  4. So, that's the easy part done. Next the masts, spars, rigging etc etc. Before I start here are some views from the mast before I start them!!
  5. Hello all! I have now finished the hull ! There are a few accessories like barrels etc to add but they will wait until I come to the end as I don't want them rattling about. A few bits to do on the launch as well but they also will wait. Thought you would like a few pics. For the purists amongst you out there I have made a couple of minor modifications and I may give prizes for anyone that can find them!!!. The fact that it is not painted is not a modification but personal choice so no prizes for that.
  6. I can't stand football and have been getting on with my boat!! Look forward to seeing your pics though.
  7. Hello all, Thought it was time I posted an update on progress. I have now finished the basic hull complete with rubbing strakes, the keel and the rudder. I made a complete mess of the rudder by gluing the hinges in the wrong places with CA glue. However, with a lot of cellulose thinner, a lot of patience and a lot of bad language I managed to get them off and start again! The whole thing has had at least (!!!) two coats of satin varnish and just for good measure I veneered the edges of the bulkheads and decks on the exposed side. The time spent was worth it I think. Next, all the deck accessories and fittings to be done!
  8. Very nice of you CF and many thanks to you for your help and tuition. I know I didn't use your fan template on the second go but you did make me realise the importance and technique of tapering without which I would now have a clinker built barge!!!
  9. Oops, missed a point there! The reason my transom is pale is because my kit states the pale sections should be painted blue. I want to keep them in wood so I planked the transom which was ply to match the rest.
  10. Capt's both, Thank you for your kind comments. My model does seem to have a lot of differences. Regarding the pale section, my first attempt was to ignore my instructions and do what others had suggested which would have been more similar to yours. However it looked a complete mess. When I overplanked it, I followed my instructions which gave precise measurements for the line between bass wood and sapele running parallel with the bulwarks. If you remember I asked the multitude about the positions of the rubbing strakes which will eventually cover the join. I had mixed replies between parallel with the deck or parallel with the bulkheads. The difference whilst only about 10ml I thought would be crucial later so I stuck with the instruction measurements. However I would add that the lowest rubbing strake now would leave a large gap at the bow so I am thinking of putting two on instead of three (another difference between our kits) Thanks also Hamilton, I didn't dare use CA glue because I know how badly it marks the wood for later varnishing and I want to make the best of the sapele colour.
  11. Greetings all! I know I have been quiet for a while but I have not been idle. The second planking is now done to the best of my limited ability. In fact the pale wood section I had to second plank twice because the first attempt was dreadful and I couldn't get it all off so I went over the top. Cunning eh?! It may be of interest to some that the planking was all done with PVA glue, no CA at all. Also no pins were used because I want to keep the boat in natural wood and not paint it so I held each plank with sticky tape to measure tapering and for gluing I have to trim, sand and varnish next. I am hoping that I can use the sanding process to fill some of the little gaps with sawdust and then varnish to keep the dust in situ. I realise this is not museum quality planking but, it has covered the whole hull and, to be quite honest I am pretty pleased with myself seeing as how this is my first real go at it.
  12. Hi Capt!! I haven't done a lot either. I did start my second planking which was awful so I covered it with a third go!! I have been trying to bend rubbing strakes before proceeding with the second planking below them. Been away a couple of times but the garden grows fast this time of year and loads of other jobs to do so the boat takes a back seat for the time being.
  13. You are doing brilliantly Dom!! Don't worry to much about the critics, I am sure they get it wrong too sometimes. Yours looks great and you should be very pleased with you efforts!
  14. That looks really smart CF! You have done some really careful work there, I am impressed.
  15. I think the point has been made quite enough. The comments have obviously been taken on board. Further comments along the same lines are neither helpful or constructive. Give the guy a break and get on with some modelling.
  16. Actually Dom that is really helpful. It shows me the measurements for the large rubbing strakes and the position of the smaller top one which is above the 19mm. That is a crucial measurement so thank you very much. Doesn't immediately help with the bulwark issue but I think it will help.
  17. I know Dom and I have tried but the pictures are just too small. Don't forget we are taking about 10mm on the whole huge model which doesn't sound much but makes a huge difference.
  18. Nice try matey but I don't know if I am any the wiser really. Maybe you will understand now why I want to know exactly where these rubbing strakes go. I have put out a couple of feelers to other MSW members who have done the Bounty and I await their advice. I did bung my transom on today!!
  19. Dom, I want to know EXACTLY how you decided on the position of your marker planks. Are they lying as they lay or have you bent them at all? Why did you put them so low? etc etc. I need this help!!!
  20. It looks good to me Dom but it also occurs that this 'no lateral bending' lark doesn't matter as long as you have the thickness of wood to allow for the removal of clinkering afterwards. If you don't do it the way you have you would have to shape each individual plank as I see it. I feel, whilst it may not be 'correct' that the way you have done yours is the same as I did for my stern section which once sanded looks good. So are we right?
  21. Thanks Dom, I did look at those but on such a small scale it doesn't really help. I can get a good idea from the model itself but it seems that around the bow particularly these measurements need to be fairly precise. The difference between parallel with the bulwarks and parallel with the deck is 10ml which you will appreciate is a lot. Maybe you could measure yours (I appreciate it is much smaller scale) and see which your strakes run parallel to?
  22. I quite forgot about the plans I have for the masts etc. However would you believe they don't show the rubbing strakes at all!!! Back to you matey or anyone who has done a Bounty and can help.
  23. Oh Dom, that's a good one!!! What plan sheets would those be? Presumably the ones you don't get with this kit!! Could you give me any idea from your Bounty?
  24. Hey all, I need some help/advice about rubbing strakes. I have to put on 4. Three of them are 2x5ml and one on top of those is 2x3ml. My wonderful instructions give me measurements from the rear bulwarks and the middle from the deck but no instructions as to the bow. So my first question is should rubbing strakes run parallel to the top deck or the bulwarks? My second question relates to the fact that above the rubbing strakes I have to plank in ramin wood and below in sapele. The instructions say plank first and then put the rubbing strakes on. Apart from the fact that that is a waste of wood it seems to make sense to me to put the rubbing strakes on first and then plank up to and down to them afterwards. Doing it that way would also give me the line for the second planking. What do you think?
