bluenose2
Posts posted by bluenose2
  1. Hello Les here. I have a new tool to me in my must have tool box. It is the DSPIAE Electric sanding pen. It is a rechargeable mini Dremel like tool. I have used it to drill very small holes and do close grinding. For close in work it kills the Dremel or other similar tools I have. It isn't as powerful as a rotary tool but it fits very well in the hand. You can purchase a tungsten drill bit set separate. The drill was $39.97 Can and the drill bit set was $10.97 here in Edmonton. Please check it out. And no this is not a commercial. Check out their web site to find a distributor near you.
  2. Hello Les here. I am currently building the Corel version of this ship. I have purchased the book Endeavour, by Karl Heinz Marquardt. I believe this to be the best reference book out there. I have made many revisions based on the material. I have built the masts and yards based on this book. Now my dilemma is that the mast and rigging plans don't necessarily agree with each other. So what next? The build plan shows the places where you belay or rig the ship but the book does not. I feel your pain.
  3. Thank you for your responses. I can only imagine a ship rolling out of a yard fresh as a daisy. What would it have looked and smelled like? My new build on the Beagle has made me think if I should make it pristine or like a ship that has done a few years at sea. I don't build any of my models overly weathered as this, only in my opinion shows disrespect for the craft. As this will be my final build, I agree whole heartedly that the final planking of especially walnut may add some limited interest for those who don't know anything about how ships were built in this era but thats not the point. I would like to get this one right so I can look at it and say it's as close as I could get it. Luckily a have a wood supply store in my city so I can get what you have recommended.
  4. I have a question. I am working on my next build the Beagle. I would like to do something different. I believe that ships of this era where planked primarily with oak not walnut as supplied by the kit suppliers. I have some old growth in my stock and would consider milling it for planking etc. Would this be a good idea and how would I finish all the components? Thnx Les.
  5. So I think this is what I'm going to try. Take a small sharp blade and very carefully scrape the joint so I don't feel any sharp edge on the joint. Then flood in some Varathane to seal the crack. Then I will see if I can polish and buff the repair. I will use some Novis polishing compound used for Plexiglass scratch repairs and see if this works. If that isn't satisfactory I will mask out and spray new clear coat just like an auto body shop would do for a repair.
  6. My table saw and blades are fine. That isn't the issue. My question is if you look at the end of a 3/4" x 4" walnut plank, which way would you rip it to get the most flexible planking? Would you stand it up and rip .5mm strips then rip it to 5mm or lay it flat 3/4" rip .5mm strips then cut to 5mm? And sorry as I said I am talking about walnut, the second planking a lot of manufactures supply in your kit.
  7. Hi Les here. I am finishing up my Beagle but have run out of walnut second planking. To source it pre cut will cost about $100.00 to get it shiped to my house here in Canada. I have some 1x4 planks in my shop. I can cut it on my table saw but I don't know in which direction I would do it. I tried this before and the planks cracked when trying to install them. So do I stand it up tall on the four inch and cut to thickness and then cut to width or the reverse?
