Everything posted by *Hans*
It's been quite a while since my last post on the trireme.... sorry. Started again with two cent coins - collected them via lokal stores and started again to make them convex, tinned them and soldered a little grip on the backside. Thus the shields could be hung on a pole on the ship's side to protect the sailors during sailing, and could be easily taken off to use as shield in man to man fights. I've got 28 now - need 60 of them
Batavia by *Hans* - FINISHED
*Hans* replied to *Hans*'s topic in - Build logs for subjects built 1501 - 1750
Every once in a while I'll post something in this topic. On a Dutch forum Mr. Danny Mulders is building the Kolderstok Batavia. Please visit http://www.modelbouwforum.nl/threads/bouwverslag-kolderstok-voc-schip-batavia-1-72.234841/if you are interested. -
As far as I know the first editions of the book where with plans, but they skipped these plans in the later versions.
Thanks Hartmut! It already has been a while since I finished her, and after that I started with a Greek Trireme (see my signature) This one however has come to a temorary stop due to the fact I started making wooden building kits of the Batavia. There are hardly any Dutch 17th century ships as kit available so I started to fill this gap. Working model for the Batavia kit was/is the "Dordrecht" from 1618 - a sister ship of the Batavia and the previous vessel Francesco Pelsaert sailed on. There is no build log on the Dordrecht, but here some images of her stern: -
Jan, merely for two reasons: - first of all the fun of trying it and doing it. I think it is a main part of modelbuilding not only making the model itself, but also (to me) make the tools and get the feeling of how things can be made by yourself instead of just use the parts provided in a kit. - second: when showing a modelkit to someone they often ask if ornaments etc are in brass or other cast metal. Resin is good stuff and easy to work with, but not everyone is pleased with it. But to be honest: the resin is in fact the better product. Easier to work, easier to glue, easier to paint, easier to change, easier to sand, etc.etc. -
Regarding the angle of open gunports: Keeping in mind how over 300 people had to live and work for over 9 months on their journey to the East Indies and back I am pretty sure they wouldn't bother about the angle they had opened the lid. Just pull the rope with blocks until it won't go further - which means all the lids would open merely the same...but never all of them under 97,4 degrees angle or so
Nice job Jan - looking good! thread not behaving the way you want it is the most annoying thing there is.
- 139 replies
- corel
- prins willem
Piet, just took a quick re-read through your topic - You're doing a very nice job here! Did you already try to do something on the diverse carvings for the stern? I saw your nice drawing (and saved it on my computer - If allowed ), but I guess you haven't started on it. I'm eager to see how nice this is going to be!
Thanks Chris & Nils, It is really fun doing this! There is also a main diffirence in casting resin and castin tin. - resin can be done just like pouring yoghurt in a bowl - so an open mould and just pour the fluid in it. - tin has to be done in a closed mould. So I make the red silicone mould as an open one and then use a piece of oak plank to close it. Important then is to think how the air in the mould can escape - thus all the "opkomers" (English word?) for releasing the air. -
I made all the ornaments for the Batavia kit in cast resin, but have also started making these in white metal. I made a special casting mould of heat-resistant silicone and started pouring. The white figure you see is a special order for a customer in South Africa. The red fluid is silicone on the fresly made new ornament for the Batavia. Although not very clear, left the mould and right the first attempts. -
Piet, About blackening the brass - just give it a try! I use some blue fluid (which I call Eau de Cologne) to blacken the brass, but it does exactly the same on copper and on soldering tin as well. The fluid is normally used to blacken tin on tiffany lamps (I once made some of them) and is (I guess) about the same chemical bad stuff as any other blackening fluid.
Proxxon is a German company and they usually make good stuff. Maybe this has to do with the fact that Europe is 230 Volt / 50 Hz and the US 110 Volt / 60 Hz. The machine can be the same, only the elektromotor has to be changed to a 110 Volt type. And if this one is of less quality due to the manufacturer who makes these, well. Some other fact we had here in Europe (a bit off topic - I know) that the voltage changed to 230 Volt with a +/- of 10% instead of 220. So you could sometimes have over 250 Volt on the net. A lot of nice 80's amplifiers went down in this way. If you have rather high fluctuation on the net this can cause trouble.
Hey AA schipper - good luck with this vessel. It is always nice do do some scratch-work and change an excisting kit into something diffirent. Makes it a nice job - not only the building, but also the bookwork you have to do. And regarding the Batavia and the plastic model of Revell - please take a look here: www.kolderstok-models.com
Hey Piet, You know I like these kind of ships - and you are making a pretty nice one! Allow me though to make a small (positive mend) remark: The green color you have used on the Surabaya is quite "vivid" - maybe a bit to much. I don't know if you are planning to redo some paintwork on the hull, but think about making a more grey-green for the upper hull. I guess you haven't visited the Batavia on your trip to Holland this summer (due to your tight scedule), but she has quite the green color which would suit your VOC-lady very well!
