Posts posted by Ian B
Posting the picture I noticed the lanterns are not level-- better rush down stairs grab the boat and fix that!!!!
So I made a new decretive panel (no idea what the proper name of it is LOL ) and adding some cut out shape in the form of a circle and cornets plus I painted some wire gold and glued it to the panel as branch stems then painted gold leafs on the wood. With your eyes shut in a dark room it passes as a carving ha ha I also added the name with gold letra set , a couple of lanterns and the rudder chains--- a far more pleasing bum
Well I decided to sort out her stern, I did mention I would in passing earlier in the build. here is her stern built exactly as per the Billing Plan... I can sense you all yawning and a rapid on set of sleep!!!! Apart from being very boring it does not appear in anyway representative of a stern of that period.
pricey Endeavour? It should would be, you would have to throw it all away and build the brig from another kit as nothing will fit on it ha ha ha
I had forgotten all about this process. I used to make my own PCB's in the 70/80's and with your take on it I will have a go
This has given me another idea to add to my build... quite an easy addition of detail to any build.
thanks Ian
Thanks Keith-- I will have a look at the rigging plan again and work the way you suggest. I had fitted the foremast and rigged it before seeing all the advise about not doing that as it was easier to fit yards and sails first..
Thanks Matti the blue was toned down by giving it the same coat of oak stain I used for the hull.
Unless advised otherwise my next actions are-
1.--- make the sails
2. fit sails to all yards
3. attach foremast yards to already fitted mast
4.attach main mast yards - then attach mast to hull
5. fit mizzen mast yards- attach mizzen mast.
The main and mizzen are only dry fitted, I thought it would give myself lots of room to work around each mast as I rig them.
My wife has been keeping me busy on the DIY front but I have now finished making the yards. In the kit they are only shown as plain yards with the appropriate blocks attached. I have with inspiration and pure plagiarism from other builds on here created stun sail booms, the support banding around the middle of the larger yards and feet ropes. For the foot ropes I drilled and glued in 3mm loops for stirrups, wrapped line around the yard to make the appearance of them being tied and painting them black. On reflection I should have not had the line tight but sagging slightly between stirrups.. never mind one to remember for my second build. The stun sail boom supports were made from soldered copper wire and blackened.
I have posted this on another thread talking about Buoys which inspired me to make some for my ship. but thought it worth also adding to my build. I am still working on the main and mizzen masts which should be ready for installing next week some time-fingers crossed
Using a couple of old glass beads a bit of string and some wire it makes a reasonable (I think so) facsimile of a 17c anchor buoy.
- mtaylor and qwerty2008
- 2
amazing -well deserved recognition for what looks a simple straightforward display but massively under plays the skill, craftsmanship and patients required to achieve this superb standard..
well done
wow that is good.. I have booked mark them and will do something similar when I get onto my next project as it could do with several small parts made in brass as I know the kit comes with the bits in plastic and need painting brass coloured.
That is a touch that's makes such a difference to the finished model.... do you mind saying if it was very expensive getting the prop made?
wow loads of super info, I am really glad I asked. thanks for the link. Next week I hope to sneak away from doing DIY and household chores when I am home and start creating them. Thanks again everyone.
Ian
- geoff, avsjerome2003 and CaptainSteve
- 3
This is a nice touch to add to any model, looks easy enough to make. I shall make a couple for my build, thanks Keith for the idea
That's great, thanks for the very prompt reply and explanation. Right now to look at some of the builds on here about scratch building them..
I think I have the right name , it is the parallel booms on the upper side of yard arms. Is this a feature all large square riggers have? It is not shown on my Billings Bounty model but a few Bounty builds and a lot of similar models have them? I am about to tackle making the yards and if they are needed then I need to plan out how I will do it.
Thanks
What about this multi purpose machine?
The Unimat 83000 it seems to drill, lathe, mill and sand-- I am sure it could make the coffee to?
Just google Unimat 83000
HMAV Bounty by Ian B - FINISHED - Billing Boats
Thanks for the comments Gunther as for your Ocre model MIke I am sure it is far closer to the real thing than my flight of fancy I just knew I would always the look of the Billngs bum!
